16" wheels on 05+? - Diesel Forum - TheDieselStop.com
Old 07-07-2009, 08:39 PM   #1 (permalink)
u2slow's Avatar
My Photos: (21)
16" wheels on 05+?
Has anyone tried 16" wheels on the larger brakes found on the 05+ models?
Sure would be nice if it was just a little grinding on the caliper, or it can be solved with proper backspacing on the wheel.
Any ideas?
97 E350 SRW minibus, E4OD/D70/4.10, 19.5 whls, BD trans pan, 3 batteries & inverter, tach dash
93 W250 6BTA/5spd/D60/D70/3.55
90 D250 6BT/5spd/D70/3.55
Other rigs I wrench on:
95 F350 CC 4x4 ZF 4.10 Lockright/Detroit, T444E J/W pump, hydroboost, EBPV brake, straight pipe, 5.6k mod, 4" lift, 35" Toyos
Ford 6.9/7.3/IDI/turbo/PSD, 89-02 Dodge CTD
Marine Engines I mess with:
Mitsubishi S6U, S6R, 6D14; Mirrlees National KVSSM; DDC/MTU 12V2000; Cat 353, 398, 3306, 3406
u2slow is offline
Old 07-07-2009, 10:12 PM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (44)
No, 16" rims won't fit on an '05-up PSD. A 16" rim is not big enough to clear the caliper.
SmokeyWren is offline
Old 07-07-2009, 10:42 PM   #3 (permalink)
u2slow's Avatar
My Photos: (21)
Yeah, that's the popular opinion.
I'm trying to see if anybody has tried to make 16's work... much like 15" wheels could be put on older 3/4 or 1ton Ford and Chevs when some caliper grinding and/or less backspacing on the wheels.
The reason is I have an '07 rear end that I'd like to steal the disc brake setup from (probably re-drill the rotor). Might have to figure this out the hard way though.
u2slow is offline
Old 07-12-2009, 12:30 AM   #4 (permalink)
BubbaZ71Tahoe's Avatar
you may be able to with grinding and like a 3.25bs wheel... I know of alot of guys running 15s on dana 60s
2002 f250 ecsb 7.3,4r100 triple disc converter shift kit, amsoil atf, 60/10.5 DIY Tymar, (ISSPROboost, trans, Egt) PHP FU.
AutoEnginuity in the Lafayette-Houma area
BubbaZ71Tahoe is offline
