Waste Gate - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 02-28-2010, 11:10 PM   #1 (permalink)
Troy250's Avatar
My Photos: (5)
Waste Gate
Has anyone tried the turbomaster wastegate controller? Is it worth the $$?
Black 99.5 SC,4x4,auto, superchips tuner,4"turbo back exhaust,DIY 6637 filter,sonax valve and Tricumulator springs. Carbon Fiber Boost, Exhaust and Trans temp with pillar. Added factory fog lamps, 03 headlights, heated telescoping mirrors.
Troy250 is offline
Old 03-01-2010, 09:32 AM   #2 (permalink)
honeydew's Avatar
Take a read through this thread:
7.3L Turbo Master Wastegate Controller anyone have input?
2001 F250 4X4 CC Lariat, fuelly; modifications: Ford AIS w/ cool_canuck mod & fender sleeve, 4" turbo-back, mechanical wastegate controller set to 24 psi, dp tuner F5 (60e, 80e, 1200 idle, 120r) all with codes option, trans temp, EGT and boost gauges, max cold valve, dieselsite boots and oil crossover line, 203 t-stat, coolant filter, Riffraff FrX, ITP hutch setup & pre-pump filter, Warn premium hublocks, Red-Head steering gear box, Scangauge II, LED glowplug indicator light.
removed: charge pipe foil, Air Intake Heater (AIH), engine cover & bracket
honeydew is offline
Old 03-02-2010, 07:33 PM   #3 (permalink)
anyone know if the turbomaster waste gate works on the banks turbo exhaust housing?
flguy1215 is offline
