turbonetics - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 03-18-2008, 12:53 AM   #1 (permalink)
turbonetics
Should I go with a Turbonetics BB turbo? I was going to get a Garrett but they are all out of stock. I tow both a 7000# and 14000# trailers. 3.73 gears. Up and down hills. I need a turbo to cure surge and last a long time. I have no plan of big oil or injectors, unless something happens to the stockers. Do I need head studs with this turbo?
Its either this or some sort of custom one based on a stocker.
2001 F350, 4x4 off road, 7.3, Auto, CC, LB, 3.73's, 285 BFG AT's, Curtis pop up hitch, 6637 intake, stock downpipe then 1st straight section is 4" with Magnaflow muffler and tail pipe (free), Autometer cubby mount gauges, CB, Sirrius radio
Rick2001 is offline
Old 03-18-2008, 10:47 AM   #2 (permalink)
NorCalDiesel's Avatar
That is a good upgrade option. You will like it much more than a stock upgraded replacement. Both the compressor wheel and turbine wheel are larger than stock and will move more air. Your decision will be what size turbine housing to go with, .84 or 1.00 A/R. You may have lower EGT's with the 1.00, but it may take a second longer to spool up depending on your elevation. But with no chip and a 3 inch DP you may want to stick with the .84 housing. Either way you will eliminate turbo surge with most all aftermarket turbo options available.
My1.00 A/R housing spools like a grandma when my chip is in stock mode
2002 X PSD, Billy Boat 4", AirRaid, Gillett Diesel Service Turbo, High Output turbo exhaust housing, KCM HPX Crossover, ITP Overboost Annihilator, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp
DP-Tuner 6 pos No Start - 140 Aggressive
Thanks Jody and Diane
Super Heavy Duty / Triple Disc 4R100 built by Jim Galatioto at ATO Transmissions in Sacramento.
NorCalDiesel is offline
Old 03-18-2008, 11:30 AM   #3 (permalink)
I guess i need to update the signature.
I have a 40 60 80E DP tuner now
Rick2001 is offline
Old 03-18-2008, 11:58 AM   #4 (permalink)
CSIPSD's Avatar
My Photos: (52)
You will love the Turbonetics Ball Bearing turbo... Get it from BWD and run...
05/01 F-250 PSD,200k,AFE2 ,Modded H2e, 6.0 IC,Water Injection, AIH delete, Swamp tuned, GTS Hybrid injectors, ITP Fuel system, Studs, 910 valve springs, Suncoast 4r100,MBRP Duals, 6" tips, 17 Isspro Performax gauge's, 100g fuel tank, 05 mirrors with recon lens, 4" Revtek lift 37-13.50-17 Toyo MT's
CSIPSD is offline
Old 03-18-2008, 07:59 PM   #5 (permalink)
Well I ordered a Turbonetics BB from BWD. It should be here and on in a couple of days. I'll let you know what I think!
Rick2001 is offline
Old 03-19-2008, 12:57 PM   #6 (permalink)
bbunting's Avatar
That turbo tows really well.
My truck BEST ET: 12.89 MPH: 109.24 Pictures
bbunting is offline
Old 03-19-2008, 09:41 PM   #7 (permalink)
Just got my Turbonetics BB turbo in the mail this week. I'll report back this weekend after I install and let you know how it runs...
2002 F-250 PSD shortbed supercab, 4R100, BTS transmission w/ 6.0 trans cooler, 285/75R17s Copper STTs, TS chip (stock,high idle,50 tow,80 tow,100,125), tymar intake, diamond eye 4 inch exhaust, isspro boost, pyro, trans temp guages, firestone ride-rite airbags, light cup-holder mod
fatyesno is offline
Old 03-19-2008, 11:58 PM   #8 (permalink)
stick with the TN for towing like that, won't have to be as concerned with keeping the RPMs up to avoid surge.
2002 F250
DarkShadowDiesel is offline
Old 03-24-2008, 09:19 AM   #9 (permalink)
Well it has arrived. So all I have to do is install it. I have everything apart. But I decided to get new up pipes for it. Have to treavel for work so sher has to sit a couple more days unless I can get some time off tonight.
Rick2001 is offline
