Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 7.3L Engine
Upgrades and Aftermarket - 7.3L Engine Upgrading and adding aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 08-18-2008, 10:20 PM   #1 (permalink)
Turbomaster Wastegate
Been thinking about giving one of these a try. For some reason my Garrett is only hitting about 32 lbs and I think its bleed off.. Just wondering if those who have the Turbomaster like them and if anyone has one on a Garrett Ball Bearing GTP38R?
Ironhide is online now
Old 08-19-2008, 08:04 AM   #2 (permalink)
My Photos: (5)
Mine is on a stock turbo and it made a definite difference. I like it a lot. Even with stock tuning on, it makes quicker boost.
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, DP Tuner F5 - no start, stock, 40t, 60t, 80e and 80t, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, currently 80,100 miles. truck Pictures
clydesdale is offline
Old 08-19-2008, 03:05 PM   #3 (permalink)
aklim's Avatar
Question. What problem will it solve? AFAIK, it is supposed to solve the problem of boost bleed and a weak spring which holds the wastegate in place. OTOH, I am not sure that the weak spring is really much of an issue, is it?
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, Van Turbo and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 08-19-2008, 04:12 PM   #4 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Not to argue, but my understanding is the OEM wastegate starts opening when boost gets to 7-8 psi and continues opening further until boost peaks at around 17-19 psi in an unchipped truck. The turbomaster as I understand it's operation maintains the wastegate closed until a threshold is reached when it opens. The point at which the wastegate opens with the turbomaster is set much higher and is adjustable.
haul_n_horses2 is offline
Old 08-19-2008, 04:49 PM   #5 (permalink)
aklim's Avatar
I agree. However, what I am trying to accertain is whether it opens because of a weak spring or whether it opens because that is the design. I have used a Boostvalve and to make it simple, no boost got to the wastegate until it got to the preset pressure. For $45 it is a pretty sweet deal. Now, if the wastegate will still move under turbo pressure, the Boostvalve might not help.
aklim is offline
Old 08-19-2008, 05:02 PM   #6 (permalink)
PStroked444's Avatar
I guess it would be mechanical versus computer controle. The pcm will try to give you better fuel milage. The Turbomaster just holds the wastegate shut till enough force opens it. This was my hesitation on the turbomaster. When I am cruising down the road where will my boost be. The stock junk might let the turbo bleed boost off so I can run lower boost at slow speeds or highway. My truck does great for fuel milage just want to keep it there. With my 6-speed it sounds like the Turbomaster would be excelent for me so I can get the turbo spooled up quicker with no open waste gate(at 7-8 psi). Well that is what was running through my head. JMHO
99.5PSD, F250, 4x4, wht. CC, SB, Line-X, 200K+ , 6spd,LUK Ceramic Clutch, Warn Premium hubs, DP Tuner F5 stock/high idle/40T/60T/80E, DIY TYMAR, No EBPV, 08 Diff Cover, 4"MBRP S/S, Banks wheel*traded for stock wheel*, ATS Housing, HXLine, Zoodad Mod, CCV Mod, AIH removed, Shimmed fuel, Isspro Boost Guage & Pyro Guage, 2" Level Kit, Firestone Air Support Springs, BFG AT k/o, CB Galaxy DX949, DUAL Antennas, Lead Foot came stock
1998-F150 4x4, LB, K&N, No Kitty, 24LB inj, CB...Wifes ride.
94 Mustang GT, Red, Black Saleen rims, T-5, intake, exhaust, cam, 24LB squirts, tuned, last of the 302...
PStroked444 is offline
Old 08-19-2008, 05:09 PM   #7 (permalink)
aklim's Avatar
I have used the Boostvalve before and what it does is let the pressure build up till it is enough to overcome the check ball held in place by a spring. At which time, the air moves into the solenoid and opens the wastegate. Pressure drops, the check ball closes the air off and repeats. It does build up the boost way faster in my T3/T4 turbo and I think it would work for ours except it is a lot cheaper. That is why I wondered if the solenoid was being forced open by turbo pressure.
aklim is offline
Old 08-19-2008, 05:16 PM   #8 (permalink)
CSIPSD's Avatar
My Photos: (52)
Yes the factory wastegate rod will be opened by boost pressure alone... The turbomaster works great! I had one on the stocker, the 38r and the TN... I am running the TN one now, just because I never put the turbomaster back on. If you adjust the stock rod you can control it to a certain extent...
Example, when I got the TN BB, I saw a max of about 34-35, I ajusted the WG to the point of locked down and got 50!!! Ajusted it down a bit and it sits at 40-42 now. All this with the factory PCM controls gone.
