Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 7.3L Engine
Upgrades and Aftermarket - 7.3L Engine Upgrading and adding aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 09-21-2009, 10:27 AM   #1 (permalink)
Water / Meth injection
What is the true story on these kits? I have people telling me that they are great and you will make more power. On the other hand I have people telling me that they will hurt things. What is the best kit out there and who sells them?
1999 F350 XLT DRW CC auto 373 gears 4x4.
cold air intake
4" strait SS exhaust
ATS housing
W Wheel
Turbo Timer
manual waste gate
boost pop off
dual tranmission cooler
no exhaust valve
tripple phantom gauges
dieselsite 6 position chip
oil cross over line
transmission valve body
Billit Torque converter
crowhater is offline
Old 09-21-2009, 10:59 AM   #2 (permalink)
thuglike's Avatar
Cooling Mist is the best kit I've seen by far. I picked mine up from KT Performance. Running straight water won't hurt anything as long as it's set up right. I set my 2 stage to come on at 15 and 30lbs of boost. It's prob. the safest injection mod you can do. Problems start when you add meth to the formula. 30% meth is safe, you can run that all year long without fear of freezing or blowing up your motor. After you get over 50% meth/ water ratio....that's when you need to be careful. Meth is a fuel and by adding it to your engine yo add timing. You'll need to adjust your tunes for it. You are totally safe runnin' straight water or up to 40% meth. Go off of boost to engauge your stage(s) and your motor will live a long happy life.
'00 F-250 X-cab 4x4: Powered by DI PERFORMANCE
Best run to Date: Spring Fling-633/1075- ALL FUEL/ 12.21 @ 110.45 Diesel Nationals (all fuel)
thuglike is offline
Old 09-21-2009, 11:06 AM   #3 (permalink)
I hear you just add windsheild washer fluid and go.
cold air intake
ATS housing
W Wheel
Turbo Timer
manual waste gate
boost pop off
no exhaust valve
oil cross over line
Old 09-30-2009, 11:58 AM   #4 (permalink)
Stay away from Snow Performance. I have replaced the pump once and had to use two solenoid valves (also replaced) to keep the tank from flooding the motor with water. They will not even discount replacement pumps that go out for no reason.
2001 F250 Lariat, Super Cab, Shorty, 4x4, Harvest Gold, 7.3PSD, BTS Auto, 373 Posi, Tow & Camper Pkg, Heated Bun Warmers, 6 Disk With Kicker, Alpine, & Kenwood, TTM, Isspro EV, Gutted EBV, BB turbo, LED's, ARE Topper, Oilguard Bypass Filter, Coolant Filter, Tymar Intake, DP Chip, (Kim Lux's Lousy Injectors-GONE), Mini Me's, Water Injection, BWD Spearco 6.0 Intercooler, DP 6 position chip, live Tuning, DI FASS System, And A Few Other Toys. Factory Installed Knock. (PMT3) More To Come:
460/950 Corrected Prior To Water Injection and Spearco IC.
13.974 @ 95.65mph on PMR's
2008 Cummins Truck Fest 4WD Diesel Champion
'07 Duramax Classic, Leather, Sunroof, Bone Stock.
DZacc is offline
