Not quite. He had a complete 08 donor truck. He grafted the 08 firewall, front clip and dash as well as the 08 harness and added in the necessary X electrical components... I wonder if the 99 computer can even drive the 08 cluster??? Here is the link to the original detailed thread. It is in another forum so i don't know if it violates rules but it does go into details. It may give you some needed information. Good luck.
Building an 08 Excursion(pics) - Ford Powerstroke Diesel Forum
Member # 23075 Reged: 07/18/02
2005 Excursion w/ 6.0L PSD - Edge Insight, RCD EGR delete, Turbo Drain/Blue Spring/Oil Cooler Updates, Dfuser Coolant Filter, 240amp alt, fumoto.
2008 FX4 F250 CCSB w/ 6.4L PSD - Edge Insight, H13 Bi-HIDs, custom coolant filter, fumoto.
