Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 7.3L Engine
Upgrades and Aftermarket - 7.3L Engine Upgrading and adding aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 01-20-2008, 03:44 PM   #1 (permalink)
TS Performance chip feedback
I'm looking for peoples satisfaction with the TS chip setup. Power and MPG satisfaction. I know everyone raves about the Dp-Tuner and if I had the $$$ I'd go there too. While we're at it, what are the differences between the two. Heard of Tony Wildman, but don't know much about his.
Thanks in advance for the great info.
2001 F250 SD 7.3, HPX mod, in tank mods, ATS, regulated return, Air Raid intake, AIH mod., Dp-Tuner F5.
granitefan is offline
Old 01-20-2008, 09:50 PM   #2 (permalink)
AFAIK T/S has not made any new 7.3 programs in quite a while (years). They pretty much stopped 7.3 R&D when the 6.0 came out. Tony is a very good programmer.
"Mekka-lekka-hi, mekka-hiney-ho!"
Ggg6 is offline
Old 01-20-2008, 09:59 PM   #3 (permalink)
I've had pretty good luck with the TS set-up because of the custom tune with my BTS trans. Every once in a while it has some weird gremlins, such as it reverts back to stock setting. It has happened about 4-5 times in about two years. I have not seen any great increases in fuel mileage, but the power is good.
2002 F-250 PSD shortbed supercab, 4R100, BTS transmission w/ 6.0 trans cooler, 285/75R17s Copper STTs, TS chip (stock,high idle,50 tow,80 tow,100,125), tymar intake, diamond eye 4 inch exhaust, isspro boost, pyro, trans temp guages, firestone ride-rite airbags, light cup-holder mod
fatyesno is offline
Old 01-20-2008, 10:53 PM   #4 (permalink)
ROADKILL's Avatar
I love mine. I've had mine for 4or5 years now. I sent it back one time for a update and never been out again for any kind of problem. I think it's the best chip out there for me. If you have a setup close to mine you should get around the same numbers as I have on a dyno. 318hp 748torque. The two things you might need to watch for is the turbo surge that you can get with any chip and stock turbo combo and over boost light. If either of these things happen this is what you will need to do. Again these can happen with any chip! If you get surge, you will need to buy a ATS tuned housing to fix the surge ATS PORTED SHROUD COMPRESSOR HOUSING - ATS6355 and if you get the over boost light you will need this Boost Relief Valve + Sorry if you already knew this but if you didn't I hope it helps. You will never regret it.
99.5 F350 crew cab Power Stroke. BD Dyno 318/748. Sky Jacker 4" easy ride lift, Fox Shocks 35X16.5 BFG AT's and Weld wheels, ATS 4R100 stage4 trans and converter with Commander lockup controller, ATS compressor housing for surge cure. EBP delete fix, Over boost fix, TS 4 position chip 50 75 100 and 140 hp, Hypermax 5" exhaust and three gauge pillar set tranny temp pyro and boost. Extreme Duty air cleaner 8" Kodiak Sidewinder electric steps, 18k Reese signature series hitch Rear 2500lbs air bags with on board air and dash gauge controler. Next mods 6.0 tranny cooler and IC.
ROADKILL is offline
Similar Threads
any feedback on ts 6 position chip rrcolvin1 Upgrades and Aftermarket - 7.3L Engine 16 01-12-2008 11:53 AM
1st tow with chip and guages report. need feedback hobie Upgrades and Aftermarket - 7.3L Engine 17 05-25-2006 12:51 AM
Performance Chip? Any one? billcare Power Strokes 1994-1997 General 0 02-01-2006 08:08 PM
Performance Chip and Performance programs roreri Bio-Diesel and Alternative Fuels 3 05-30-2005 01:54 PM
Performance Chip and Performance programs roreri Upgrades and Aftermarket - General 3 05-28-2005 10:18 AM
