05 conversion parts questions??? - Diesel Forum - TheDieselStop.com
Old 10-12-2009, 12:12 AM   #1 (permalink)
Just wondering if these are the necessary parts to do a 2005 conversion to my 2002 thanks for looking
2005 headlights- 2005 05 Ford F250 F350 F450 Super Duty Headlights PAIR:eBay Motors (item 110441131374 end time Oct-31-09 16:54:34 PDT)
2005 header panel- HEADER PANEL ford F-250 SUPER DUTY 05-07 06 2005 2007:eBay Motors (item 230386390786 end time Nov-08-09 07:34:36 PST)
2005 bumper- BUMPER ford F-250 SUPER DUTY 05-06 2005 2006 part auto:eBay Motors (item 230383451552 end time Oct-31-09 06:41:09 PDT)
2005 grill- I couldnt find a whole grill just inserts but of course I know I need one
2002 F250 7.3l Lariat
4'' MBRP turbo back straight pipe,Tymar,Superchip Flashpaq 1855,Boost,EGT,aih delete,wicked wheel
brc51m is offline
Old 10-12-2009, 01:32 AM   #2 (permalink)
You'll also need the following...did mine last August (2008)
1. Brackets for new bumper
2. Valance Panel
3. Fog Lights (Yes...they are different than the 99-04 style)
4. Headlight Wiring harness (they used a different bulb style in 05...there's a harness avaliable at dfuser.com...it will make the new headlights plug and play)
I think thats about it!
F250Ghost is offline
Old 10-12-2009, 03:35 PM   #3 (permalink)
Do you know where I can get the bumper brackets from?? And what is a valence panel?
Was the conv a long/hard process or what it moderately easy?
brc51m is offline
Old 10-12-2009, 04:54 PM   #4 (permalink)
woodnthings8's Avatar
Look here Powerstrokeshop.com Scroll to the bottom
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 10-13-2009, 12:06 AM   #5 (permalink)
I got my stuff from Ford Parts Direct Online: Buy genuine Ford OEM auto parts & aftermarket accessories at wholesale prices.
Old 10-14-2009, 08:15 PM   #6 (permalink)
mmterrill's Avatar
hey check out speedycarparts.com too. i got a primer aftermarket front bumper for 155 shipped.
mmterrill is offline
Old 11-04-2009, 08:06 PM   #7 (permalink)
Not trying to hijack this thread but, if i were to just get the grille and headlights from an 05 Harley, will I be able to just bolt it in? If not, what problems will I face?
Thanks In Advance
04 250 Harley is offline
Old 11-04-2009, 08:14 PM   #8 (permalink)
LOOSEWHEEL's Avatar
Thanks In Advance
Headlights will work but you will have to cut your existing header panel to make them fit. As well, you will have to replace the bulb connector harness to the newer H13 style. The grill will not fit as it is bigger than your 04 and will interfere with your bumper. However, some have cut the bottom of the grill to make it fit.
2001 F350 CC SWB 6spd WHITE 8.5" on 37's. Currently getting a complete makeover......stay tuned.
Pics
'Everything is possible if you don't know what you are talking about'
LOOSEWHEEL is offline
Old 11-04-2009, 08:19 PM   #9 (permalink)
LOOSEWHEEL's Avatar
Originally Posted by brc51m View Post
Do you know where I can get the bumper brackets from?? UAnd what is a valence panel?
You do not need the bumper brackets (referring to the side ones). The four bolts that hold the bumper to each frame rail will be sufficient. The upper valence (bumper cover usually painted to match) should come with the bumper.
The conversion is a simple bolt on procedure. You will have no problems getting it done. See this thread here
Pics
