Tranny cooler: 6.0 -vs- Tru-Cool Max 4739 - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 08-04-2009, 10:42 PM Thread Starter
Teknobenji's Avatar
Need to upgrade my tranny cooler - have read about 100 posts on here and am looking for a chime in from the tranny experts on here (Mark?) I cannot find a decent price on a 6.0 cooler but dieselsite has the Trucool for a VERY reasonable price - brackets included - any downside to the trucool? it is a vastly larger cooler than stock!
Thanks!
1999.5 F250 Crew 4" Magnaflo Turbo back exhaust, DIY intake, AIH Delete, HPX Line, zoodad mod, Wicked Wheel, Gauges (Tranny, Boost, EGT) DP-Tuner
ITP "In-Tank" mod and prepump filter, RiffRaff FRX Regulated return, foil delete and lighted cup holder...that's right - lighted cup holder.
Teknobenji is offline
post #2 of 8 (permalink) Old 08-05-2009, 09:50 AM
FleetMan's Avatar
I originally installed a six pass Hayden cooler (19,000#) as my aux cooler, mounted in the open area behind the front liscense plate - license plate and holder relocated to enhance air flow. The 60 to 90 degrees above ambient was consistent while towing a 9,000# TT in 100 degree plus temps. I replaced the Hayden cooler with the Tru Cool Max and experienced similar results - this was done long before the 6.0 cooler became available. I do not have the oil to water cooler and other than one time when stuck in stop and go traffic for an extended period of time, have never seen my tranny temps go above 185 degrees. In my case, I see no ned to convert to the larger 6.0 cooler.
Early 99 F250 PSD (XLE4) XLT, Extended Cab, Short Bed, 4X2, BTS Trans/TC, 3.73 Limited Slip, Transfer Flow 48 Gal. Mid-Ship Tank
Western WA - Member since August 2001
FleetMan is offline
post #3 of 8 (permalink) Old 08-05-2009, 10:00 AM
I don't think "vastly" is the word I would have chosen, but it is bigger. The OE cooler has 9 rows and #4739 has 13.
444-4D is offline
post #4 of 8 (permalink) Old 08-25-2009, 11:40 AM
jerome b.'s Avatar
I just installed the Tru-cool 47391 in my 2000. The ambient temps were in the high 80's to low 90's. Prior to the installation, my trans temp was in the 160 to 180 range. During my 60 plus mile run yesterday, the trans temp stayed right at 145 degrees. I have not hooked up to my 12,000 5'ver yet but considering the unloaded difference, it should be a dynamite $110 investment. It is connected inline going from the stock cooler to the 47391 and back to the trans.
jerome b. is offline
post #5 of 8 (permalink) Old 08-25-2009, 02:56 PM Thread Starter
Teknobenji's Avatar
Great! thanks for some concrete info! that's what I'm looking for!
post #6 of 8 (permalink) Old 08-25-2009, 06:23 PM
I have the 31 row 6.0 cooler and pull a 37ft toy hauler 5ver here in the Las Vegas heat. Before the change to the 6.0 cooler the trans temp would get hot quick. After the install pulling up out of Laughlin which is a 7% grade at times with the ambient temps around a 100 my temps are between 180 and 190 which I think shows it to be very good for my needs. just my .02
2001 Ford F-350 drw 4x2 auto,4.10 gears,Turbonetics ball bearing turbo, Turbo Master Wastegate controller, Dieselsite Boots, ceramic coated up-pipes and exaust manifolds, DIY Tymar, 4 inch exaust turbo to tip, Isspro guages EGT,Boost, Trans temp from DieselManor, 6.0 trans cooler, AIH delete with boost attachment, ITP Regulated Fuel Return kit,hutch and harpoon mod done, ITP in tank and prepump mod kit, Rotella ELC, 203 Stat. Oil Guard by-pass filter system
DP Tuner-no start, stock,40,60,80E,120
BTS Transmission,(BTS-BUBBA)
105,000 miles, built to tow
Toys: 03 Screaming Eagle Duece Harley
37ft Cyclone by Heartland 5th wheel toy hauler
ford4me2 is offline
post #7 of 8 (permalink) Old 08-31-2009, 10:59 PM
I just installed the 6.0 cooler in my 7.3 and I have yet to tow with it but I can allready tell a difference in temps around town. Normally around town in 85-95 degree weather it sits right below the 170 mark, since install of cooler haven't even seen the pyro move! I can't wait to tow with the new cooler next step will be deeper tranny pan and diff covers along with gears I believe the cooler is well worth the money and install is very easy
1999 F-350 Dually 7.3 diesel lifted 8.5inches 37x13.50 xtream all terrains
Just Installed a DP Tuner F-5 chip, with stock, Decel, 60 Hp Tow, 80 HP econo and 120 HP performance and WOW!!! k&n airfilter Road Armor front bumber Warn 15000 winch Shift Kit, Beefier tourqe converter. Kenwood Indash Navigation, Sirius Radio, Back up camera, Kodiak Electric Steps HID Conversion Kit..
Next up is Gears!
buzzy12 is offline
post #8 of 8 (permalink) Old 09-03-2009, 05:53 AM
If you can get your hands on the 31-row cooler, then I would go that route. EBay sometimes has them. My temps unloaded are generally around 130 with ambient 75F. The other day when it was raining and in the 60's, the gauge barely even moved above minimum.
2001 7.3L, John Wood stage-1 transmission, 6.0L trans cooler, Single-shot HO injectors, ITP RR, DP Tuner, Ford AIS Intake, 4" Exhaust, Detroit Truetrac, 245/70 tires, Accuride 19.5x6.75 wheels
F450Diesel is offline
