What Chip/tuner should i get? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-15-2009, 10:31 PM   #1 (permalink)
Im getting a 2001 f350 7.3 6 speed manual and i want to chip it get an intake and exhaust what do anyone think would be the best setup? mainly wondering about the chip
Thanks shawn
1994 F-350 7.3 turbo diesel Vin K 4x4 Reg cab long bed 5-Speed 4 inch lift and 35's
94forddiesel is offline
Old 11-16-2009, 09:41 AM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Depends on how often you plan to change tunes.If you'll normally change tunes only when you tie onto a heavy trailer or turn loose of that trailer, then you'll probably like a programmer. The advantage of a programmer is any idiot can use it to change tunes, and there is no install work required. The disadvantage of a programmer is it requires a coupla minutes to change tunes every time you want to change tunes. And with most programmers you are limited to three different tunes.
A chip is a lot more complicated to install. It plugs into the main computer (PCM) after you meticulously clean the electronic contacts in the PCM and on the chip. Then you have a tune switcher that you must install, and that requires electrical/electronics wiring. The advantage of the chip is you can have a lot more tunes to choose from, and you can change tunes instantly with a good tune switcher.
The same tunes are available for either a programmer or a chip. However some "tunes" are practical only with a chip. The decel (exhaust brake) tune can be active only when coming down the mountain. So you have to switch it at the top of the pass, then switch back to your towing tune at the bottom of the pass. Also there are several "high idle" tunes available, but you have to switch back to a normal tune before you can move out.
The most popular tuner right now is Jody Tipton at
DP-Tuner
I have his economy and towing tunes flashed into my Edge Evolution programmer. Good stuff. I usually leave mine in 60-tow all the time. It's a great towing tune for towing an 8,000 pound trailer, and is also good when not towing. I would switch to 80-economy only if I was going on a long trip unloaded.
SmokeyWren is offline
Old 11-16-2009, 05:58 PM   #3 (permalink)
RIStroker2000's Avatar
Send a message via AIM to RIStroker2000
DP Tuner!!!
2000 7.3 Extended Cab Long Bed Lariat.... Van turbo (1.15ex.), Casserly stage 1's, DP tuned [()], IH uppies, 07 grille & lights, dieselsite boots, autometer gauges, 6637, walker BTM, CCV Mod, Oil X over, ITP boost anialator, Foil Delete, Add a leaf HD rear springs, leveled, 285 Nitto's, 200 gal. spray tank, 8' Fisher plow winged, 2.5 yard sander.
(waiting for reasonable answers on reasonable questions)
1999 Maxima- 3.5 swap turbo. runs low 12's 1/4 mile
2008 Subaru Legacy (STI swapped)
RIStroker2000 is offline
Old 11-16-2009, 06:27 PM   #4 (permalink)
Matt0987's Avatar
I have an 03 Ex w/ 7.3. I have the TS Performance 6 bank chip in it. I did get it a number of years ago so I have not had a need to keep up on the most recent advances. That being said, I am pleased with it. I installed the switch where it easily reached to the left of the steering column on the lower part of the dash. When I need the extra boost I just turn the switch to the next setting. It has a OEM setting - an OEM setting w/ high idle - then additional settings w/ additional horse power and transmission adjustments. Works nice.
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
Matt0987 is offline
Old 11-16-2009, 11:09 PM   #5 (permalink)
woodnthings8's Avatar
Put in an EGT gauge at a minimum, boost is nice and will help you verify the trucks condition and keep an eye on fuel economy once you learn the gauges.
I will give a vote for DP-Tuner!!
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 11-17-2009, 05:21 PM   #6 (permalink)
94ford diesel... Definately gauges like said above.. Chips are personal.. but i dont think theres much better (cost/cust. service/'happibility'') with DP tuner...
Old 11-17-2009, 07:45 PM   #7 (permalink)
Yes gauges will be first and thank you for your imput if i tow it will be a car trailer or a snowmobile trailer.
Old 11-18-2009, 09:45 PM   #8 (permalink)
psdfanplus's Avatar
DP Tunes
I chose the F-6 chip w/stock, 1200 rpm, 1200 rpm w/EBV, 40T, 60T, 60E, and 80E. The 1200 rpm is perfect for extended idle with AC running, the 40T dramatically improves towing with our 15k 5th wheel, 60E is the best for running empty. The chip and electronic switch work flawlessly, and there are no codes to mess with. Very good hardware and tunes!
Early 99 (10/98), CC, Dually, LB, Access Cover, ZF 6 w/LUK twin friction disk clutch, 20K Reese Hitch, Ford AIS, Auto Meter Gauges, MagnFlow 3.5 DP w/4inch exhaust, Banks Big Head Wastegate Actuator, MagHytec on Dana 80, Timbrens, DP F6 (No Start, 1200 rpm, 1200 rpm/w EBV, Decel, 40T, 60T, 80T, 60E, & 80E) , 36 foot triple slide 5th wheel (15K), 335K
psdfanplus is offline
Old 11-18-2009, 11:20 PM   #9 (permalink)
scaldwell5863's Avatar
Thanks for the DP tuner link... don't want to do any chip mods just yet, since truck has over 368K on her right now... brand new E40D, and also looking at getting another engine dropped in around 1-2yrs from now
scaldwell5863 is offline
