Used DP tuner F5 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-19-2009, 04:40 PM   #1 (permalink)
bryrylan's Avatar
My Photos: (11)
Used DP tuner F5
What would you pay for a used F5 with the following tunes.
1. Stock
2. 40 tow
3. 60 tow
4. 4 wheel drive low exhaust brake
5. regular exhaust brake.
6. 80 hp economy tune.
2002 F-250 3.5" leveling kit, 305-70-16 Procomp AT's,Eagle alloys 16" rims,Autometer procomp trans boost pyro gages, AIS, Coolat filter ELC, TS 6POS chip, Banks Billet torque converter, Transgo tugger shift kit, galaxy CB pumpin 20watts, Sirius radio,Kenwood cd player, kenwood door speakers, Infinity tweeters, 500 watt Pioneer amp, 10" Pioneer sub, Panelite LEDs, Custom back rack with LED lights, Bores guide poles, SHO-ME led warning lights, 4" exhaust, Grandrock 5" stack kit with bullhauler stacks,MBRP y pipe cover, 9Ft Fisher plow. Timbren SES
1995 30ft 14K Gooseneck flatbed.
10K winch
All LED lights
bryrylan is offline
Old 11-19-2009, 04:42 PM   #2 (permalink)
bryrylan's Avatar
My Photos: (11)
PS besides 4 low these are the tunes I want. what would this cost new I'm having trouble understanding Dps site.
10K winch
All LED lights
bryrylan is offline
Old 11-19-2009, 04:53 PM   #3 (permalink)
BadDogPSD's Avatar
Used F5's seem to go for $200-300 with 4-5 tunes loaded including the switcher & switcher mount. If buying used, you need to make sure that the chip was tuned for your PCM code. If not, DP will need to reburn. Not sure how much that would cost, but I think it's less than what you'd pay for new tunes. If you were to buy that chip new, it would be about $425, plus $40 for the switcher, and $15-25 for the switcher mount.
Best bet would be to call DP and talk to Diane or Jody so you'd know exactly what you'd need to do to make the chip the way you want it for your truck.
1997 F250 4x4 Crew Cab PSD; Modded H2E, FFD Stage 2's, CPR Fuel, SRP1, ARP studs, Comp 910's, DI pushrods, Dana 60; Sky RSK w/SD springs.
BadDogPSD is offline
Old 11-19-2009, 11:30 PM   #4 (permalink)
westvandude's Avatar
As mentioned, the tuner chip board itself has a price, then each tune has a cost, and finally the switcher that mounts on your dash has a price. Add up each piece, all the tunes and that's the cost.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, Adrian Tavano's triple disc converter, transgo tugger HD2, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler & tru-cool trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, clear corners & tails, silverstar bulbs, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, 2x Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck, 12.5" flipdown video.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. Custom fiberglass hifonics 12" sub & 280w usacoustics amp. Tint is next.
westvandude is offline
Old 11-20-2009, 03:21 PM   #5 (permalink)
When Jody burns a chip, there are several questions asked.Your pcm code,gear ratio,any modes done,tire size,speedo calibration.Everything is taken into concideration so chances are even if it is the same pcm code unless both trucks were completely stock you will still have to have it reburned.
2000 F350 srw pickup
3 in. leveling kit,35x12.5x16.5 BFG's,K&N air filter,4 in. exhaust from turbo back,Bully Dog boost,trans temp and exhaust temp gauges,Painless wiring inline module,Western Diesel four position chip(currently out being repaired),203 thermostat,Bully Dog shift kit.
greasemonkeyf350 is offline
Old 11-20-2009, 05:21 PM   #6 (permalink)
bryrylan's Avatar
My Photos: (11)
It came out of a 2002 with an intake and exhaust I'm going to email about the tires.
10K winch
All LED lights
bryrylan is offline
Old 11-21-2009, 10:51 AM   #7 (permalink)
Just a thought...unless you find a DP-Tuner that is made specifically for your PCM you've gotta figure that its gonna cost you $50 to have DP set it up for your PCM, plus $25 for each tune you want switched over, plus about $20 in back and forth shipping. At least that's how I understand their pricing (?). So if its not for your PCM you gotta figure in all of the costs. With their 10% Holiday off sale and free shipping I'd go with a new one these days UNLESS you find one made for your PCM, etc. Also, buying new, you get free updates I believe. Just something to consider.
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, custom bed carpet/bench inserts, Rhino grill guard, Bugshield, mud flaps, CCV Mod, AIS w/foam sleeve, Fuel filler mod, GOS headlight harness, Hella 80/100s, 02-04 Headlights, Rancho HD steering stabilizer, C-Btr Mirrors, Hella FF1000, Sonnax/Tricumulator, Htr Bypass valve, 31 row 6.0 tranny cooler,front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DTRS and BPP kill switches, DIY "pitstop" switch.
http://community.webshots.com/user/l...host=community
losfinch is offline
