02 with 20" Moto Metals...Stock 18's on newer truck fit? - Diesel Forum - TheDieselStop.com
Old 11-22-2009, 07:51 PM   #1 (permalink)
indystroker's Avatar
01 with 20" Moto Metals...Stock 18's on newer truck fit?
My 01 has 35x12.50x20 Toyo MT's on 20" Moto Metal rims. I just purchased the truck. It looks good, but i want to drop tire and rim size. Really dont want to shuck out the $$ for 20" tires. Thinking 33's on a stock 18" rim off a newer Super Duty. Aftermarket rims If I must. I've read about issues of wheel backspacing or something on the newer rims. ? is, are there any newer rims that can inner change onto my 99-04 bodystyle, bolt patterns not the same or what?
Or if this combo isnt even possible, shoot me in the right direction.
Indystroker
01 F-250 4x4, XLT, Crew Cab,
AFE Stage II Intake
TS Chip w/ PHP Tunes 40HT,80DD,120R,140 Xtreme
Auto Meter Gauges
ITP Fuel Tank/Pre-Pump Kit
Riffraff FRx Crossover
Gutted Turbo
Riffraff SS X-over
DIY CCV
4" Turbo Back w/Donaldson M085171
Warn Hubs
Sonnax Kit
indystroker is offline
Old 11-22-2009, 09:32 PM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (44)
'05-up wheels won't work on a '99-'04 SuperDuty because the offset/inset is almost 1.5" different. If you want new wheels, you also want hub centric wheels, and very few hub centric wheels are available. But one good one is the Ultra Wheel Predator 8.
It comes in 18x10, 8 on 170mm bolt pattern, 4.5" backspace, -25" offset, and 125.22mm (4.93") pilot bore, which is hub centric on your hubs. An exact fit for your truck.
LT285/65R18E tires are the smallest that will fit good on that 10" wide rim.
SmokeyWren is offline
Old 11-23-2009, 02:24 PM   #3 (permalink)
Dumb question, what does Hub-Centric mean? How can you tell if the wheel is hub-centric?
Indystroker
AFE Stage II Intake
Auto Meter Gauges
Gutted Turbo
Riffraff SS X-over
DIY CCV
Warn Hubs
Sonnax Kit
Old 11-25-2009, 01:32 AM   #4 (permalink)
jaseray's Avatar
forget that... i haven't and not many other people have had any problems with lug centric wheels like kmcs, moto metals, etc... and the wheels off of a newer super duty (05-07) will fit, they will jus be sucked in a little bit and might rub with a wide tire
2000 F-250 4x4 ext. cab- 207,000 mi- 35x12.50 hankook m/t, 18x9 black xd spy's, leveled with 2 inch add-a-leaf, 4 inch turbo back exhaust STRAIGHT PIPED, Hypertech Powerprogrammer III , 5.6k mod, A.I.H. Delete, IC foil delete, DIY tymar intake, Ranch Hand front bumper, black TSC toolbox, gooseneck hitch, 2 130 watt Pro-Comp spotlights, Prodigy brake controller, smoked '08 taillights 3rd brake lights and cab lights, '02 headlights,... TOTALED!!!
New Truck:
2005 F-350 Lariat 4x4 crew cab swb- 93,000 mi- AFE stage 2 intake, Diamond Eye 5" exhaust, '08 taillights
jaseray is offline
Old 11-25-2009, 10:08 AM   #5 (permalink)
SmokeyWren's Avatar
My Photos: (44)
In a nutshell, it means the wheel is centered on the hub by the pilot bore (big hole in the center of the wheel) and not by the lug bolts and tapered lug nuts. The pilot bore is exactly 125.22mm (4.93") diameter, so it fits very tight on the hub. If the pilot bore is bigger, then the wheel is not hub centric.
The wheel specs should include the diameter of the pilot bore, sometimes called just the bore. Hub centric wheels will be 125.22mm or 4.93 inches. If you have a good caliper measuring tool, then if it's less than 5" it's probably hub centric, but if it's 5" or more, then it's lug centric. The proof of the pudding is when you mount it on the hub, there should be no "play" between the hub and the pilot bore.
You will not find a chassis engineer that agrees it's okay to mount lug centric wheels on your hub centric hubs. Your hubs were not designed to live with the increased stress and strain of a slightly-loose wheel flopping around on the lug bolts.
Old 11-26-2009, 05:14 PM   #6 (permalink)
SmokeyWren. I just got a set of factory 18" wheels for my truck. Do you know what the tire size was from factory on that wheel. Is it 275/65-18?
What is weird is that tire rack shows that wheel only on a 250 and not a 350, I can't see why that would make a difference.
