Wanting to change from Mercon to Synthetic trans fluid... - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 03-01-2005, 10:40 PM   #1 (permalink)
I am wanting to change the fluid in my tranny from Mercon over to Royal Purple. Any suggestions as to how I go about it? Does the entire system need to be drained first? Or do I just change it as specified through another post that I read? (draining into a bucket throught the rear transmission/cooler line) Thanks in advance!
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
CaliEx is offline
Old 03-01-2005, 11:08 PM   #2 (permalink)
Re: Wanting to change from Mercon to Synthetic trans fluid...
Just follow the procedure outlined in the FAQ (the one you saw) using synthetic (any synthetic that is Mercon/Dexron rated). I did this very same procedure after installing the Sonnax/Tricum kit.
http://community.webshots.com/user/roadfrog
Cheers,
Chris
FOR SALE! 2002 F350 CC 4x4 SB Lariat Blue & Silver, General AT2 295/75/16's on 16x8 Panther Rims, KYB Monomax Shocks, Euro Style Tail Lights, billet fuel door, Putco chrome handles, Autometer Z Gauges & Pillar Pod, Billet Grill, Bullbar, JVC KD-AR870 head unit, Sirius, MEI Reference Series 600 Watt amp with 6.5" Alpine DD Drive F17C components front, 6.5" Jensen components in rear, Better Built truck box, auxiliary backup lamps, acetoned badges, blacked out lower weld seams, Dodge auto-dimming rearview mirror, Avital alarm system, heater by-pass mod, in-tank, harpoon and pre-pump mods, 5" SS exhaust tip.
2002 Acura el (only available in Canada)
2002 Fleetwood Wilderness 31G
1988 Campion Allante, 19.5' w/ Merc 5.7 litre
Roadfrog is offline
Old 03-01-2005, 11:37 PM   #3 (permalink)
Wow... OK, I will try it! I thought that doing it this way would just "mix" the two different fluids together, and didn't think that it would work well since I am wanting to go from "dino" fluid to synthetic! But I guess that is what I get for thinking!
Thanks!
CaliEx is offline
Old 03-02-2005, 10:44 AM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Click here for the "how to".
Using those procedures, there will be very little mixing going on. There will be a little bit, but that's why you use 20 quarts of new ATF instead of the almost-18 quarts the system holds.
After you drain the pan (or use the option to pump the pan dry), there will be only a few drops of ATF left in the pan. So you're not mixing the ATF in the pan.
Think of the rest of the system as a garden hose. You push ATF into one end of the hose, and that forces the old ATF out the other end. Where the new and old ATF meets inside the hose, there will be a little mixing - expecially in the torque converter where the garden hose expands to a bigger size. But the extra two quarts of ATF you use for the job will push that mixed ATF out the end of the garden hose by the time you get done.
SmokeyWren is offline
