Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 7.3L Engine
Upgrades and Aftermarket - 7.3L Engine Upgrading and adding aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 07-20-2005, 02:18 AM   #1 (permalink)
Why are my temps always warm?
Ok well to me my temps seem hot, or is it just me.
Grossing about 14k on flat ground at 70 mph 2000rpm just under 10lbs boost tranny is 175degs to 180 ( note mods in sig) 900deg egts sometimes going down a little and up to over 1000
Going up a hill i can hold 60 in drive and maintain 1300degs at about 15lbs boost
Something seems wrong. I do have a small up pipe exhaust leak I know of. And I get a squeel from the turbo it sounds like that come and goes on and off going up some hills
New turd [img]/ubbthreads/images/graemlins/frown.gif[/img] 06 F350 King Ranch loaded
Sold [img]/ubbthreads/images/graemlins/frown.gif[/img] 03 F350 4x4 AT 7.3 SC Arizona Beige H2E AFE Intake Zoodad mod 5" exhaust 6pos Amsoil w/dual bypass filter, 203 t-stat, coolant filter, evans coolant. Spin On tranny filter, Sonax kit, trumax cooler, TC Lock up switch, water/meth, CPR+ fuel system
2004 Honda TRX450 w/HRC Race kit
2003 Polaris Sportsman 600 warn 2500lb
2005 Polaris RMK 900 151"
2007 WW SLC 37' Billet Edition
2000 Yamaha Banshee 4 mil
Sold 93 F250 5 speed 7.3
03_F350_2 is offline
Old 07-20-2005, 10:46 AM   #2 (permalink)
Re: Why are my temps always warm?
Well first of all at 60 mph uphill and you boost is only at 15 and your pulling 14k, that aint a bad temp at all. The skipping sound your hearing is the turbo surging because your rpms are prolly under 2k. Try downshifting and keeping the rpms up and the boost a little higher.
Your temps aren't bad so don't worry about that part. Just need a little change in the method of pulling.
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 07-20-2005, 10:59 AM   #3 (permalink)
trans temp looks good.. wow..
1997 F350 Crew Cab 4X4 some injectors trans by BTS (thanks Brian Patti and Albert)tymar open air filter aftermarket intercooler and turbo custome chip (thanks kale ) and 3" and 4" exhaust
powerstroke_mike is offline
Old 07-20-2005, 11:39 AM   #4 (permalink)
That the weight of the truck and trailer loaded. And I did down shift to drive and turn 2500 rpms up the hills.
I never got over 22lbs of boost this time and before I could get 28lbs. When I left I had to go thru traffic so my tranny did get to 200degs but its was slow going for a while.
I just don't see how I could tow anything much heavier, what if I got a trailer that was 8,000lbs empty and I put another 6,000 in it, seems like I would be in 4low going up some hills.
Old 07-20-2005, 11:53 AM   #5 (permalink)
Ok, you didn't say that in the first post.
Hmm, do you have a boost regulator on?
Is your wastegate unplugged?
What programs do you have on the chip and what one's have you tried towing in?
How does the truck run unloaded? And was the water/meth on when you were towing?
Old 07-20-2005, 01:52 PM   #6 (permalink)
All the turbo stuff is hooked up, I had the wastegate linkage comeoff before and it stuck open i belive, but I pulled it back and hooked the rod back up and got a clip for it.
I have the DI 6 pos chip high idel stock 50 75 100 140, tried all the power settings and its about the same. When I had the 4 pos chip my egts were way high too.
Truck runs good unloaded but Iam still not seeing the same 28lbs of boost I use too. I have no boost leaks either.
Water/meth was on the whole time, I could not tell anydrop in temps when i would turn it off thou. I did use about 10 gallons for under 500 miles, from sacramento to coos bay oregon on I-5 and hwy 42 in OR
Old 07-21-2005, 03:38 PM   #7 (permalink)
I HAVE THE SAME ISSUES. I MAKE THIS SAME TRIP TWICE A YEAR.SAC TO OREGON.PULLING 8000 TO 9000LB TOY BOX .MY TEMPS ARE RUNNING RIGHT AT YOURS.PROBLEM I HAVE IS I SPENT $1000 BUCKS ON INTAKE,EXHAUST AND PROGRAMMER.ONLY TO BENEFIT NOTHING.BEFORE MODS ALL I HAD WAS K&N DROP-IN STRAIGHT EXHAUST AND GAUGES,TRANS HAS BD/TC.I RAN THE SAME TEMPS WITH THIS SET-UP. I THOUGHT I WOULD GET THE WATER /METH BUT IF YOUR TEMPS ARE RUNNING WHAT THEY ARE I WILL SAVE MY MONEY. ANYONE HAVE ANY BETTER IDEAS?
haflich is offline
Old 07-21-2005, 03:48 PM   #8 (permalink)
Get your RPMs up. 2,500 is more like it. Pulls more cold air through the intake and cools your stuff off with a quickness. Also, what power level are you running at? Seems to me your temps aren't all that bad at all. Sometimes you have to downshift even if the truck doesn't feel like it needs it, to pull more air through to cool it off.
