Where to purchase Ford AIS Intake? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 01-14-2010, 11:18 AM   #1 (permalink)
^ title. I have done a bit of searching using the 'search button' but most of the sites I get directed to says they are completely out of stock.
Anyone know a current source to pick one up at? Would the dealership not have them in stock either?
PMDf250 is offline   Reply With Quote
Old 01-14-2010, 11:48 AM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Have you tried PowerStrokeshop? No mention of them being out of stock, but maybe call them to be sure:
Your Premiere Source for Ford Truck Parts and Accessories
Also Dfuser has them on their website with no mention of being out of stock.
DFUSER Diesel Intake
then scroll down until you see the AIS.
Large Ford dealers may not have them in stock but they can get them within one or two days from the nearest Ford zone warehouse. My itty bitty Ford dealer had one in stock, and he beat the PowerStrokeShop price, so I'm a happy camper.
SmokeyWren is offline   Reply With Quote
Old 01-14-2010, 12:02 PM   #3 (permalink)
TousleyParts's Avatar
I can sell one to you at a good price. Sorry, I do not have one in stock. They have been on backorder for awhile. Ford tells us they expect to be off backorder around the first or second week of Feb.
There are still a couple I can pick up around here
PM me if interested
We are Autonation Ford of White Bear Lake selling all OEM Ford parts 10% over dealer cost (formally Tousley)
Please PM me for any price requests
Call us at 1-800-328-9552 OR check out our website www.tousleyfordparts.com Be sure to mention this website for the good discount.
TousleyParts is offline   Reply With Quote
Old 01-14-2010, 04:50 PM   #4 (permalink)
Thank you both for your quick responses.
I decided on that first link you sent me for 198.00.
I contacted my local Ford dealership and they said it would be 295.00 so I decided .
This will be my first ever install. Wish me luck
Old 01-14-2010, 08:39 PM   #5 (permalink)
JimmyDee's Avatar
My Photos: (24)
No luck needed. It an easy install.
Jim
2001, F250 4x4, CC, Auto; Mobil 1 in transfer case&Trans.; Frantz Bypass Filter; "Hutch" fuel mods; Sonnax/Tricum mod; 4" Exhaust, 30" MagnaFlow; Attitude in A-Pillar and tranny gauge in Dash; AIS; EASE Diagnostics; Reese Slider Hitch; Fr Rotors, Cryo Treated&Slotted by ART.
JimmyDee is offline   Reply With Quote
Old 01-15-2010, 08:52 AM   #6 (permalink)
What year truck is it for? If its an e99 also need another intake hose.
2006 KR, CC, LB, 4x4, 6.0 moonroof, power rear slider, dual alternators, Pop-Up gooseneck ball, DR leveling kit, 70000 miles, 285/75/18 Toyo ATs
12/98, CC, XLT, LB, 4x4, 7.3, 6sp, '06 front end, 4" front springs, Bilsteins, DiPricol Pyro,Boost and Fuel Gauges, 35" Toyo, SouthBend Con-O, 197,000 miles, 4" exhaust, Performance Friction rotors and pads, DP F5 chip, RedHead steering box
BWD Turbonetics .84 Quickspool Turbo/Spearco
EBPV Deleted
Dieselsite BRV+, Intercooler boots
Banks Tubes
Terminator
ITP Reg. Return, Intank, and Delete
2008 Hudson 7 ton GN
2002 JCB 212s
2004 A300 Bobcat
barnbuilder is offline   Reply With Quote
Old 01-15-2010, 07:03 PM   #7 (permalink)
psdfanplus's Avatar
Ais
I purchased my AIS from Diesel Power Products w/foam sleeve.
Ford AIS Severe Duty Intake System 98.5-03 7.3L Powerstroke FA-1759
Early 99 (10/98), CC, Dually, LB, Access Cover, ZF 6 w/LUK twin friction disk clutch, 20K Reese Hitch, Ford AIS, Auto Meter Gauges, MagnFlow 3.5 DP w/4inch exhaust, Banks Big Head Wastegate Actuator, MagHytec on Dana 80, Timbrens, DP F6 (No Start, 1200 rpm, 1200 rpm/w EBV, Decel, 40T, 60T, 80T, 60E, & 80E) , 36 foot triple slide 5th wheel (15K), 355K
psdfanplus is offline   Reply With Quote
Old 01-15-2010, 09:15 PM   #8 (permalink)
How do I check on whether it's newer/later 99?
Old 01-15-2010, 09:56 PM   #9 (permalink)
bigb's Avatar
where does the foam sleeve go and what does it do?
Brian, Tucson, Arizona
02 F350 4x4 CREW 7.3 140K, AIS, Isspro pyro, boost & tranny temp pillar pod, Dipricol coolant temp, Isspro EV-2 Fuel Pressure & HPOP, Dieselsite boots, coolant & tranny filters & 203* Stat, 6.0 Tranny Cooler, ITP pre pump tank mod, Bellowed Up Pipes, Riffraff Frx, netbook mount with AE, GPR LED, Stancor, Red Head steering gear, Battery Tender & 2 Marincos.
bigb is offline   Reply With Quote
Old 01-15-2010, 11:21 PM   #10 (permalink)
RDG
RDG's Avatar
My Photos: (16)
It reduces air restriction.
Ford 7.3L Powerstroke AIS Intake Foam Fender Sleeve
TheDieselStop.com Moderator
99.5 F-250 CC SRW
TDS Member since 12.18.99 # 4366
NRA Member
Retired UAW 383
RDG is offline   Reply With Quote
Old 01-16-2010, 05:26 AM   #11 (permalink)
psdfanplus's Avatar
My truck is an early 99. The original factory intake drew air from a hole in the inner fender well. The AIS uses a snorkel and draws air through the grill, the foam sleeve uses an additional hole cut in the AIS w/foam sleeve to draw air through the inner fender well. This setup provides two sources of air, snorkel and inner fender well.
Old 01-16-2010, 09:03 AM   #12 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Tousley Ford Parts Depot has the best price I've seen on the internet. They are a new sponsor of TheDieselStop and apparently are going to be a price leader when it comes to Ford parts. They responded in a post above. Did you notice it?
Old 01-16-2010, 11:25 AM   #13 (permalink)
Just sent that rep a PM about it actually.
Thanks for all the help guys.
Old 01-16-2010, 12:12 PM   #14 (permalink)
If anyone has an early 99 OE intake system they want to get rid of, send a PM to me.
444-4D is online now   Reply With Quote
Old 12-23-2012, 12:50 AM   #15 (permalink)
AIS
Im considering the AIS system for my 2002 excursion 4x4 7.3 diesel w/ 136,000 miles on it. Currently its stock intake/filter. How much and whats the extra foam sleeve about?
How much?
Jmylesmc is offline   Reply With Quote
