turbo issue - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 02-25-2010, 07:05 PM   #1 (permalink)
turbo issue
I have a 2000 7.3 that only builds 16 pounds of boost? the intercooler boots do not look that bad i had a ford mechanic tell me the waste gate was messed up and it was internal and i could do nothing to fix it! the truck has a bully dog 6 position programmer, air raid intake 4 inch down pipe 5 inch straight out the back, and boost fooler.i have a chance to get a turbo off a 1997 7.3, the guy has the complete engine so i could use all the up pipes and turbo pedistal. my question to you is what do i have to do to adapt this turbo to my truck? Thanks for any advise you could give me.
200fps is offline
Old 02-26-2010, 01:20 PM   #2 (permalink)
LTFFNREMTP's Avatar
Here's your solution to waste gate issues: http://www.dieselsite.com/index.asp?...ROD&ProdID=875
That will allow you to up it to the max of 25 PSI for your stock turbo. Even if boots don't LOOK bad, check all claps, make sure they are tight. Clean around them so that in a few days or a week you can look again for any new residue buildup that might show signs of a leak. No need for a turbo swap like that.
'99 F250 CC-SB 4x4, AFE Stage 2 intake with Pro-Guard 7, Dieselsite coolant filter, DiPricol Full gauges, AIC, On board air + Buell emergency series air horns, Striker turbo timer, Striker I module, Cyclops anti-theft module, TC lockup and 6.0 trans cooler. Powerslot Cryro'd rotors and Hawk LTS pads.
LTFFNREMTP is offline
Old 02-26-2010, 03:26 PM   #3 (permalink)
Feedback Score: 3 reviews
Un plug it and check your boost, you should be able to adjust it.
Your BD maynot be asking for wnough fuel also.
Could also have leaks.
No need to change turbo
Cary
caryt is offline
Old 02-27-2010, 12:35 PM   #4 (permalink)
i will give this a try! thanks guys, i also was looking a little deeper last night and seen some soot leaking at the y pipe on the back of the turbo i am replacing the gasket today!
200fps is offline
Old 02-28-2010, 03:34 AM   #5 (permalink)
how do you adjust the waste gate?
200fps is offline
Old 02-28-2010, 03:38 AM   #6 (permalink)
i looked @ the turbo when it eas on the bench and seen allot of small hair line cracks inside the turbine housung?? there were also a few bolts missing from where the compressor mounts to the turbo?? also there was some sealant all over everything? i think there was an issue with this truck befofe??
200fps is offline
