Who makes the best transmission? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Closed Thread
Old 10-03-2008, 04:22 AM   #1 (permalink)
415_dezl's Avatar
GET THE POPCORN OUT! this is gonna be good! LOL
2002 F350 Lariat CC SRW 4x4 LB , Shadow Gray, Edge 4.5" w/ dual bilsteins up front/ Toyo Open Country M/T 315-75-16. Stock Motor 7.3, dual alts / 3 guage pillar pod, Auto Meter/ 5" turbo back magnaflow exhaust w/Aeroturbine muffler & 6" Jardine tip/ Husky 24k 5th wheel / Air Lift Bags.
John Wood Transmission / DP tuner / 08' rear diff cover
2005 40' Weekend Warrior 5er, SLC 3905
1977 Tahiti 21' / Berkeley Jet Daycruiser/ 455 Olds.
2000 Sandcars Unlimited / Turbo VW 2275
1988 Ford Thunderbird Turbocoupe 2.3
415_dezl is offline
Old 10-03-2008, 06:58 AM   #2 (permalink)
JimTJr's Avatar
My Photos: (20)
JW or BTS I would say, (I Love BTS,, but I am a bit Biased)
Shouldn't need allot of popcorn,, probably only going to be two main competitors, BTS and JW,, Pappy will chime in with his "Sunny Coast" Transmissions I imagine, (Nothing against those either,) never dealt with anyone but BTS on the 4R100. AND I LIKELY WON'T EITHER!
BTS RULES!!
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 10-03-2008, 07:32 AM   #3 (permalink)
415_dezl's Avatar
I know, i started this thread as a result of the last one. I do, though, like to hear my 35" mud tires chirp when hittin fourth gear on the freeway. (thanks to the dp tuner)
415_dezl is offline
Old 10-03-2008, 08:38 AM   #4 (permalink)
Has Anny one tried a ATS? are they good anything bad about them?
2000 F250 extended cab XLT, 6 inch lift, 315/75/16 BFG TKO, cold air intake, 6 inch stacks, TDP custom chip, 230cc injectors with 200% nozzles, garret ball bearing turbo, FASS system,20* swamps oil pump,traction bars,custom built 4r100, 3 gauge pillar and gauge kit and a whole lot of the giggly juice
00Allonthe line is offline
Old 10-03-2008, 11:09 AM   #5 (permalink)
IMO if the trans has a suncoast kit or a set of alto red clutches and kolene steels with the correct valve body upgrades and a good billet torque converter completed by a GOOD REPUTABLE trans rebuild facility or technician it is as good as it will get for a 4R100/E40D ( but the key is they need to have lots of experience in trans modifications with sucess ) I know JW , BTS , And ATS are all good but a good local rebuilder "should be able" to give the same results as them
1996 F350 2WD DRW CC Black STG1 160 CC INJECTORS , D66 TURBO FROM BEANS ,3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM ,DIY TYMAR AIR FILTER , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
6.0l SD INTERCOOLER MOD WITH NEW CUSTOM MODDED TANKS AND AEM WATER METH KIT TO HELP LOWER EGT'S ON HILLS , E40D HIGHLY MODDED
2009 FORD F 150 FX4 S /CREW LOADED (BLACK)
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline
Old 10-03-2008, 12:29 PM   #6 (permalink)
FionaThe02PSD's Avatar
My Photos: (12)
One vote for JW. Had one in my 02 and holy crap Batman, that trans was flawless..
2006 Dark Slate F350 CC LB 6X6 Lariat Tow Boss Complete with training wheels.
Vegetarian, an old indian word for bad hunter!
K&N Intake, Coolant filter, Recon smoked LED litght: tail, Clearance, Center bumper, 3rd brake, Fat fender, Pressure pro TPMS, Firestone air bags, Alpine/Infinity/Polk sound system, Autometer Phantom EGT,Trans,Boost gauges above the rearview mirror.
For the BEST in performance parts and accessories ITP Diesel
Arizona Powerstroke Group
FionaThe02PSD is offline
Old 10-04-2008, 12:51 AM   #7 (permalink)
415_dezl's Avatar
i second that. Imagine if we didn't have the internet..we'd have to actually get our trans's done at normal shops! I'm glad that JW is starting to hold it down on this site..it's been very one sided for a long time in here
415_dezl is offline
Old 10-04-2008, 06:53 AM   #8 (permalink)
Send a message via ICQ to coldair
bts bts bts
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission FASS and ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:30s ARB air lockers front and Dana80 rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
OneUp ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
coldair is offline
Old 10-04-2008, 07:04 AM   #9 (permalink)
JimTJr's Avatar
My Photos: (20)
"DR" IT will NOT happen, no way, no how. Just the kits won't get it to the level BRIAN does, (Or JW either I think) Both machine new parts for the internals, Clutch housing and several others. To MUCH Tighter tolerances than stock.
Brian asks only one thing for you NOT to do. (Other than common sense stuff, neutral drops, ect...) He asks that you do NOT go from reverse to drive without coming to a complete stop. (How most of us back out of the drive, still rolling ever so slightly backwards, and drop it in "D") HE said his are so much tighter, there is no "SLACK" for any of the parts and he would rather you didn't do it. (Have I? Sure, it's a HARD habbit to break) Would he fix it if it breaks from that,, I have every confidence he would. (Oh, and my trans is now going on something like 6 yrs old.....) In it's second truck!
