USED 6.0 trans. cooler in 7.3 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-18-2009, 11:28 PM   #1 (permalink)
Any thoughts on using a used tranny cooler? Is it safe to use? How can it be cleaned? I tried on Ebay,and new are going for over $200.00. A used one is a lot less. Thanks a bunch for your replies
2000 Ford,Lariet,F350,P/S,auto,3.93l/s.diff,longbed,4in.exhaust(turbo back),dash mount gauges(boost,tranny temp,exhaust temp(pre-turbo),Amsoil 15w/40 syn.oil with dual-bypass filter,in-line trannyfilter,coolant filter, 6.0.tranny cooler,20k Reese 5er hitch,mods( ccv,203deg.thermo,pre-tank,in-tank,aih,un-do Ford cackle-fix(replace LL8,reprogram pcm) ,wicked-wheel, EPBV gut,reg.fuel return,pressure set 62psi.,hpx kit,dptuner 5position.chip,modified air intake w/Donaldson B085011 air cleaner,tranny rebuilt (JohnWood ).
ronchyhiker is offline
Old 11-19-2009, 02:40 AM   #2 (permalink)
Powerstrokin400's Avatar
My Photos: (18)
A 6.0 tranny cooler is just a fancy radiator. If undamaged, should be good if all cleaned out. You'll need the adapter fittings too. I see you've done business with John Wood, me too. Great guy. Give him a call. (760) 356-9421 or jwtt.com or johnwoodautomotive.com. He'll tell ya for sure. Very Smart dude.
2003 F250 XLT 7.3L, Auto, FX4, Crew Cab, Long Bed, 6.5" Pro-Comp all spring lift & Firestone HD Rear Air Bags, BFG KM2 37x12.50x17 tires on Eagle 17x10 Rims, 4" Turbo Back Exhaust & muffler delete, Bully Dog Programmer @ 120 Hp setting ALWAYS, Machined & Bellowed International Up-Pipe Kit, Autometer Overhead Gauges (Boost, Pyrometer, Trans. Temp), Custom Pre-Filter Ram-Air with K&N filter, "John Wood" Custom Stage I Transmission, 6.0 Billet 3 Disk T/C, External T/C Lock-up switch, 6.0 Trans Cooler, Hughes Racing Deep Structural Pan, and a few more goodies. Now spinnin' AAM Rear & Dana Spicer Front 4.30:1 Gears with Warn Premium Locking Hubs.......I do a lot of towing.(13,000 lb 33' Toyhauler & 21' Ski Boat). 84,568 miles as of 11/09
So. Cal. Fireman
IAFF Local 2342
Other Rides:
2006 BMW 330i Sport
1992 Camaro RS 5.0L, 25th Anniversary
1990 Mustang LX 5.0 Sport, 5spd., 25th Anniversary
Powerstrokin400 is offline
Old 11-19-2009, 08:35 AM   #3 (permalink)
dlblazer's Avatar
I wouldn't use a used cooler. A trans rebuild is too much to cheap out on the cooler. I would be surprise if JW does't say the same thing. I am also surprised he didn' advise you on a cooler when you had the trans rebuilt.
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter (no more), Superchips 1705 tuner, Reese Titan, AIS, IPT pre-pump filter kit, in-tank mods, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
dlblazer is offline
Old 11-19-2009, 12:37 PM   #4 (permalink)
Feedback Score: 3 reviews
Never ever use a unknown used cooler!!!!
Cary
caryt is offline
Old 11-19-2009, 12:54 PM   #5 (permalink)
SmokeyWren's Avatar
My Photos: (44)
No.
It can't.
Ford requires that the oil-to-air (OTA) tranny cooler be replaced with a new one any time a Ford tech works on a tranny. Unscrupulus folks at some unscrupulus dealerships take the old coolers out of the trash heap and sell them on e-bay. But the used coolers are usually full of junk that can't be cleaned out, but will slowly work its way out and ruin your tranny.
It's a lot less until it costs you a new tranny. Then it gets really expensive.
SmokeyWren is offline
Old 11-19-2009, 03:02 PM   #6 (permalink)
aklim's Avatar
Would you take a used rubber and wear it for sex? Same thing with O-rings and trans coolers.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 11-19-2009, 03:12 PM   #7 (permalink)
I would use one if I knew it's history and that history was satisfactory. I wouldn't use one if it had anything in it other than dirty oil. Berryman B-12 and compressed air or detergent and hot water work well for cleaning dirty oil.
444-4D is offline
Old 11-19-2009, 04:46 PM   #8 (permalink)
bryrylan's Avatar
My Photos: (11)
f)))ing awsome to find this out after I just put a used one from a freind in......
2002 F-250 3.5" leveling kit, 305-70-16 Procomp AT's,Eagle alloys 16" rims,Autometer procomp trans boost pyro gages, AIS, Coolat filter ELC, TS 6POS chip, Banks Billet torque converter, Transgo tugger shift kit, galaxy CB pumpin 20watts, Sirius radio,Kenwood cd player, kenwood door speakers, Infinity tweeters, 500 watt Pioneer amp, 10" Pioneer sub, Panelite LEDs, Custom back rack with LED lights, Bores guide poles, SHO-ME led warning lights, 4" exhaust, Grandrock 5" stack kit with bullhauler stacks,MBRP y pipe cover, 9Ft Fisher plow. Timbren SES
1995 30ft 14K Gooseneck flatbed.
10K winch
All LED lights
bryrylan is offline
Old 11-19-2009, 04:51 PM   #9 (permalink)
aklim's Avatar
Generally I wonder why you are selling it used. Now if the donor truck was totaled out and hit in the front, well..... If it was hit in the rear, probably might be ok. Usually, like it was mentioned, the tech is supposed to dispose of the trans if the install a new unit. Well, if the tech flushes it out and sells it as a used unit, do you believe that Ford wouldn't have had the tech do that and save warranty if they thought it was safe?
aklim is offline
Old 11-19-2009, 05:03 PM   #10 (permalink)
bryrylan's Avatar
My Photos: (11)
Kid switched it to a 6spd the auto still shifted fine and worked fine he just wanted a stick and found a whole truck that was totaled for cheep so he made the swap. and I bought the cooler
10K winch
All LED lights
bryrylan is offline
Old 11-19-2009, 05:22 PM   #11 (permalink)
aklim's Avatar
Fair enough. Probably ok then. IMO
aklim is offline
Old 11-19-2009, 05:30 PM   #12 (permalink)
bryrylan's Avatar
My Photos: (11)
I drained it and blew it out with compressed air for what its worth.....
10K winch
All LED lights
bryrylan is offline
Old 11-19-2009, 05:39 PM   #13 (permalink)
aklim's Avatar
Like I said, if it comes out of a wasted trans, no thanx. Keep it. If it comes out of a known good working trans, a flush probably would suffice.
aklim is offline
Old 11-19-2009, 05:43 PM   #14 (permalink)
bryrylan's Avatar
My Photos: (11)
yeah i hope so I just spend 2300 on a new bed I cant afford a trans rebuild right now lol
10K winch
All LED lights
bryrylan is offline
Old 11-19-2009, 07:38 PM   #15 (permalink)
I sure thank you,all,for the replies.I guess I'll just have to bite the bullet and save up.I don't want to have the tranny rebuildt again.
Thanks again
