12V fuel transfer pump - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 03-17-2013, 10:14 PM Thread Starter
We just bought an '04 F550 we're turning into a farm service truck. I've done a few upgrades and some maintenace already like blue fuel spring, egr delete, bypass oil filter, coolant filter, gauges, alternator gone through, new batteries, etc. If we're going to run a 12v fuel pump off the battery, do you think I should come up with a way to turn the idle speed up or just get a bigger alternator? I don't know what kind of pump we're going to get yet but I've seen pumps listed from a 20 amp draw to a 35 amp draw depending on how fast you want to pump or how much you want to spend.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters. SD starter. DP 80hp tuned PCM.
'04 F550XL reg. cab. ZF-6 speed. EGR delete. Coolant filter. Cat EC-1 coolant. LF777 bypass oil filter. Blue-spring fuel pressure regulator. ScanGauge II. Glowshift fuel pressure gauge.
'06 F350 xlt crew cab. 5R110 auto trans. 4x4. EGR Delete. DIY Coolant filter. Cat EC-1 coolant. Blue spring fuel pressure regulator. Open CCV. SCT X4 Gearhead Tunes. Dual SPA fuel/oil pressure gaugeWicked Wheel 2.
sdan27 is offline
post #2 of 5 (permalink) Old 03-18-2013, 11:07 AM
HeavyAssault's Avatar
My Photos: (6)
What if the intended use of the pump??
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
post #3 of 5 (permalink) Old 03-18-2013, 01:05 PM
You should be able to do the high idle mod that idles the truck up for PTO use. I did it on my F250 back in 06 when I got it. I don't know if the F550 was any different. It is just a matter of connecting a couple of wires to a switch. I used one of my upfitter switches. Unfortunately it was so long ago i cannot remember which wires are which, but the truck should already be wired for it.
A bigger alternator is a got change even without the pump. I have a 200 amp Quickstart large frame alternator. The older style large frame alternators will bolt on without any changes to the truck.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
post #4 of 5 (permalink) Old 07-09-2013, 10:27 AM
Smile
are you going to add lights? any other things that might need juice?
would prove a good thing to get a better out put from the alt. and add in a couple deep cycle batteries
going to install a gas/diesel powered welder?
but how fast/much do you need to transfer?
lots of gallons 100's a day?
or just 50 or so every so often?
would a hand crank pump work?
less to worry about.
but at age 54 a powered pump sounds good. even for the odd 20 gallons.
been thinking about adding a extra tank to my truck and would need a low psi higher volume pump to transfer the fuel. ( speed for volume only, no back pressure to worry about).
but for me even a battery drill motor pump would work.
larry
kg6tgu
2006 F250 4X4, 6.0 w/ auto, quad door cab, short bed.
for now just a stocker set up for pulling a fifth wheel, and moto transport.
N 38*09*900
W 120*49*900
packnrat is offline
post #5 of 5 (permalink) Old 07-11-2013, 12:31 PM
lone_star_dsl's Avatar
I've had a transfer pump in my truck for years. On one job in Louisiana, I was doing about 500 gallons a day. Never needed high idle or a bigger alternator.
One suggestion I do have is to run the power wires into the cab and put them on a separate (hidden) switch. I've had a lot of locks cut and fuel stolen and when I added the separate switch, I kept losing locks but I quit losing fuel.
2016 RAM 3500 Big Horn, CC LB, DRW, 6.7 CTD, 4wd, Aisin trans
Gone but not forgotten...
2002 F-350 SRW
Lariat, Crew Cab, Long Bed
4X4, Auto Trans, Tymar Intake
Wicked Wheel, Zoodad Mod
DP Tuner - 60E, 80E, 40T, 80T, Decel
05+ Harley Headlights
6" Upper and Lower Windshield Brows
ISSPRO Gauges, Edge Insight CTS
Sold at 206,000 miles
lone_star_dsl is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