2004 F-350 Lariat supercab 8ft bed
6.0 w/ Torqshift
Dark Shadow Grey w/ Black Accent
3.73 Limited slip
ESOF, Power rear sliding window, FX4 package
Tele/HTD/lighted mirrors
Pioneer AVIC-N3 navagation/ roof lights
Adjustable accel/brake pedal
Reverse sensors/ heated seats
polished cab steps
MFD 02/04
Edge Insight with turbo timer and EGT probe
Sirius Satellite Radio
XM Radio
XM Navtraffic
2004fx4 is offline
Old 11-26-2009, 08:53 PM   #7 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Yes, but only on 4x2. F-250 4x4 optional tires and F-350 SRW 4x4 standard tires were LT275/70R18E.
There is no difference. F-250 and F-350 SRW with 18" wheels both have the same wheel specs. The slightly-different tire sizes for 4x4 and 4x2 will both fit the 18"x8" wheels.
Most of the world ignores the "tweener" pickup Ford calls the F-350 SRW. When they think F-350, they think dually. And dually tires and wheels are different than SRW tires and wheels. So maybe that's why TireRack doesn't have the F-350 SRW on their list - it takes the same thing as the comparably-equipped F-250.
If your truck came with stock 16" or 17" rims, then the LT275/65R18 will have about the same revs/mile as your stock-size tires, therefore no change to the speedo/odo/tripmeter calibration. But the LT275/70R18E is quite a bit taller, so it will throw off your speedo/etc. by about 3.8% and give you 3.8% longer legs (taller final drive ratio).
Old 11-26-2009, 11:46 PM   #8 (permalink)
Thanks. I ordered the 275/65r/18 in load range E. I guess I got the right ones.
6.0 w/ Torqshift
3.73 Limited slip
polished cab steps
MFD 02/04
XM Radio
XM Navtraffic
2004fx4 is offline
Old 11-27-2009, 06:57 PM   #9 (permalink)
In a nutshell, it means the wheel is centered on the hub by the pilot bore (big hole in the center of the wheel) and not by the lug bolts and tapered lug nuts. The pilot bore is exactly 122.25mm (4.93") diameter, so it fits very tight on the hub. If the pilot bore is bigger, then the wheel is not hub centric.
The wheel specs should include the diameter of the pilot bore, sometimes called just the bore. Hub centric wheels will be 122.25mm or 4.93 inches. If you have a good caliper measuring tool, then if it's less than 5" it's probably hub centric, but if it's 5" or more, then it's lug centric. The proof of the pudding is when you mount it on the hub, there should be no "play" between the hub and the pilot bore.
122.25mm is actually 4.81inches. I found some rims I like that are 125mm(4.92 inches). This should still work right? Are the offset and back spacing wrong?
http://www.ultrawheel.com/pdf/rims/09tech-173Nomad.pdf
16x8, Back Space 4 1/4", -6 offset, Bolt Pattern8-170 125mm bore 3400lb.
17x9 Back Space 5.47", +12 offset, Bolt Pattern 8-170 125mm bore 3500lb
Indystroker
AFE Stage II Intake
Auto Meter Gauges
Gutted Turbo
Riffraff SS X-over
DIY CCV
Warn Hubs
Sonnax Kit
Old 11-27-2009, 09:18 PM   #10 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Yeah, you caught me with a brain not working really good. The number is 4.93", which is 125.22mm, not 122.25mm.
Ultra wheel says their Nomad with 8-on-170mm hole pattern and 125mm pilot bore will fit a '99-04 Superduty. But if hub centric is 125.22mm, then 125mm is going to be a very tight fit. Ultra also makes the Predator 8, which has 125.22mm pilot bore. The 18x8 comes with perfect specs for your truck. Those should fit for sure if you wanted 18x8 rims.
I don't know enough about it to declare right or wrong. Ford offset is minus 0.25". That minus 6 raises a red flag, unless it's minus 6 mm, which is close to a quarter inch. Ford doesn't publish backspace, but others have said it's 4.5". So that 4.25" is close enough for Government work. And again, Ultra Wheel says it's for our trucks, so it probably is.
Old 11-27-2009, 09:32 PM   #11 (permalink)
I'm going to contact them on the -6. See if it is 6mm. I like the looks of the Nomads better than the Predator 8, they're a little flashy for me. I think I'm gonna go back to stock size rims and throw some 285's em. The 35's with 20's aren't the best for fuel economy...but man they're cool looking!
Indystroker
AFE Stage II Intake
Auto Meter Gauges
Gutted Turbo
Riffraff SS X-over
DIY CCV
Warn Hubs
Sonnax Kit
