What is involved with installing a guage package? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 01-23-2009, 02:03 PM   #1 (permalink)
I've been toying with the idea of installing a pillar mounted three guage package (boost, pyro & trans. temp) on my truck. I drive a 99.5 7.3L psd with a manual trans. What is involved with installing these guages? I don't know how they tie into the system. If you purchase a gauge package, does it include the sensors or simply the gauges and mounts? I would also appreciate anybody's insight as to what packages are good and what to stay away from. I'd like to hear from the guys who have done this before and get some insight. I have looked around for a link on an install and as of yet haven't come accross one. Whats a man got to do for three gauges?
Chilli is offline
Old 01-23-2009, 02:45 PM   #2 (permalink)
aklim's Avatar
http://www.itpdiesel.com/store.php/products/DIY_2_Gauge_Kit
You don't need trans gauges for a manual.
It is pretty straightforward. I would do the AIH mod and put a nipple in for the boost gauge and drill a hole in the exhaust manifold for the EGT. It is all there on the website. http://www.itpdiesel.com/other/7.3L%...structions.pdf
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 01-23-2009, 07:33 PM   #3 (permalink)
Motoman's Avatar
Here's a write up I did when I installed mine....... just take your time and do it right the first time and you will love the result!
Motoman's Madness
Motoman is offline
Old 01-24-2009, 12:26 PM   #4 (permalink)
Motoman - from your pics, Kids are good for something. Pic 005
Chilli,
As posted, you probably dont need a tranny gauge.
As for the rest, a good set will come with all the sensors. I believe you can get a 2 gauge set or 3 gauge set. They are pretty easy once you figure out what needs to be done.
I used the instructions from DieselManor and they were perfect.
http://www.dieselmanor.com/installsheets.asp
They suggest pre-turbo for the pyro which is what I did and wanted.
The tranny (automtic) was the easiest as it only has 1 wire from the sending unit. You might swap the tranny temp for a oil pressure. That would be my choice if I wanted 3 gauges.
The Turbo boost has 1 plastic tube. I drilled/tapped into the 'Y' piece in the center rear. I took the hose to the hardware store and matched the fittings to the drill/tap used for the pyro sending unit. Saved me about $20.00. See picture. You can use the plastic T and hose clamps, but I didnt want any additional places to leak.
You need 1 wire from the light turn on common to all gauges. I pulled the light switch box out at drivers left knee - just stick a screwdriver under bottom center and it pops out. I used either the bottom right or top right (dont remember) - check with test light whichever turns on with lights are on. I use a female wire tap connector - the type that 1 side folds over the wire and slices thru the insulation to contact the wire. I dont usually like these, but I only needed 1 into the factory wiring.
I did cheat on one issue. The tranny gauge required 1 wire for the light and an additional turn by key switch. I used the light turn on just to avoid running another wire. When I am concerned with my tranny temp I am usually towing. When I am towing I always have my lights on anyway...no problem.
There is a 4" knockout (foam and fiberboard) in the firewall where the clutch arm passes. Yours is used with a stick. Not sure what you will need to do here but it was easy with the automatic.
I connected all the light turn ons for the gauges while it was out. I put the mating T connector to the wire tap connector on the ends of all the necessary wires. I used the main turn on wire like a manifold with matching wiretap connector about every 4" where each gauge wires would be.
The rest was just a matter of connecting and pushing the wires and gauges into place. It all went quite easy.
Contact me if you would like more assistance.
Bruce
Bruce & Carolyn Wittmeier
2001 Ford F250 PSD, Ext cab, Shortbed, Island Blue/Silver, 4X4 Off-road, SOF Auto, Alum Wheels, DP-Tuner 40/80/120HP, Chrome Step, Line-X bedliner, Jordan Ultima 2020, AirLift 5000 Airbags, DiPricol gauges
wittmeba is offline
Old 01-24-2009, 12:34 PM   #5 (permalink)
aklim's Avatar
Why did you tap the manifold when you could have removed the AIH and tapped the plug?
aklim is offline
Old 01-24-2009, 06:16 PM   #6 (permalink)
My first response is I didnt want to remove anything to install something else.
Secondly, it came right out of the DieselManor instructions which worked flawlessly.
3-Gauge Install Pictures
wittmeba is offline
