Upgrades and Aftermarket - GeneralUpgrading and adding aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
whats up guys ,, im looking into a set of 24.5" freightliner wheels with low pro tires, i have a 06 f550 and i tow a pretty heavy trailer around only a couple times a year (25k lbs loaded) and also a 15k lb trailer loaded about once or twice a month but only local..
my first question is, will i need a lift? my 550 sits pretty high, i do have a bed on it, and i also have a 2,5" level kit in the mail..
secound, are these tires ok for towing? or should i put a "big rig" tires on the 24's?
thanks alot guys
06 F550 dually with bed ,Pioneer z1 touch screen, Kicker component speakers front & back, 3 10" kicker CVR subwoofers, 10K HID headlights&Fogs,3 pod pillar egt boost trans, Banks 4" turbo back exhaust muffler n cat gone, custom 6" lift by RMS, Airaid intake,Zoodad , Bed cover, chrome grille, SCT by innovative xtreme tuned . All runnin on 35's
Lots of big rigs use low pro tires. Assuming by low pro you mean size 285/75R24.5 instead of the taller 11R24.5.
The 285/75R24.5 is 41.4" diameter, with 502 revs/mile. So that will change your effective rear axle ratio by 22 percent. IOW, your 4.88 will feel like a 3.80 ratio. Is that going to be enough leverage for your max load? No, not if the trailer weighs as much as 25k. And you would struggle with a trailer that weighs 15K.
The 11R24.5 is even taller, so they would change your effective rear axle ratio by about 25.6 percent. Don't go there.
To make up for the taller tires and get back to at least a 4.30 equivalent ratio, you'd need to change your ring gear and pinion to one with 5.42 ratio. To get back to the full power and torque of the equivalent to 4.88 with stock-size tires, you'd need a 5.95 ratio ring gear and pinion. That's no big deal, because Dana makes ratios over 6.00, but they ain't cheap.
thanks alot guys
Are you doing this only for towing or mainly for aesthetic reasons? If you just want load capacity a 19.5 would be more than adequate with proper tires.