Also, the guy talking about running water/meth, you probably won't notice any EGT drop unless you just run straight water. Adding meth adds heat, it is a fuel, too.
However, I am convinced that a guy could tow a lot more weight with just some more RPMs under the hood, and turn your chip down or off altogether when pulling the grade.
'99.5 PSD 6 SPD 4x4 Extended Cab long Box F-350
AFe Stage 1 intake, Marinco Block Htr Plug Mod., Hutch in-Tank Pickup Mod, $10 AIC, Walker BTM, Edge Juice with Attitude, and that is all, FOR NOW!!! Next mod = Regulated Return???
Old Truck - '95 PSD 5 spd 4x4
Haulin' a 11.5' camper, an '85 Bayliner Capri 20' boat w/ Chevy 350, and a flatbed w/ two big quads.
2004 Grizzly 660 Yamaha (For Me)
2004 Polaris 500 HO (For the Wife)
Spokane, WA
"I don't ride bulls, but I have fought some men" Hank Williams, Jr.
"Sie vie pacem, para bellum" (if you want peace, first prepare for war...)
Hoss350 is offline
Old 07-21-2005, 04:26 PM   #9 (permalink)
my issue is running out on the flats @65mph my temps are at @900 to 1000 turning @1800to2000 rpm to get rpms your talkin about i would be runnin @75mph. this last trip i just started using the evo in 80 setting.i ran same temps and got same fuel milage this being 10mpg as before the mods
haflich is offline
Old 07-21-2005, 04:32 PM   #10 (permalink)
My Photos: (12)
75 MPH @1900 RPM, on a 95* day, my truck runs 700*-800* unloaded. I have big tires too.
FWIW,
Tom
(Paid For)2001 Ford PSD, Auto, 4X4, SC, SB, Toreador Red. AFE Stage II w/Pro7 intake, IAH Delete, DP Tuner Custom 6 Pos. Chip, FPR mod, HX mod, 203*T-Stat, BB Turbo, EBPV Delete, 4" exhaust. Map mod, Poontank, In-tank/Pre-pump, Sonnax/Tricum Kit, Mag-Hytec Trans/Diff pans, Full gauges on A-Pillar. 6.5" all spring lift. Dual remote reservoir shocks. Dual steering stabilizers. 37x12.50x17" Wheels/Tires. Roadmaxx all metal grill. (((XM))), 1000W Inverter, Amp/Subs, Fender turn signals. Paging Alarm/Remote Start/Turbo Cool Down Timer.
<font color="990000">My Pavement Princess</font>
kwazyca is offline
Old 07-21-2005, 04:36 PM   #11 (permalink)
i due run these numbers when i am unloaded. my issues are when i am loaded @8000-9000lbs toy box
haflich is offline
Old 07-21-2005, 04:42 PM   #12 (permalink)
My Photos: (12)
My point was your temps seem pretty normal/low for a loaded truck.
I saw lower towing temps when I went from a programmer to a chip.
Tom
kwazyca is offline
Old 07-21-2005, 04:51 PM   #13 (permalink)
how much lower were your temps? would really love to get them down
just got the evo, thinkin sending it back and callin tipton
haflich is offline
Old 07-21-2005, 04:55 PM   #14 (permalink)
n2quads:
I ran the SCMT programmer for a couple of years. We probably take the same trips out to Fallon etc. Even out there on the flat desert I could have egt issues. I finally got rid of the SCMT and put in 4 position chip from DP tuner. Night and day difference! More power and cooler EGT's overall. Did I mention more power??? My truck will pull my LOADED 33' 5er, (4 quads, 100 gal water, 40 gal fuel, tools, compressor, wife, kids blah blah blah etc) over Donner Summit at 65+ mph. EGT's at 1150/1200.
I once got stuck behind a big rig on a 5% upgrade. Slowed to about 40 mph. Traffic cleared and I put my foot into it. Driving it right at 1250 EGT, I was up to 60 mph in no time. It just keeps on pulling!
Sorry to sound like a cheerleader here, but Jody's tunes have given me a new truck.
Brian
2000 PSD Lariat 4x4 SC,, 111k miles, AFE pg7 stage II w/outerwear, ATS turbo housing, Wicked Wheel, gutted EBV, Banks BHA, 4" turbo back exhaust Aeroturbine , A-pillar gauges, Swepco in the tranny, BD torque lock, FTVB, 203* T-stat & billet housing, DP Tuner Tuning (4 pos; stock, econo, tow, perf), AIH plug, Powerslot Rotors & Hawk pads, Ride Rite air bags, PML rear diff cover, Filters: Dahl fuel, Dieselsite tranny & coolant, Amsoil dual remote oil. Rancho 9000's w/in cab controller(that needs install) on board air & horns,, done!!
I believe in Santa!! He drives a Big Brown Truck and wears a Brown shirt and hat!!!
All this to tow the 33' toy hauler loaded with fun!!!
dunesday is offline
Old 07-21-2005, 05:21 PM   #15 (permalink)
My Photos: (12)
Roughly 200*-250* lower
Really good idea!!!! [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Tom
kwazyca is offline