YOU FIND A LOCAL SHOP who will stand behind their product, after you move it from one vehicle to another, and it's almost 4 yrs out of their "WARRANTY" if you want to call it that.. his is not a "WARRANTY" his is confidence in his product!
With a "Handshake" Better than ANY piece of paper.
JimTJr is offline
Old 10-04-2008, 11:40 AM   #10 (permalink)
The "best" is BTS hands down, and no need for popcorn. JW builds a good unit, and has many happy customers. ATS, avoid at all costs! ATS has many completely DISsatisfied customers. How about a tough question, and we can get out the popcorn. Yeah, and what Jim said!
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95 Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
HighwayPrisoner is offline
Old 10-05-2008, 09:02 AM   #11 (permalink)
415_dezl's Avatar
Oh geez, hands down? We all are fans of our trans builders. the "best" in your eyes may be the BTS, but in mine..i've seen special parts that go into a JW, that he builds IN-HOUSE, that i think made a superior product. He doesn't have many happy customers..he has tons of them..most of them hard working farm trucks..with owners who don't come on the internet. Not only that, he goes to Glamis and knows the So cal clientele and their specific needs. The majority of the towing i do is within an hour of his shop. (colorado river and Glamis).
No one is ever going to win this debate, but i'm just trying to get the word out there that in this great nation of ours, there is more than one trans builder worth going to. My truck sat in my garage for a couple of months with a broken tranny until i made my decision. Honestly, I saved a lot of money with the shipping hassle, and did not want to trust some shop out here with the install. YES< i could have done it myself but just did not want to deal with the hassle.
Hey, at least we can agree that the 6.0 coolers work good! Not only that, JW is someone i could go drink beer with, has dyno events at his shop, and you can pull up your RV there and party it up!
415_dezl is offline
Old 10-05-2008, 05:51 PM   #12 (permalink)
Hey guys,
I am here in Vegas this week for bike week, I pulled my 44' enclosed trailer with 10 fully dressed Harleys out here from North carolina and Tennessee, I am in my 2002 F350 and the transmission is on its way out, started getting hot and seal leaking, keep adding fluid, but now with trailer on it it overheats to the point of "CHECK GAUGES" light comes (275 degrees) on within 5 minutes, but with trailer off, it doesnt over heat, Question is this, I wanted to use BTS since I am based out of Tenn., but I just picked up this truck 3 weeks ago, and wasnt ready to have to do it yet, and im now on the west coast,
Does Brian have installers on the west coast? or Where in SoCal is this "JW" some of you are talking about??? Going to try and drive it into SoCal this Tuesday (no trailer) but need to find a good west company, or I will just leave it at the house in SoCal and come back out next month and resuce it and put it on a trailer and tow it back to Arkansas to BTS.
Thanks for any help and info in advance.
2003 BLACK Excursion Limited 7.3 4x4 w/DVD entertainment center, rear captians chairs, 3.73 limited slip. 4" MBRB Stainless Exhaust, AFE stage II intake, DP F5 Tuner, 4.5" Donahue lift, Rolling on 18" Jesse James Lawless 8's wrapped by 35" Toyo Open Country Mud Terains and airbags, Prodigy brake controller.
2002 BLUE F350 XLT 7.3 4x4 Crew Cab short box, BTS Tranny, 6.0 tranny cooler, 4" Silverline Stainless exhaust, S&B intake, DP F6 Tuner with 9 tunes. Line X, B&W turnover ball, Prodigy brake controller.
1968 Chevy C-10 Short Bed PRO-STREET 500+CI BBC
1991 Honda CRX-SI (Black Also)
2002 John Deere Gator Diesel 6X6
2003 Limited edition Cannondale Cannibal- With colors that woulnt run, RED, WHITE and BLUE #0000016
Owner and Dad of Godspeed MX racing. #269
1BADF350 is offline
Old 10-06-2008, 11:44 AM   #13 (permalink)
what kind of issues are the ATS transmissions having?
Old 10-06-2008, 01:50 PM   #14 (permalink)
Originally Posted by 1BADF350 View Post
Hey guys,
John Wood is at Holtville, CA near El Centro. John should be able to get your transmission installed on the same day you go down there as long as you schedule ahead with him. I would also have him install a 6.0L trans cooler. Your 44' trailer likely weighs a lot and this cooler upgrade should help keep your temps down.
2001 7.3L, John Wood stage-1 transmission, 6.0L trans cooler, Single-shot HO injectors, ITP RR, DP Tuner, Ford AIS Intake, 4" Exhaust, Detroit Truetrac, 245/70 tires, Accuride 19.5x6.75 wheels
F450Diesel is offline
Old 10-06-2008, 02:09 PM   #15 (permalink)
aklim's Avatar
Won't matter to you. If you use a program that they don't approve or is not stock, you have no warranty. You would in fact be paying aftermarket prices for a stock warranty. No thanx.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Closed Thread
