Who has BEST aftermarket turbo for 7.3? - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 07-15-2005, 06:37 PM Thread Starter
Is it worth the money? can the factory one be modified?
samfrank is offline
post #2 of 16 (permalink) Old 07-15-2005, 06:49 PM
Re: Who has BEST aftermarket turbo for 7.3?
what do you plan in doin... adding injectors or a HPOP that can all vary for what kind of fuel you have or are going to add.
LBZ
5" MBRP
EFI Live
Searching for 5 bills
bldr018 is offline
post #3 of 16 (permalink) Old 07-15-2005, 08:14 PM
It all depends on what you are going to do. You need to sit down and figure out how far you are going to go for power. Then you pick the turbo for the mods you do.
Wayne B
2000 F-250 XLT PSD 4X4 ESOF Auto, SC, LB, Gauges, Mag-HyTech Trans Pan & Rear End Cover, <font color="red"> (((XM))) Inside</font>, ATV Racks w/ Two Kawasaki Prairie 400 4X4's sitting on them, 25' Rockwood TT. Ashburn, Va. Member # 103
Wayne B is offline
post #4 of 16 (permalink) Old 07-16-2005, 01:41 PM Thread Starter
right now my truck runs 9.40's in 1/8th mile.....i want to run 8.60's
samfrank is offline
post #5 of 16 (permalink) Old 07-16-2005, 02:54 PM
Like they said. You can add a huge lung to it, but if you don't have the fuel to spin it there is no point. Tell us what mods you have or are planning on doing??
~Lovin
04' F-350, Crew Cab, King Ranch, Dually, LOADED.. DPPI Turbo Back, gauges,SCT from kermit, air raid, coolant filter, amsoil bypass
CAN YOU KEEP UP
06' ZX-6R
Dad's rides...
99' 7.3L F-350 Custom flatbed, supercab, dually
96' 7.3L F-250
99' Expedition 5.4L
99' Contour
2 T300 bobcat
6 custom built trailers
03' BMW 330Ci
soccerstud19 is offline
post #6 of 16 (permalink) Old 07-16-2005, 04:24 PM Thread Starter
only mods i have are ...120hp jody flash/ 4 inch bullydog exhaust/ and ram air kit.....thats it...my truck runs 9.40's and my buddy has the same exact thing onhis 6.0 but he is running 8.70's
samfrank is offline
post #7 of 16 (permalink) Old 07-16-2005, 04:27 PM
get you some injectors, size that is good for stock HPOP, and the new turbo and could possibly be at that time
LBZ
5" MBRP
EFI Live
bldr018 is offline
post #8 of 16 (permalink) Old 07-16-2005, 04:30 PM
also what year is ur truck the reason why i am askin is b/c what rods u have. if you have an early one with forger you are safe, but if you have pmr's u are SOL! You are gonna need to change those and add head studs before you window your block!
LBZ
5" MBRP
EFI Live
bldr018 is offline
post #9 of 16 (permalink) Old 07-16-2005, 04:50 PM
i know there is a way to check t osee if you have forged or PMRs, but is there a way to tell by year? Ive got a 2001 PSD and was wondering which i more likely had.
73PSD is offline
post #10 of 16 (permalink) Old 07-16-2005, 06:03 PM
Send a message via AIM to Bobcat698
More than likely you have PMRs... But there are SOME 2001 trucks out there that made it out of the factory with Forged rods.
I would check to make sure.
PURE DIESEL POWER
TS Performance chips, SCT, Edge Products, AFE, Superchips, Diablo, Autometer & Dipricol Gauges, Turbo Air Guides, MBRP & Magnaflow Exhaust, Aeroturbine, ATS, Hypertech, Steroid & 18K modules, South Bend Clutches & more!
Get STACKED with a 4,5,6, or 7 Inch STACK kit!
Call us for your exhaust pipe needs!
Superior Customer Service, FAST Shipping!
Garrett Shields
OWNER
715-254-1833
Bobcat698 is offline
post #11 of 16 (permalink) Old 07-16-2005, 07:02 PM Thread Starter
its a 2003....crew cab...4X4....what are my chances getting away without RODS? I never really pull anyhting, just play around with it 1 a week.
samfrank is offline
post #12 of 16 (permalink) Old 07-16-2005, 07:15 PM
Well if you want your truck to run 8.60 in the 1/8 that is pretty darn fast so you will have to have fuel...injectors, fuel supply, programming, etc and then you will need plenty of air to burn that fuel and then you will need a tranny to transfer that power to the rears to move that truck to a 8.6. So..this could be some good hp and may be putting you in the danger zone for PMRs. I would say you are looking at at least 440-475 hp needed to run 8.6 in the 1/8 mile with a good launch which would put you in the mid 13's in 1/4 mile. I am fairly confident that 400 hp or under will not get you an 8.6 in the 1/8 mile and anything over 400 hp on PMRs is considered dangerous for those rods. I may be off with that guesstimation so take it for what it is worth [img]/ubbthreads/images/graemlins/smirk.gif[/img]
Good Luck with whatever you choose
99.5 F250 SD Lariat SuperCab PSD LB 4x4
Hybrids
Bean's Modified H2E
DP-Tuner
BTS Tranny
DI Fuel System
ITP Regulated return
AirDog
FS2500 Oil Bypass
Full Engine rebuild- cryoed, ceramic coated, shot peened, blah, blah, blah
(on stock tranny/upgraded TC and .0065" nozzles)
Dunbars Dyno, 1.04 CF
jat99 is offline
post #13 of 16 (permalink) Old 07-16-2005, 07:22 PM
Since everyone else is avoiding the question here goes. Your best choice is a Garrett ball bearing turbo. You have to decide if it is worth it to you. You should be able to buy one for about $1450. You can modify the stock one for less but it will not be as good.
444-4D is offline
post #14 of 16 (permalink) Old 07-16-2005, 07:38 PM Thread Starter
so what would you guys do? i already have 120hp Dp-turner, 4 ich bullydog exhaust, ram air kit, i need honest suggestions!!..how much power or ET will i pick up with turbo...is it worth it? or should i have mine modded?
samfrank is offline
post #15 of 16 (permalink) Old 07-16-2005, 07:56 PM
My honest answer is "I don't know"
If you change your compressor housing, compressor wheel, turbine housing, and balance your turbo you could easily spend $1000. You will still not have the ball bearing rotating assy or the 88mm compressor wheel.
444-4D is offline
