Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Im considering installing the Banks Big Head waste gate accuator on my 99 PSD. Just wondering if anyone is using this product and if they would recommend it. Will it put any extra stress on motor, or is this a fairly safe product? Thanks for any opinions.
So not too many using the Banks huh? Today I heard of the turbo master waste gate accuator. This Idea seems better than the Banks system. Does anyone have ant opinions on the Turbo Master? I do not have a boost gage, so would I be able to properly set this system up? Is there a way to rig up a preasure gage to measure boost to set up the Turbo Master? Any thoughts are appreciated.
I looke at buying the Big Head, and decided to just disconnect the stock wastegate acuator and plug the pressure feed lines going to it. Who needs a wastegate anyway?
Early 99 F350 7.3 250k
SRW single cab 4x4 Auto Trans
4" turbo back w/ 5" muffler
Isspro trans pyro, boost, and HPOP Gauges
Stage 1 single shots from Full Force
Riffraff FRX & HPX
Terminator 500 HPOP
EBPValve delete W/ Blank Pedistal
Kickers all around w/ 10" sub
4" Cold air intake
35" MTs with 1.5" wheel spacers
DP f5 Tuner w/ F8 switch
On board air w/ Air horn
AST Ultra remote start
WMO !!!!
I top out at 32psi. I did a lot of things at the same time, so I dont know how much disconnecting the wategate affected things. If I was making over 40psi, I would probably worry about too much boost, but the 7.3 has got a pretty serious lockdown on the head gasket. The danger of too much boost, is that all of the cavities trying to contain that pressure (boost) have to be able to withstand it. One of the most typical places for this pressure to escape on a diesel is the head gasket.
Riffraff FRX & HPX
Terminator 500 HPOP
4" Cold air intake
WMO !!!!
Remember your fueling and tuning can play a large role in overall boost as well. A truck with stock injectors and stock programming won't make as much boost as a modified truck will.
DP Tuner
Sales and Technical Support
Specializing in Power Stroke Tuning and Performance
828-221-0076
I've been running my stock actuator unplugged for a while now. It helps, but I can hit the 34psi "safe level" on a stock bushing GT38 turbo very quickly and then have to back off. I'm starting to think I didn't catch myself quick enough too many times because the center rotating assembly is now stiff to rotate. The DieselSite unit, TurboMaster, I just purchased and based on theory will recommend every time. You need to make sure you aren't prematurely destroying your turbo. Use every bit of boost you can, till you shouldn't. Only the TurboMaster does this. I will see how it works once I get it.
__________________ '02 F-350 "Babe The Big Blue Truck" 4x4, Ext. Cab, 8' bed, SRW
DP-Tuner 80T, Stage I single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
I ran one for the last seventy thousand miles on my truck. I adjusted it to four turns on the turn buckle as instructed by Dennis at ITP. It increased my boost from the stock 15-18 to just over 20 PSI. When I added a DP Tuner it boosted anywhere between 25-30 PSI. This is tough on a stock turbo. Just two weeks ago the turbo gave up and I upgraded it to the Garrett Ball Bearing GT38. Currently I have 168,000 miles on my truck
I plan on selling my used Big Head on Ebay with no reserve.
