What cold air intake should i buy - Diesel Forum - TheDieselStop.com
post #1 of 44 (permalink) Old 03-26-2008, 11:51 AM Thread Starter
Larry H's Avatar
I have a 2002 7.3 F 350 4x4 crew cab dually. I want to put a good cold air intake on it. What is the best or which one are good thanks for the help
Larry H is offline
post #2 of 44 (permalink) Old 03-26-2008, 12:17 PM
bnvcrows's Avatar
Amsoil Air filter
I have posted this before. Amsoil air filter is cleanable with air and it service life is 100k or 4 years.
One picture is with out the pre-filter
Bill
Name:	Compressed New Air with Pre-filter finished EaAU4091.jpg
ID:	894   Click image for larger version
Name:	Compressed Air box Mod 009.jpg
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
SLAPS Member
Edge with Attitude & Bush Fender Flairs
Amsoil 3000 5w 30, Amsoil EaAU Air Filter, Amsoil Dual Remote By-pass BMK-16A,At 38,000 miles on oil Had to change I went long enough still was ok to run.
Amsoil ATF Transmission & Transfer case, Amsoil 75w-140 fluid front & rear end , Amsoils Antifreeze, Transmission Magnefine filter, 4" Turbo Back Exhaust
Sportman Tonneau Cover
bnvcrows is offline
post #3 of 44 (permalink) Old 03-26-2008, 12:26 PM
AFE Stage II
2002 F250 CC 4x4 Lariat (SRW),
20" KMC Monsters,
37" Toyo M/T's
8" Full Spring Skyjacker
4in Turbo Back (no muffler)
Some kind of programmer/chip?,
RanchHand Frt/Rear,
AFE Stage 2 intake,
Banks Intercooler Pipes,
DieselSite Boots
New tranny(30K),
Banks TransCommand,
Mag Hytec Tranny Pan & Diff Cover,
Quad A-pillar(ISSPRO trans,boost,pyro,water)
About to be DynaTrac'd
My heart belongs to the Mustang and Windsor Motor, so you;ll have to forgive me until I get up to speed with thesee diesels
Steve_USMC is offline
post #4 of 44 (permalink) Old 03-26-2008, 12:28 PM
SmokeyWren's Avatar
My Photos: (45)
Originally Posted by Larry H View Post
What is the best ...
a
Depends on how you use the truck.
If it is a typical towing machine with a mild hot rodding or a stock engine, then best is the Ford Air Induction system (AIS). You can get it from Powerstrokeshop.com - PSD and Ford Superduty Parts for a hair over $200.
If your truck is a race-winning hot rod, or will be, then you want the aFe Stage II with ProGuard7 filter. About $500 from most sponsors of ThedieselStop, including Mark Craig at Diesel Performance Parts - Home .
SmokeyWren is offline
post #5 of 44 (permalink) Old 03-26-2008, 02:39 PM
bigblockbill's Avatar
Originally Posted by SmokeyWren View Post
a
If it is a typical towing machine with a mild hot rodding or a stock engine, then best is the Ford Air Induction system (AIS). You can get it from www.powerstrokeparts.com for a hair over $200.
Exactly...I could not say it any better
2008 F350, Crew Cab, FX4, SRW,
job 3, Long Bed.
bigblockbill is offline
post #6 of 44 (permalink) Old 03-26-2008, 03:13 PM
I believe you mean Powerstrokeshop.com - PSD and Ford Superduty Parts
My AIS arrived today
2002 F250 7.3 PSD XLT 4x4 EXT Cab Shortbox - EVO2, AIS w/Zoodad, MBRP 4" 409SS, 08 rear diff cover, 6.0 Trans cooler, Heated tow mirrors w/signals
1988 Mustang GT 9.71 @ 143 (1.43 60ft)
2008 H+H 24' CL series V Nose Car Hauler
Blk88GT is offline
post #7 of 44 (permalink) Old 03-26-2008, 04:25 PM
SmokeyWren's Avatar
My Photos: (45)
Originally Posted by Blk88GT View Post
I believe you mean Powerstrokeshop.com - ...
