upgrade intercooler ? ? ? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 10-16-2009, 09:18 PM   #1 (permalink)
I have a 2000 p/s and was about to do the 6.0 intercooler in 7.3 mod. My question,now,after doing some measuring,is it really going to help. If my figures are correct,there is 1065 cu.in.in the 7.3 and 1216 cu.in. in the 6.0 intercooler. Is this small difference of 152 cu.in. going to make any difference in the cooling of the air from the turbo?
I was going to do this mod based on replies on other forums as an inexpensive way of additional cooling. Really confused, now.
Thanks for your replies.
2000 Ford,Lariet,F350,P/S,auto,3.93l/s.diff,longbed,4in.exhaust(turbo back),dash mount gauges(boost,tranny temp,exhaust temp(pre-turbo),Amsoil 15w/40 syn.oil with dual-bypass filter,in-line trannyfilter,coolant filter, 6.0.tranny cooler,20k Reese 5er hitch,mods( ccv,203deg.thermo,pre-tank,in-tank,aih,un-do Ford cackle-fix(replace LL8,reprogram pcm) ,wicked-wheel, EPBV gut,reg.fuel return,pressure set 62psi.,hpx kit,dptuner 5position.chip,modified air intake w/Donaldson B085011 air cleaner,tranny rebuilt (JohnWood ).
ronchyhiker is offline
Old 10-18-2009, 12:41 AM   #2 (permalink)
Send a message via Yahoo to escs36
if your egt's are running consistantly at max temp, then the cooler will help. 50* is about the difference you will see. that can be big deal while pulling trailers in the hills. i personally spent the big money and got an after market. i bought the diesel innovations. why gamble? pulling warped exhaust manifolds is not a fun job, i speak from experience.
Early Bird Super Duty 230,000 miles, Swamps 200/30%, Beans D66, Adrenaline HPOP, ITP Regulated Return, John Wood Stage 1, DP Tuning, IDM Mod, Diesel Innovations Intercooler, 4" Turbo Back w/MBRP muffler, etc...
escs36 is offline
Old 11-02-2009, 10:30 PM   #3 (permalink)
Banned
I think it made a significant difference in EGTs on mine. I cannot get it over about 1250 on the longest hard mountain pull. Most times it wont get over 1100. It made a noticeable difference in acceleration....
Alabamatoy is offline
Old 11-06-2009, 03:32 PM   #4 (permalink)
6.0 Intercooler In 7.3
This a follow-up on your reply, on what I posted,in regard to 6.0 intercooler in a 7.3. Can you get me the measurement of the 6.0 intercooler you used? I bought a used one and the core is narrower, by4in.than the 7.3 but it is higher and thicker. Is there more than one type? I am trying to figure out if it is worth the effort of exchanging them.
Thanks for your reply
Old 11-06-2009, 03:40 PM   #5 (permalink)
6.0 intercooler dimensions
Anyone that has done the "6.0 intercooler in a 7.3 mod",please send me the core dimensions of the 6.0 intercooler. I would really appreciate it.
Thanks a bunch
Old 11-06-2009, 04:19 PM   #6 (permalink)
I've always heard you're really not going to see much of a difference unless you do a lot of towing. If youre just driving it, its really not worth the time and money.
Jourdan
2011 F250 King Ranch FX4, 6.7L with all the options
SOLD: 2002 F250 Lariat 4x4, 7.3L
DIY Intake, Zoodad, 4 inch exhaust turbo to tip, DP Tuner F5 (no start, stock, high idle, 60hp tow, 80hp econo, 120 hp race), Isspro Gauges: egt, boost, tranny (thank you girlfriend!:hail), Dieselsite Coolant Filter, AIH Delete, HPX Line, in-tank & pre-pump mods, FPR shimmed to 70 psi, Hawk Brake Pads and Powerslot Rotors, Dieselsite WW, Rhino Bedliner, 285/75 Goodyear Wrangler Silent Armors, Trailer Tow Mirrors, Bilstein Shocks, 203* T-Stat, Dieselsite Billet T-Stat Housing, Door Seal Mod, Fumoto Oil Drain Valve, Passport 9500i hardwired in w/ smartcord, A toolbox full of goodies and a few other things here and there:sly
TXF-250 is offline
Old 11-07-2009, 09:13 PM   #7 (permalink)
I pull a 15k 5er, in mountains of Colo,AZ MT at elevations of 3500 to 10000 ft.,
so I really have to watch the EGTs I can hit temps of 1250deg very easily
Thanks for the reply
Old 11-07-2009, 10:38 PM   #8 (permalink)
I haven't done the swap so I can't give any actual numbers. I can tell you that cubic inches of CAC volume is not what you need to consider. A 12"x12"x12" CAC would have a lot of volume but would not be very efficient. The surface area is important, height is better than width, and the front half of a CAC is more efficient than the back half (a 2" core will not cool twice as well as a 1" core).
444-4D is online now
Old 11-09-2009, 02:41 PM   #9 (permalink)
Thanks for the reply.So what is the big deal.The 7.3 is 30in.wide X18in.high=540sq.in. the 6.0 is 25.75in. wide X 21in. high=540.75. The only difference is thickness of .25in.
Is there something I am missing?
Old 11-09-2009, 06:48 PM   #10 (permalink)
Maybe, have you noticed that the radiator core on a 7.3 radiator is wider than the distance between the tanks on a 6.0 CAC?
Old 11-09-2009, 10:54 PM   #11 (permalink)
Thanks.The 7.3 is about 4in. wider than the 6.0. My question is, will the 6.0 cool better,it is narrower but higher and thicker than the 7.3.(maybe because the core tubing is shorter,but more of them,it will flow more air.) The truck is used,mostly towing.
Please, your comments. Thanks
Old 11-10-2009, 11:19 AM   #12 (permalink)
More tubes is good. I would be surprised if it doesn't cool a little better. Towing heavy, I wouldn't install one without having a real coolant temp gauge. I would want to see if it had an effect on the coolant temp.
Are you drawing intake air from the engine compartment? If yes, you can lower temps by changing that.
After that there is different tuning.
And regardless of your combination, you need RPM's to stay cool.
Old 11-10-2009, 09:51 PM   #13 (permalink)
Thanks for all the replies.It has made a difference in my thinking.
Thanks,again
Old 11-12-2009, 06:58 AM   #14 (permalink)
Without the CCV mod I have wondered if just cleaning the intercooler would help. Probably a lot of oil in there. How hard would it be to pull it out and clean with a good degrreaser and water?
2003 7.3 F250 SD SRW Auto DIY intake 285/70 1.5" Leveling Kit TS Performance 75 HP Chip
TTBadDog is offline
Old 11-12-2009, 12:53 PM   #15 (permalink)
I think its a pretty involved process to get that thing out of there and clean it up. You have to essentially flush it and then let it sit all day to make sure it gets good and dry.
Seems like I remember someone saying you have to use a prybar to get it out? Id be itnerested to see if people have done it and how hard it is
Jourdan
TXF-250 is offline
