want up fitter switch - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-19-2009, 12:41 PM   #1 (permalink)
hugestroke's Avatar
if you could get your hands on a set up up fitters out of a wrecked truck with the harness could you make them work on a 2001 truck. i am not really worried about cutting into the dash for a mount just about the wiring.
2000 f 250 7.3 liter auto. Started as a xlt truck has been up graded to a lariat. 8 inch fabetek lift. 20 inch eagle alloys painted black. 41/14.50/20 super swamper irocks.05 head lights with 10,000k hid's. Turbo back 4 inch into two 6 inch stacks under bumper. edge juice with attitude. k&n cold air. ready for dp and ingectors.
hugestroke is offline
Old 11-19-2009, 03:50 PM   #2 (permalink)
Yes. I want to do the same. Had looked into purchasing the switches and lower dash from powerstrokeshop.com, just haven't done it. I think I have the instructions saved on my computer at home. Shoot me a pm and when I get home tomorrow night I'll get it to you.
2006 KR, CC, LB, 4x4, 6.0 moonroof, power rear slider, dual alternators, Pop-Up gooseneck ball, DR leveling kit, 60000 miles, 285/75/18 Toyo ATs
12/98, CC, XLT, LB, 4x4, 7.3, 6sp, '06 front end, 4" front springs, Bilsteins, DiPricol Pyro,Boost and Fuel Gauges, 35" Toyo, SouthBend Con-O, 185,000 miles, 4" exhaust, Performance Friction rotors and pads, DP F5 chip, RedHead steering box
BWD Turbonetics .84 Quickspool Turbo/Spearco
EBPV Deleted
Dieselsite BRV+, Intercooler boots
Banks Tubes
Terminator
ITP Reg. Return, Intank, and Delete
2008 Hudson 7 ton GN
2002 JCB 212s
2004 A300 Bobcat
barnbuilder is offline
Old 11-19-2009, 05:34 PM   #3 (permalink)
My Photos: (19)
The cutting and mounting is what most worry about. It's usually the only issue. Wiring them up can be done relatively easily. Go for it!
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline
Old 11-20-2009, 03:25 PM   #4 (permalink)
There is a member on here that put them in the map pocket and just had to make a little filler panel to take up what the switches didn't cover.As for wiring there is one main power wire that plugs into the fuse box so that is all you have to deal with.You could tap into the ignition switch harness with a fusible link if you had to.
2000 F350 srw pickup
3 in. leveling kit,35x12.5x16.5 BFG's,K&N air filter,4 in. exhaust from turbo back,Bully Dog boost,trans temp and exhaust temp gauges,Painless wiring inline module,Western Diesel four position chip(currently out being repaired),203 thermostat,Bully Dog shift kit.
greasemonkeyf350 is offline
Old 11-20-2009, 03:36 PM   #5 (permalink)
hugestroke's Avatar
thanks the map pocket was were i was going to put it.