I believe you're right.
The only thing worse than getting old is the alternative.
post #8 of 44 (permalink) Old 03-26-2008, 06:40 PM
fyrehose's Avatar
a
How much HP can an AIS handle. The reason I ask is because I have one with the fender sleeve and zoodad. But every time I go WOT, it sucks the filter minder down to 50%. Is the filter minder a good gauge to go off of? How do I know if the AIS is flowing enough?? I am at about 340 RWHP. BTW, I am using the filter minder off of the stock box.
2001 F250 CC 4X4, 4" lift on 35's
Swamps 250/30%
DP Tuner
Stealth Stage I
JW Trans
38R
PMR's
9.2 @73mph 1/8 mile
fyrehose is offline
post #9 of 44 (permalink) Old 03-26-2008, 06:46 PM
03griz's Avatar
try removing the snorkel temporarily and see if the minder is pulling down. If it is then maybe it is too restrictive. Or maybe the filter is dirty.....................
2002 F250 S/C Lariat 4x4 7.3L, Automatic, Autometer Guages, AIS w/canuck cut, Walker BTM, AIS, DP tuner, 6.0 liter cooler.
Yes it's fast
No you can't drive it......
03griz is offline
post #10 of 44 (permalink) Old 03-26-2008, 07:04 PM
dondiesel444's Avatar
DIY Tymar, less than $50 and does the same thing all the others do
2001 F-250 PSD Crew Cab short bed, 4x4 Lariet, only 97k miles bone stock for now
previous trucks:
2001 F-250 PSD CC SWB 4" lift, 315's, DP Tuner..
late '99 F-350 PSD CC LWB 4" lift, 315's, DP......
early '99 F-250 PSD SC SWB short shifted 6-speed, 5" stacks, 5.5" lift, 4.30 gears, DP Tuner, etc....
1997 F-350 PSD 4x4, 4" lift, 35's, Superchips tuner
dondiesel444 is offline
post #11 of 44 (permalink) Old 03-26-2008, 07:18 PM
bnvcrows's Avatar
I was having the same thing happen with both mods thats why i made my own and I installed the filter minder to make sure I did fix the problem. That problem has been solved. Here is a the link
Bill
Bill
SLAPS Member
bnvcrows is offline
post #12 of 44 (permalink) Old 03-26-2008, 08:13 PM
haul_n_horses2's Avatar
My Photos: (17)
That fancy and pricey AFE Stage II drops the temp at the manifold by a whopping 8 when motoring down the road. Is that worth the difference between that and the Tymar (DIY or real tymar)?
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #13 of 44 (permalink) Old 03-27-2008, 12:46 AM
fyrehose's Avatar
Has anyone put an S&B intake on. It is supposed to be just as good as AFE II with the pg-7.
S&B Filters
Swamps 250/30%
DP Tuner
Stealth Stage I
JW Trans
38R
PMR's
9.2 @73mph 1/8 mile
fyrehose is offline
post #14 of 44 (permalink) Old 03-27-2008, 02:37 PM
OK Now you all have me worried. Are the K&N's that bad? I have a FIPK kit on my 02 and was wondering how bad is this thing really hurting my PSD. Let me ask this - Can I keep the intake kit and replace the filter with a AMsoil? I looked and they have a replacment element for the K&N that is used.
Thoughts?
Shawn Zeller
02 F250 Crew, 4X4 Off Road, 3.73, Edge Juice w/ Attitude
K&N Generation 2 Performance Air Intake
02psdcrew is offline
post #15 of 44 (permalink) Old 03-27-2008, 02:56 PM
Feedback Score: 3 reviews
I think the best value around is the new S&B intake kit with the grill snorkel. It flows 50% better than the stock unit and still has a 99.47% efficiency rating. Here is a link with more info.
Performance Truck Products LLC - Diesel and Gas Performance Parts and Accessories
DSTRBD is offline
