Tightening up the limited slip? - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 09-17-2007, 12:01 AM Thread Starter
is there a way to tighten up the factory limited slip?
2000 F250
Stage 2 Singles. 1.0 Ex Housing.
The1andOnlyKyle is offline
post #2 of 14 (permalink) Old 09-17-2007, 01:07 AM
Re: Tightening up the limited slip?
You can rebuild it, but it wasn't very good from the factory. If you want a good limited slip, spring for an aftermarket.
WestPSD
Early '99 F250 Lariat SC SB 4x4 7.3, 305-70-16's, DP Tuner 6 pos chip, 4" MBRP, BRV+, K&N FIPK, Gauges, Sonnax kit, 3 disc-billet converter, True-Cool, 3.73's, Detroit TrueTrac, Line-X, goose neck, 5er, alignable bumper hitch, AutoEnginuity
westpsd is offline
post #3 of 14 (permalink) Old 09-17-2007, 02:07 PM
Ditto on that..
Ironhide is offline
post #4 of 14 (permalink) Old 09-17-2007, 04:00 PM
FionaThe02PSD's Avatar
My Photos: (12)
I heard this weekend that the Sterling had a decent setup but people complained about the noise so they took out some of the clutches and put metal shims in so it would slip.
True?
Fix?
2006 Dark Slate F350 CC LB 6X6 Lariat Tow Boss Complete with training wheels.
Vegetarian, an old indian word for bad hunter!
K&N Intake, Coolant filter, Recon smoked LED litght: tail, Clearance, Center bumper, 3rd brake, Fat fender, Pressure pro TPMS, Firestone air bags, Alpine/Infinity/Polk sound system, Autometer Phantom EGT,Trans,Boost gauges above the rearview mirror.
For the BEST in performance parts and accessories
FionaThe02PSD is offline
post #5 of 14 (permalink) Old 09-17-2007, 06:01 PM
Dieselmaster's Avatar
My Photos: (18)
some people over do the friction modifier and almost completely disable the effects of the limitied slip. A cheap easy way to start would be to change the fluid and start by not adding any friction modifier, then only add it if it binds up too much when turning.
New Truck - 2002 Shadow Grey F250 CC SB - K&N FIPK - 4" Turbo out exhaust - Saving up for a lift and new tires.
Old Truck - 1999 F350 CC LB SRW 4x4 Lariat PSD - <font color="red"> Fire Red </font> ... 37" Goodyear MTR tires... APP Forged One Piece Wheels 17x9.5 ... DI 4-way Chip... ProComp Stage II 6.5" Dual Shock Lift... 4" Turbo out Exhaust... Trango Shift Kit....Armaliner Spray in Bedliner... Heater Core Bypass Mod.... ProComp big air intake system. DIS A-Piller Gauge POD - Autometer-Carbon Fiber gauge's - Pyrometer - Trans Temp - Boost...Gutted EBPV... Hutch Pre-tank & in Tank mods... Black Lab hair all over the back seat.
Dieselmaster is offline
post #6 of 14 (permalink) Old 09-17-2007, 09:03 PM
elkkiller's Avatar
Dieselmaster was thinking exactly what I thought.... start over with the fluid. my limited slip works perfect, I put 2 perfect divots in my drive way just yesterday backing up. much cheaper than new rear end ($1200.00 + )~Aaron
2000 F-250 S\C 4X4, rebuilt engine \ DP Tuned \ 3 Gauge cluster \ "cackle cure"- FX cross over fuel return \ shimmed fuel reg. 69 psi. \ new rear-end \ rebuilt tranny \ transgo tugger shift kit w\ non-modulated T\C lock up \6.0 trans. cooler \ wicked wheel \ \ open element intake \ magnaflow muffler \ ccv mod \ HX mod.\ Redhead steering gear \ Head light harness and lenz up grade \ Bilstien shocks \ in tank and pre-pump mods.\ and a HOLE in my wallet so big I can park my truck in it!
elkkiller is offline
post #7 of 14 (permalink) Old 09-18-2007, 12:15 AM
Yes it doesn't have all the plates it could, and yees it can be rebuilt tighter. There is someone on here that posted on it, has it in his sig too.
Diesel Mechanic 34 yrs Maintenece Manager 23 yrs
Garbage_Mechanic is offline
post #8 of 14 (permalink) Old 09-18-2007, 01:12 AM
SVT
Add xtra clutch packs just turns less before lock up worked on the 8.8 in my mustang but same concept buy the rebuild clutch pack kit and save a couple of your old ones to put in as shims.
I could get you more specifics from my diff guy tomorrow if you want more info
97 Black CC F250 4X4 BDP stage 2's D66 5"exhaust Snow H2o/meth shimmed FPR modded pedistal 17*HPOP tymar intake black bird rear disks HPX BTS Tranny 10/4/07
SVT is offline
post #9 of 14 (permalink) Old 09-18-2007, 09:45 PM
My Photos: (5)
This tech article was written by a good friend of mine and has worked for countless 8.8's. Page 3 has the general idea of restacking the frictions and steels.
http://pomoforacing.com/tech/FTWOG.pdf
2002 Super Duty 7.3 CC 4x4 - 4.5" Icon lift, 35x12.5x17 Toyo MTs on Weld Racing X-Landers, 08 Tow Mirrors, DP-Tuner, 38R, RR Plenum Inserts, RR Boots, HPx, Frx, 4" Magnaflow, IH Bellowed up-pipes, coolant filter, hutch and harpoon, Ford AIS, CCV mod, BTS, 6.0 Trans Cooler, Auburn LSD, 08 Diff. Cover, Pullrite SuperGlide 5th, Firestone Ride-Rite air bags, Pioneer P4300DVD, Rear Entertainment LCD and a new steering wheel
HoustonPSD is offline
post #10 of 14 (permalink) Old 09-19-2007, 04:28 PM
My Photos: (12)
Would that apply for the Sterlind as well? I would think so, otherwise you wouldn't post it right?
post #11 of 14 (permalink) Old 09-20-2007, 04:13 PM
My Photos: (5)
I *think* so. We are going to try something out here in the near future on another friends truck.
post #12 of 14 (permalink) Old 09-20-2007, 11:36 PM
Maintain's Avatar
Keeping an eye on this b.c I've got one wheel peel and I just want it to do both in the next few months before going to a detroit trutrac.
2001 F250 CC/SB Platinum
11.62 @ 115.79
SWAMPED
Maintain is offline
post #13 of 14 (permalink) Old 09-21-2007, 01:08 AM
SVT
Diff guy says don't try this unless you know what you are doing.He says when you buy the dealership rebuild kit it comes with different sized shims. the shims will be the last disk you take out of the carrier (closest to the brakes on each side) He says install the biggest shim in the kit for the fastest action (it may chatter through corners)
you've been warned but it helps a ton you make the call
SVT is offline
post #14 of 14 (permalink) Old 09-24-2007, 03:41 AM Thread Starter
How much are the rebuild kits? And where's the best place to get one?
2000 F250
