Unbelievable Results - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-04-2009, 12:47 AM   #1 (permalink)
I just got finished the best two hour mod I've done on my truck . I have located a International dealer who ordered me the correct cps . This one was differerent than fords . This requires a .0020 air gap with provided shims (cant recall exactly) I also went ahead and did the powerstrokehelp.com banjo fitting and fuel bowl mods . Holly snikes ( i hope with this language my post wont get deleted ) and by golly she ran like a scolded dog . It was quieter , shifted much smoother , and best of all FASTER !!!! I would highly recomend this mod . Please let me know if I may be of any assistance
John
01 4x4 off road . mods to include : fluidamper , big bad wolf turbo w/ banks down pipe mod, 5" pipe to areo resinator muffler , upgraded jasper trans , propane injection , oil cross overs , inline map relife valve , boost fooler , aih delete , pulley kit , flex lite fan , ccv mod , multiple Dfuser sensor eliminators and 18k injector control, custom 4" intake w/ 1200 cfm filter , quadzilla monitor , edge 100 hp programer w/ BD program , cryo slotted rotors w/ hawk pads , 07 header and lights , Lincon style grill , alien patrol bumper (owner is p.o.s.) , 6" super lift , 37" desert grapplers , 20' m.k.w. rims , just bought 6.0 intercooler , airdog 130/75 and ts 6 bank with dfuser programing
johnthepracticalbuilder is offline
Old 11-04-2009, 11:49 AM   #2 (permalink)
Can you post the PN from IH for the CPS. I have had three different CPS in my truck at one time or another and none ever came with a shim. The Blue IH CPS will retard the timing which does make the engine quieter but the tradeoff is also a slight reduction in power.
This was documented a few years ago when someone ran some comparisons using a Dyno. It should be in the archives, somewhere.
Can you also explain the Banjo Mod?
2OOO F-250 4WD Crew Cab, 248,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator H2O Pump. AIS Severe Duty Filter, Switched 10K MOD, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Optima Redtops,Mesa, Arizona
PRDATR is offline
Old 11-04-2009, 03:25 PM   #3 (permalink)
I purchased a cps from international, it was the black one (part#99) everybody raves about, it didn't have any shims and i didn't see a noticeable difference.
tinkerr is offline
