08 seats in a 99 - Diesel Forum - TheDieselStop.com
Old 02-13-2010, 04:31 PM   #1 (permalink)
08 seats in a 99
ok so i bought a set of 08 heated leather seats to put in my 99 XLT. but i have a few questions. First off could you get heated seats in 99 if so is it just a wiring harness that is under the seat to plug it into. second questions what mods do i need to make so these seats go in my truck? and if i dont have wiring harness under my seat can anyone tell me what im going to need to do to hook the seats up. do they use a constant 12v or do they use a resistor? Thanks for your help
'99.5 (12/98 build date) F-250 XLT super cab, short bed, 4x4, off road, 6-speed, South Bend Con O-Fe, 121K miles, turbo-back MBRP 4" exhaust w/ 5" tip, 6 position TS chip, AutoMeter Pre-turbo pyro, Post- turbo pyro,boost,oil pressure, Tymar Intake, Coolant Filter, HX hose, ITP over-boost eliminator, AIH Delete w/ boost port, Swamps F*me injectors, Hypermax mounting kit with a S300 turbo, headstuds, and a complete fuel system
randylamarr is offline
Old 02-13-2010, 04:35 PM   #2 (permalink)
skate918's Avatar
My Photos: (10)
have you checked to see what type of plug iut takes underneath the seat in your tuck and compared to the 08 ones? i put some 04 lariet power seats in my 01 xlt and they just plugged right in and worked. do they bolt right up?
2007 f-250 crew cab 4x4 w/ 130k
interior: outlaw seats, pioneer in dash, isspro fuel pressure gauge, edge insight monitor.
exterior: 4" zone off road lift, 20" kmc xd hoss wheels, 35" federal mt tires, ats rear end cover, x-metal grille, led taillights.
engine: arp studs, rcd egr delete, 4" turbo back exhaust, s&b intake, banks intake manifold, sct x3 witch mkm tuning, black onyx head gaskets, sinister coolant filtration system, fass platinum 95 series, ats aurora 3000 turbo, River City Diesel 180mm injectors.
skate918 is offline
Old 02-13-2010, 04:57 PM   #3 (permalink)
im not sure of they bolt up i will find out im not worried about them bolting up i will make that work im just wanting to get the power to the seats!!!
Old 02-14-2010, 11:30 PM   #4 (permalink)
jgarden's Avatar
if you arent worried about th fabrication (if needed) to install the seats, the electrical can't be much challenge!
Is the heat switch for the seats on the seats or on the dash?
Do you have heated seats now? If you don't I doubt you will have the harness.
Are all the controls for the seats actually on the seats? If so then you may just need +12v to the seat?
Anyhow, keep up posted and let us know what you eventually find out.
TDS member #49 - 1999.5 (Built 4/26/99) White F350, CC, SRW, LWB, Lariat, AIC, 4R100 (4th transmission before 85k - gotta love this tranny), 6.0 trans cooler, manual shift 4wd, 3 inch leveling kit, KING reservoir shocks, 285-75-16 Bridgestone REVOs, Performance Friction Pads all around, Powerslot Cryo'd rotors in front, CD player, Infinity REF 6800CS speakers (front and rear), Garmin 2610 GPS (hardwired), 40/20/40 leather seats, heated turn signal- TT mirrors, Titan V hitch, weatherguard box, DP Tuner 4 Position chip (love it), AIS intake, Diesel Site CAC Boots, 4" Magnaflow exhaust, Diesel Innovations Up Pipe, gutted EBPV, Non EBPV Turbo Pedestal, X-Monitor. NO STEERING WHEN BRAKES ARE APPLIED!
Jack
jgarden is offline
