Whose gone from muffler delete to full 4 turbo back system? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 07-09-2009, 10:29 AM   #1 (permalink)
Browning01's Avatar
Right now I am running my truck with no muffler. Ive got a dual 4 inch kit that I may buy it is missing the downpipe so I will be using the factory downpipe and connecting the kit to the stock exhaust thats still on there. My question is will I notice a big difference if I buy a 4" downpipe, I would like to have a full 4 inch exhaust but if it isnt necessary I dont want to spend the money on it. Have any of you gone from a muffler delete with stock exhaust to a full 4 inch system with 4" DOWNPIPE? What are the differences sound, power, lower egt's etc?
2001 F250 7.3L White 4X4, Lariat Crew Cab, 7 1/2" Superlift, Mickey Thompson Classic lock Wheels wrapped in Dick Cepek 325/80/16 tires, 05-07 Grille and Headlights, wood dash kit, Pioneer Flip out DVD player, Cobra CB mounted under the 4x4 switch, DP-TUNER WITH STOCK, NO START, 80 ECON and 140 AGRESSIVE, DIY Intake with napa 6637 filter, IC Foil delete, new aftermarket tranny with sonnix shift kit and triple disc billet Torque converter, 4" Magnaflow Turbo back exhaust, Plantdrive wvo kit with 75 gallon external L shaped heated tank in the bed, Racor filter inline before the stock one, 146,000 miles
Browning01 is offline
Old 07-09-2009, 09:18 PM   #2 (permalink)
Just like any system it will only flow as much as the greatest restriction. I.E. your 4 inch exhaust is really only a 2 1/2 since you use the crimped stock downpipe. Just my advice = go with a 3 1/2 -4 inch downpipe. You will notice a small difference if the only performance part is the exhaust. Everything is a variable and you will notice more power, lower egts, etc. the more you get your system flowing optimally.
Year: 06/01 F-250 XLT 4X4 All hands on work completed by me. 4” Icon Lift, Dual Stabilizer, Pan Rod Bar, Shocks, Leaf Spring, Purple Cranium 10.5 & Dana 60 356 alloy, T-6 Diff Covers with Lube Locker gaskets, Mag-Hytec Tran Pan, AFE Stg II w/ PG7, MBRP 4” SS Exhaust, 0589-7887 Eagle Alloy w/ 315/75 MT Baja ATZ, U-joints upgraded to Precision Super-Strength greaseable, EBC 3GD Sport Vented Rotors w/ Yellowstuff (ceramic/carbon fiber) pads all around, SS brake lines, 203* Thermo w/ Billet housing, DB HT Starter, Harpoon/Hutch Mod w/ inline Fuelab filter, RedHead Steering Gearbox, Energy Suspension Master Bushing Kit, ISSPRO EV2 Gauges, DP Tuner.
01F250CCLB4X4 is offline
Old 07-11-2009, 12:57 AM   #3 (permalink)
YAMAHAMMER's Avatar
Send a message via Yahoo to YAMAHAMMER
The biggest difference I noticed was seemingly faster spool. That and you'll be able to tell its flowing better just from the sound, it doesnt sound all congested.
YAMAHAMMER is offline
Old 07-12-2009, 09:11 AM   #4 (permalink)
JimTJr's Avatar
My Photos: (20)
I went from the stock system straight piped to a 4" turbo back system. Sound is quite a bit different. Cant describe really. I like both. Performance diff? Negligable with the SOTP dyno. Spool may be a BIT Slower with the 4" DP. But not enough to worry about. Main difference/advantage is lower EGT's with the 4" DP and exhaust.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
