08 F350 axle gears DASH / COMPUTER question... - Diesel Forum - TheDieselStop.com
Old 10-17-2007, 02:31 AM   #1 (permalink)
37's on there and going with 4.30 gears(3.73 now)....all ready have the mph corrected.
Question: Will there be anything lighting up on my dash gages... any funny readings due to the gear changes? Any computer problems,THANKS!
RKRacing is offline
Old 10-18-2007, 12:15 AM   #2 (permalink)
Re: 08 F350 axle gears DASH / COMPUTER question...
Has any one changed their gears yet in a 08...
RKRacing is offline
Old 10-18-2007, 11:54 AM   #3 (permalink)
I went with 4.10 but didnt think it was enough so i am switching to 4.30 today should be on the road tommorrow
2008 f-350 lariat
blkout2 is offline
Old 10-18-2007, 11:39 PM   #4 (permalink)
Hey there i'm possibly looking for some 373 gears for my 08 due to the crapy milage, i have talked to the dealer and they told me they could change the computer setting for different gears.
My truck is an 08 dually.
Tobysmobilerepairsinc@comcast.net
Toby4143 is offline
Old 10-20-2007, 02:54 PM   #5 (permalink)
ritschner's Avatar
Send a message via AIM to ritschner
If the 08's are like the earlier trucks, which I believe they are, changing the axle ratio will have no affect other than RPM at road speed. The speedometer pickup is in the differencial and is induction ring is separate from the ring gear. If your speedometer is correct now, it will still be correct after a gear change. It only needs to be recalibrated after a tire diameter change. The only thing I would suggest is to reset the PCM to allow for the different loads that will occur at a given road speed. The PCM will eventaully learn on it's own, but it will probably be less frustrating to reset it. If you are worried about clock and radio settings, you can reset the PCM by removing the PCM keep alive fuse for twenty seconds. The fuse number will be listed in the owners manual.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB w/cat, Accufab, Edge Platinum/w Evo Trans Tune, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
Old 10-26-2007, 01:25 PM   #6 (permalink)
What u turn said is the same thing I would have said.
I am very familiar with the 99 - 08 superduty trucks and speedometer correction methods
to original poster: how are you correcting the speed by the way?
kenny
Mercury is offline
