trans bypass tube - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-20-2009, 12:07 PM   #1 (permalink)
DJM0525's Avatar
trans bypass tube
What are the cons of deleting the warm up or bypass tube on the transmission? And is there a kit to do it I saw where someone just smashed the tube closed but I want it done right. And also what is the advantage?
DJM0525 is offline
Old 11-20-2009, 12:26 PM   #2 (permalink)
The purpose of the tube is to provide lubrication to some parts in the back of the trans should the flow thru the cooler become restricted. So the con would be burning up your trans if the flow thru the cooler gets restricted. The only advantage I can think of is the elimination of a part that could fail. There isn't much in there to fail, just a ball and spring.
444-4D is offline
Old 11-20-2009, 12:36 PM   #3 (permalink)
Mark Kovalsky's Avatar
It's not there to help warm the trans. In fact it doesn't work for that at all. It only bypasses when the coolers are restricted.
Pro of blocking it: None
Con: Failed trans
Mark
Mark Kovalsky is online now
Old 11-20-2009, 01:25 PM   #4 (permalink)
DJM0525's Avatar
Thanks for clearing that up, but if there is a ball and spring in there if that gets froze up will the return line from the cooler that connects to the back end of that tube not let ATF flow back into the tranny or is the ball and spring on the upper end? should I be taking that tube off and making sure those arent messed up I don't want to end up goin through another tranny.
DJM0525 is offline
Old 11-20-2009, 10:30 PM   #5 (permalink)
MonteC's Avatar
Its rare but the check valve does fail. If your worried about it ride down to ford and pick up a new one. Cheap insurance.
99 (5/98) F350, PSD, CC, LWB, DRW, 6SPD, 2WD, 4.11 TRUE TRAC, RED, S&B, MBRP 4", ISSPRO EV2 EGT/BOOST, DP TUNER F5.
MonteC is offline
Old 11-21-2009, 05:00 AM   #6 (permalink)
If the ball and spring fail fluid will bypass the cooler and keep the trans lubricated.
Mark
Old 11-21-2009, 08:19 AM   #7 (permalink)
MonteC's Avatar
Yes, but the fluid will not cool.
MonteC is offline
Old 11-21-2009, 12:32 PM   #8 (permalink)
Touchette's Avatar
Send a message via Skype™ to Touchette
Trans Bypass Tube
What advantage are you looking for by removing the bypass tube?
This is designed to protect your tranny in the event of a clogged / failed due to blockage ATF Cooler.
A replacement online will cost about 50 bucks but will be higher at the Dealer.
2002 F-350 CRW DRW PSD Larriat, 4" Down Pipe 5" Airlow Inc Pipe and shorty muffler, autometer full pillar guages, AFE 2 Magnum intake, DI six pos chip, DI Fuel Reg Mod, #8 Inj AD, Front and Rear Hitches, Suv Lights harnesses, White Night backup lights, P&E Tonneau, Tail Gate Guard, Husky mats splash guards and burl dash set, Mag hyTec trans pan diff covers, TTM, Oil Pan Heater, Oil Guard Bypass filter, Several Brite Lyte mods, On Board Air Comp, Optima Batteries, PW Harness, Heater mod and Bob Riley Diesel stuff throughout.
New decals and Badges, Sonnax Valve/Tricumulator Springs, Dahl Fuel Filter, Fuel tank mods. Ball Bearing Turbo. NON-EBV Pedestal, Gutted EBV Outlet, Difuser Doggle, Intake Heater Delete with that little wire and diode thingy, Ceramic Coated Bellowed UpPipes, RiffRaff Diesel Intake Manifold Inserts, F-650 Lower Dashboard. Thinking of putting Solar Panels on the cab roof and calling it a Hybrid.
Touchette is offline
Old 11-21-2009, 05:14 PM   #9 (permalink)
That's true, but it is better than the alternative. Without the bypass the trans doesn't get lube and it dies.
Mark
Old 11-21-2009, 06:03 PM   #10 (permalink)
bryrylan's Avatar
My Photos: (11)
Which would result in ur temping reading hot? and then you replacing the bypass tube and maybe the fluid instead of the trans toasting before you have any clue? right?
2002 F-250 3.5" leveling kit, 305-70-16 Procomp AT's,Eagle alloys 16" rims,Autometer procomp trans boost pyro gages, AIS, Coolat filter ELC, TS 6POS chip, Banks Billet torque converter, Transgo tugger shift kit, galaxy CB pumpin 20watts, Sirius radio,Kenwood cd player, kenwood door speakers, Infinity tweeters, 500 watt Pioneer amp, 10" Pioneer sub, Panelite LEDs, Custom back rack with LED lights, Bores guide poles, SHO-ME led warning lights, 4" exhaust, Grandrock 5" stack kit with bullhauler stacks,MBRP y pipe cover, 9Ft Fisher plow. Timbren SES
1995 30ft 14K Gooseneck flatbed.
10K winch
All LED lights
bryrylan is offline
Old 11-22-2009, 07:14 AM   #11 (permalink)
Right! That's MUCH better than replacing the trans.
Mark
Old 11-22-2009, 09:18 AM   #12 (permalink)
MonteC's Avatar
I never told him to get rid of it. I suggested buying a new one if he was worried about the old one.
MonteC is offline
Old 11-22-2009, 01:04 PM   #13 (permalink)
If you decide to look at it, and you do a good job of looking, you will discover that there is two ball and spring valves. One of them is in the rear banjo bolt. This one has nothing to do with the fluid bypassing the cooler. The other one is in the tube that connects between the front and rear banjo bolts. This is the one that opens to let the fluid bypass the cooler.
444-4D is offline
Old 11-22-2009, 09:06 PM   #14 (permalink)
DJM0525's Avatar
I guess i will have to take it off and check it out when I change the fluid thanks for the info.
DJM0525 is offline
