1999.5 to 2012 F-250 Nose Swap Conversion Done!!! - Page 5 - Diesel Forum - TheDieselStop.com
Closed Thread
Old 11-07-2012, 01:38 PM   #61 (permalink)
shatesme's Avatar
Originally Posted by Wrencher View Post
Are you going to swap the bed or just had fender flares on the rear?
Yeah! I'm waiting to find a 2011-2013 8ft bed under $1200.00...
shatesme is offline
Old 11-07-2012, 02:49 PM   #62 (permalink)
Wrencher's Avatar
Classifieds for Utah, Idaho, and Wyoming | ksl.com bed
Might be too far away don't know where you live.
2002 F-350 CC Shortbed, 7.3 Powerstroke,150K, DIY BHAF, EBV brake mod, fuel shim. Built tranny w/ triple disk Torque convertor and shift Kit, 4" Lift, 35" BFG KM2, TS Performance 6 Position, Banks Big Head Wastegate, 4" Duals, Superlift Air Bags, B&W Hide a ball W/ 5th Wheel Companion, Marinco mod
LOCAL 3 OPERATORS UNION
Wrencher is offline
Old 11-08-2012, 10:48 AM   #63 (permalink)
shatesme's Avatar
Thats a great price but I in New York thats to far. But thanks...
shatesme is offline
Old 11-12-2012, 03:23 PM   #64 (permalink)
shatesme's Avatar
I just got my second set of fog lights in today.
shatesme is offline
Old 11-13-2012, 08:39 AM   #65 (permalink)
05_HARLEY_F250's Avatar
That's a pretty neat trick, are there any plans to tackle the interior cab?
Replaced stock w/stock
Radiator
EGR cooler
Head gaskets
Harley Davidson windshield
Replaced w/or added, upgraded, modded or converted.
Scangauge II
RECON Big Rig Ice running board lights, interior LED light conversion.
RECON smoke LED tail lights, third brake light, mirror lights, fire & ice tailgate strip.
ARP studs
Garrett powermax turbo
Metal CAC tube, Turbo oil supply and drain conversion
Blue spring
Fuel/water separator drain plug
Goodyear Wrangler Duratrac 275/65R20
Drilled/slotted rotors w/ceramic pads
IPR Generation 2 EGR delete.
IPR High flow coolant filtration system.
JVC KW-NT700
Coming Soon!
Rear mounted under bumper off road lights for hooking up & setting up trailer.
Frame mounted air compressor w/ 2gal. Reserve.
05_HARLEY_F250 is offline
Old 11-14-2012, 11:24 AM   #66 (permalink)
shatesme's Avatar
I like my 07 interior right now but who knows when I done with the outside maybe I'll get an itch to update the interior too..
shatesme is offline
Old 11-20-2012, 01:05 PM   #67 (permalink)
NYB
shatesme: nice job. speechless. subscribed.
2000 7.3L 16 Valve
NYB is offline
Old 11-20-2012, 02:54 PM   #68 (permalink)
shatesme's Avatar
Thanks "NYB".
shatesme is offline
Old 01-05-2013, 09:31 PM   #69 (permalink)
wickedlester's Avatar
u runnin spacers on those wheels? my 2000 hit a deer also and im tryin to decide which direction to take
wickedlester is offline
Old 01-05-2013, 11:23 PM   #70 (permalink)
shatesme's Avatar
Yes I running steel spacers for the 2011-13 20" stock wheels,don't buy the aluminum ones they are horrible and a waste of money.As for the nose If you want the easy way, go with the 2007 nose upgrade its brainlessly easy. The 2011-13 wasnt to bad to do but is alittle involved but worth it IMO.
shatesme is offline
Old 01-06-2013, 12:48 PM   #71 (permalink)
usmarshls's Avatar
Send a message via ICQ to usmarshls
where did you get the emblem for the door? they make 6.0 emblems like that????
2005 F-350 King Ranch FX-4 CC long bed
2in level kit...airade intake with 4micron sock...superchips....sinister coolant filter.....blue spring update....ranch hand wrench ready front bumperreplacement.... installing glowshift gauges this week....EGT,BOOST,TRANS TEMP,FUEL PSI. with quad gauge pod A-PILLAR (DONE) 4IN turbo back cat delete
In the Garage
1995 F-150, 460CID, 9in currie rear, C-6 trans, 4.56gears, 23in susp travel.
2004 Expolrer 4.0L
Coming soon
2012 BOSS 302 (If the wife dont kill me)
usmarshls is offline
Old 01-06-2013, 01:16 PM   #72 (permalink)
thanks. how thick r the spacers? i have aftermarket wheels now and wld love to go oem as i get a slight shake with the lug centric. problem is i hate hate hate all the stock rims for 99-04. i cant see from ur photos(notice the tree) how drastic is the fender diff without changing beds?
Old 01-06-2013, 01:18 PM   #73 (permalink)
btw mine is 2wd running 285/75 16 bfg ko. time for tires anyway
Old 01-09-2013, 01:28 PM   #74 (permalink)
How much fab work was involved does everything bolt up
adewerff is offline
Old 01-09-2013, 02:53 PM   #75 (permalink)
7.3 IDI Man's Avatar
You'll fool some Mechanics
1990 F350 7.3 IDI 95,000 miles Manual Glow Plugs.
7.3 IDI Man is offline
Closed Thread
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