05/01 F-250 PSD, 125,000 miles, Zoodad, AFE Stage 2, CCV mod, Turbonetics Ball Bearing, Turbo-Master wastegate, Dieselsite's boots, 6.0 IC,Water Injection, AIH delete,ITP Regulator,DP and Wildman tunes,GTS Hybrid injectors, ITP Fuel system,Studs, 910 valve springs,Suncoast 4r100,MBRP T-409 duals,Aeroturbine, 6" tips, 16 Isspro gauge's, 100g fuel tank, 05 mirrors with recon lens, 4" Revtek lift 37-13.50-17 Toyo MT's
ME!
MY PICTURES
CSIPSD is offline
Old 08-19-2008, 08:53 PM   #9 (permalink)
Diezel Dawg's Avatar
Greg, i would adjust the wastegate on your 38R first and see what u get, unless u have already done that
1999.5 Ford F250, PSD, 4x4 OffRoad Package, Lariat, AFE Stage II Air Intake w/ Pro-Guard 7 and DP-Tuner prefilter, Garrett GTP38R BB Turbo, ITP's CCV mod, Dp-Tuner 3 Position chip, MBRP 4" Aluminized Turbo back exhaust w/ 6" stainless tip,
Future mods= Big Oil, Hybrids, ITP Reg Return fuel system w/fuel bowl delete, BTS Transmission, and upgraded chip to DP-Tuner F6, DieselSite Coolant filter
Diezel Dawg is offline
Old 08-19-2008, 08:59 PM   #10 (permalink)
My Photos: (5)
I think the TM is a great addition to a 6spd. My stock setup must have been bleeding off. With the addition of the TM and an exhaust at the same time, the boost builds much faster. I HIGHLY recommend this product. The first one that I got was defective and drove me nuts trying to make it work. I was sent a new one and it bolted up like a charm. Despite the trouble and downtime for the install, I am still very happy with it and would not want to part with it. The biggest difference is with the trailer, I can hold 3rd gear on hills that for the past 6 years I have had to drop to 2nd. I think the key is that it keeps the gate shut the whole time, until you set it to pop open at the desired boost.
Old 08-19-2008, 09:30 PM   #11 (permalink)
aklim's Avatar
So you are saying that if we took out the red hose going to the wastegate solenoid, the wastegate rod will not move? If that is the case, why not use the Boostvalve? For $45, I can control the boost to whatever I want. It will NOT bleed off any boost to open the wastegate till it reaches the preset pressure. Pressure drops, it closes the wastegate.
aklim is offline
Old 08-20-2008, 12:16 AM   #12 (permalink)
Well then I believe the TM would be the better decision. Not saying it is better But I believe the TM is the way to go. I will buy one and find out for myself.
Old 08-20-2008, 12:54 AM   #13 (permalink)
Anyone have before/after MPG #s?
2002 F250 7.3 PSD XLT 4x4 EXT Cab Shortbox - EVO2, AIS w/Zoodad, MBRP 4" 409SS, 08 rear diff cover, Heated tow mirrors w/signals
1988 Mustang GT 9.71 @ 143 (1.43 60ft)
Blk88GT is offline
Old 08-20-2008, 12:57 AM   #14 (permalink)
Layson's Avatar
My Photos: (16)
I just like the idea of being able to adjust it without taking that stupid clip off and twisting the rod.... So much nicer to fine tune the wastegate...
01 F350 CC LB 4x4 SRW,(w/forged rods), 6" Lift, 37"ToyoMT, 22"MKW M19's, Mini Mes, GTP38R, BTS Chip, Spearco, Headstuds, 910 Springs, 4" exhaust, Coolingmist Water Injection, BTS Tranny, 6.0 Trans cooler, 05' Conv. w/ Mirrors, AFE2, Truspeed, Isspro Guages, ORU Diff Covers, Hella 500s, Transfer Tank, ITP Boost fooler, AMP powerstep, Heat Extractor Hood, custom paint, billet badges, Train horns, Recon lights, strobes!
4/8/08 402hp, 824 ft-lbs Mustang Dyno
8/2/08 14.39 in the 1/4 @ 93.5mph on 37's @ 8950 lbs
Custom paint by VeniceAirbrush....
Truck Pics
Old Truck Pics
Myspace Tribute Page
Iraq War Heroes Tribute Page
Layson is offline
Old 08-20-2008, 06:05 AM   #15 (permalink)
aklim's Avatar
I can do that with the Boostvalve too.
aklim is offline
» Site Navigation
» Home
 > FAQ
