Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
How much torque can a stock tranny hold. I havent upgraded my signature yet but I do have gauges. I loaded the 100 h.p. program yesterday from my 60 h.p. to see if I can get more mpg. Just out of couriosity I dropped the hammer from a 5 mph roll and my tires broke lose through 1st. gear and then I let out of it. My tranny gauge driving threw town and then getting after it never got above 155 degrees. I rarely stomp on it and never pull anything over 4000 pounds. My tranny was gone through with a new torque converter before I bought it 4000 miles ago and just don't want to break it.
Old Truck--99.5 SD Extended Cab Long Box, 5 inch Straightpiped 6" SS Tip, Diablo predator, K&N air box mod, Gauges, SP Diesel EBS Eliminator,SP Diesel Overboost Eliminator, Zoodad Mod, Leveled, BFG 285 Mud TA's, EBPV Gutted, adjusted wastegate, TC lockup Switch, Wicked Wheel, BTS tranny, BTS 6 way chip, Van Turbo.
07 Classic CC SB D-Max 325/60/18 Nitto Grapplers, 18" American Racing Wolverines, PPE HOT+2E.T., Lift Pump,5 inch Straight Pipe, 6 inch ss tip, Gauges, 52 gallon titan tank, Some Tranny work.
The stock tranny can usually hold up pretty good if you do a couple things. 1) A strong Torque Convertor (u said it was changed but is it a strong one?) 2)a shift kit. 3) keep temps under 200F
Do those things and your tranny "should" hopefully hold up as long as you don't put BIG power to it like with big injectors and such. If you constantly "drive it like you stole it", then all bets are off.
The tq is a new factory one. I see in your sig you have one out of the new 6.0. Is there any links or literature on this mod?
I recommend you use the search function for the info. Also, John Wood Automotive is probably the top expert on the use of the 5R110 TC. His website for his contact info is www.jwtt.com . He will spend the time to talk to you and discuss whatever you need to know about your tranny.
