Re: Wastegate Acuator
By a Banks Hig Head Actuator for about $220 straight from Banks. They give complete instructions on how to install including preload.
I believe it said to line up the rod with the center of the pin, then tighten 6 more turns. This a little subjective, a mine turned out to have a little to much boost and turned on the SES light. No biggy, just add another turn and test.
Note: I did have to fill the end hole of the rod with an insert, becuase my pin was smaller than their hole. I also had to grind down on side of the rod, as it was thicker than the stock one. [img]/ubbthreads/images/graemlins/sleepy.gif[/img]
2000 F250SD 4x4 CC LB SRW, 7.3L, 4" SS Exhaust, K&N Intake Filter, "A" pilar guages, Autometer Trans Temp, EGT, Boost, Amsoil through out, Amsoil 2 stage filter system, Mag-Hytec trans pan & dif cover, Banks Big Head Waste Gate, FactoryTech Valve Body, 315 BFG KOs & Yes I made the 315 spare fit, Rancho 9000 shocks, Tru-Cool Max trans cooler, Aux/BU Lights, T/C lock. Next: Fuel System Mods, Max A/C mod.
1975 TLC 2F, H42, 4.88 gears, Power Steering, Shackle Revearsal, Next: SOA, Rear Disc Brake mods
A Scouter Forever.
