Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Okay I've been lurking for some time and only recently posting...
part 1 intake: I've pretty much settled on the tymar mod with the wix/napa/donaldson etc setup. Gonna fine the local napa and o-rielly price on the filter and clamps... got a shop in mind for the remnent of 4 inch pipe;
part 2 : exhaust idea - made my post elsewhere on the topic at hand...
part 3 : exhaust upgrade for the international part number as its starting to show a leak in the up pipes. referencing this secondary search i did from a unscheduled *reboot*:
So having found the cool links for the install (bookmarked them) and saved the pdf's...
I shall turn my focus to the turbo itself.
The trucks birth certificate on the door says:
Date 04/98
Vin 1ftsx30f2xea54696
side note: anyone have a secret decoder ring from a crackerjack box to help me understand the vin?
I'm also wanting to know where to look or from where the wisdom flows regarding this *as yet, to me* undiscovered data -- are there different sized turbos (OEM only) from 1999 to 2003 on the 7.3L psd?
IF SO, how does one tell if I've supposedly have a small one? here is one thread that makes me curious: http://www.thedieselstop.com/forums/f25/upgraded-2002-turbo-216714/
here's the info off my turbo:
Garrett
p/n 1825878091
s/n BBL28543
1.10 A/R
IIRC, there was a sticker with another bit of data on it(near the s/n-p/n sticker), do I need to bring it here too?
-i wonder how many electrons were wasted for this space?
Reason: don't like having to use html code just to "<br>" mke it look clear.
You're truck was built before 12/7/98... So that would make it an early 99.
If you are looking for a drop in upgrade then a D66 would be a good unit to purchase. Flows as much air (or more) than stock, and drops right in place of the stock turbo with no modifications.
81/94 FORD F250 PULLING TRUCK 7.3 POWERSTROKE,
525cc HYBRIDS, TWIN S400's, FULL FUEL SYSTEM, GEN3 HPOP, ROLLER ROCKERS, SOLID LIFTERS, UDP CAMSHAFT, AND MORE........
1995 FORD F-250 REGULAR CAB/SHORT BED- FRESH ENGINE, 530 HYBRIDS/EH NOZZLES, GEN3 BIG OIL W/ SWAMPS 20* PUMP, "BIG" TURBO, COMETIC HEAD GASKETS, ARP HEAD AND MAIN STUDS, AEROMOTIVE FUEL SYSTEM, SOUTH BEND DUAL DISC, AFE STAGE 2 AIR FILTER, TANK, FS2500, AND LOTS MORE...........
I guess my geeky *l337 skillz* are rusty. Tht and must be my dyslexic/ADHD brain wasn't clear enough. (sigh)
I was wanting info not a way to throw more then a grand at a as-yet-unanswered-question or two that I guess I should try to rewrite. (heavy sigh)
[paused to RE-READ my first post]...thinks..... nope, I believe I've actually worded the questions as concisely and as minimally verbose as I can.
I guess I'll patiently wait and see when other (just as busy) folks get a chance to slide over to this forum on their spare time during the rest of the week.
(now to go prep the garage for the laundry-list of activities on my "plate")
1. ball joints R&R (within the next 7 days I hope)
2. exhaust leak repair/upfitment (when will this occur? soon...)
3. new front tire for Her SV650s
4. new T-belt kit for the TDI Jetta and check brakes
and that's just my "priority list" LOL
how many of you guy's(& gal's) here look forward to scheduling the annual physical? Yeah and I gotta setup the appt. at the VA hospital (rolls eyes at the joy awaiting me there!)
/end tangent sorry for the babbling we now return you to the normal sound of compression combustion systems, a little soot, and the smeel of Napalm int the morning (smirks)
The trucks birth certificate on the door says: Date 04/98
Garrett p/n 1825878091
s/n BBL28543 1.10 A/R
That is how you tell if you have the little one..... It was built before 12/7/98
That is what makes it the small one.
FWIW, I was just trying to help you, not make you spend over 1000.00
Not much you can do to the early 99's without at least 1000.00 worth of mods, thats all i'm saying
