'04 harley wheels - Diesel Forum - TheDieselStop.com
Old 04-20-2007, 09:34 PM   #1 (permalink)
'04 harley wheels
I have an '00 f250. I am looking at some o4 harley wheels. I know the wheels will fit, but didnt the thread pitch on the studs change at some point? If it is different, what would I do for lugs? These wheels have exposed chrome lugs, so I couldnt use mine.
Y2K PSD CC 4x4 Shorty.
81 Toyota Rockcrawler LT1 Dana60 /14 bolt, dual T-cases. 44"TSLs
roktoy is offline
Old 06-14-2007, 06:42 PM   #2 (permalink)
Re: '04 harley wheels
anyone know? I just bought some wheels, but havent got them yet. Anyone know what its going to take to make them work?
roktoy is offline
Old 06-14-2007, 07:23 PM   #3 (permalink)
HeavyAssault's Avatar
My Photos: (6)
The lug pattern (8x170mm) is the same, the lug thread pitch (14x1.5mm) is NOT the same. The HD edition wheels will fit with no issue, but you will need to find some lugs that look good and use the 2.0mm thread pitch that your truck uses.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 06-14-2007, 07:53 PM   #4 (permalink)
HeavyAssault is right, your OEM lugs are 14x2.0 and the '04 OEM lugs are 14x1.5.
The closest lugs I could find to the '04 H-D OEM's are the McGard Flange Style Dually lugs.
http://www.mcgard.com/automotive/pro...6&group=11
These probably would be good enough to hold the wheels on, but they probably will not work with the center caps. Most likely the only lugs that will work with the center caps are the '04 OEM ones. You may have to look into having your wheel studs changed out to 14x1.5 and getting a set of OEM H-D lugs. Wheel locks were also standard equipment on the '04 H-D's and I would also assume that those are the only wheel locks that would work with the center caps also.
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline
Old 06-14-2007, 10:59 PM   #5 (permalink)
So if I got studs for an 04, would they work in my 00, or are the splines different? Thanks for thr help.
roktoy is offline
Old 06-15-2007, 11:14 AM   #6 (permalink)
I got a part # F81Z1107AA from the dealership for wheels studs, both front and rear at $3.77 each, does that sound right. Anyone know if the 04 studs will fit right in the 00 wheel flange? If so, how hard is it to change them? Thanks
roktoy is offline
Old 06-15-2007, 11:19 AM   #7 (permalink)
The diameter of the knurl/spilnes should be the same between the two M14 lug studs. So it should be a direct swap out.
Old 06-15-2007, 06:50 PM   #8 (permalink)
My Photos: (6)
I don't know of a big change in the studs other than the thread pitch. I'm certian they would need to be pressed out/pressed in so if you did one as a tester that would prevent a big expense in parts. You just need to research the pressing out of the studs and what would be required to remove to make it happen.
Old 07-03-2007, 02:23 AM   #9 (permalink)
A buddy that runs the local oreilly found some washered chrome lug nuts that are 14X2.0. They look almost exacly like the factory harley nuts, except the washers are smooth on the backside, instead of having the lines in them to help keep the nuts from backing off, but I think they will be OK. The Dorman # is 611-230, and they were $.39 each. Heres the kicker. The book showed them to be 14X2. He ordered them, and they showed up in a box marked 14X1.5, and had 12mm nut in it. So he ordered a few more boxes, and one box had 14X2, and the other had 12mm, but they were both marked 14X1.5. Anyhow he ended up ordering 8 boxes of 10 to get 4 boxes that had what I needed, and they all were marked 14X1.5. Kinda screwy, but I scored some nuts for $16. He thought the price was fishy, but still gave em to me for that, but was going to send in an inquiry to see what was up. Long story short, if you need some nuts for harley wheels on a truck with 14X2.0 studs these will work for cheap IF you can get them and IF the price was right. I just got them mounted they look saweeeet.
roktoy is offline
Old 07-03-2007, 10:36 AM   #10 (permalink)
Good find roktoy, like you said they are almost identical to the H-D lugs. My only question is, do the factory center caps work with the lugs?
Oh, I looked and Rock Auto is selling the same lugs for $2.06 ea., so you got a pretty good deal. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Old 07-05-2007, 01:14 AM   #11 (permalink)
Center caps still fit. Now I just need a little bigger tire and I will be happy.
roktoy is offline
Old 12-28-2008, 12:29 PM   #12 (permalink)
Well, these lug nuts started rusting after just a few months. Now over a year later, they really look bad, so Im looking for something else. Anyone ran accross any other options? Thanks
roktoy is offline
Old 12-29-2008, 12:24 AM   #13 (permalink)
Why not use the old ones?
I just got the 2004 SVT rims a few months back. The ones that look like the Harley ones but no Harley markings. I was worried about the lugs until I found out my old center caps would fit and they cover the lugs. I just re-used my old ones,no issues so far. I thought the Harley ones were much the same? I couldn't use the 2 wheel drive center caps that came with mine though.
I got mine for 125 a piece from discount tire direct (I think). The are labeled a 2 wheel drive wheel, but they are the same. Even got a spare. But man do the 18" tires hurt the wallet a lot more than the 16".
2003 F250 7.3L 4X4 auto, Supercab Lariat, Ford AIS, Dieselsite AC mod. SVT 18" wheels
buddy357 is offline
Old 12-29-2008, 07:04 PM   #14 (permalink)
My Photos: (6)
What was your initial cost? Maybe you could order 2 new sets and just swap them out as they get trashed. Aside from swapping the studs out to the 1.5 thread pitch which could be more expensive up front, but yeild a better long term solution.
Old 12-29-2008, 08:48 PM   #15 (permalink)
Got any pics of those wheels? I like the look of the exposed lug nuts on these wheels, so I would rather keep the center caps. Why cant you use the 2wd center caps? Cause you have manual hubs? I made a tool to lock mine in, and drilled a small hole in the cap, that a 5/16" allen wrench fits through. I could get some pics if you want.
roktoy is offline
