4wd frount end leveling - Diesel Forum - TheDieselStop.com
Old 07-26-2009, 10:52 AM   #1 (permalink)
Farmer18's Avatar
I have been looking for a frount end leveling kit for my early'99 and i saw a 2 or 2.5" that was just a spring pack and u bolts. Do i need to relocate my tracking bar or any thing when going that luttle amount and if so where can i get the stuff or what kit has it included? Thanks
Early '99 excab long bed with a 7.3 and a six speed 4X4 Ultra lite pryo, boost, eng oil temp, tranny temp, diff temp DP 5po stock, hi idal, 80, 100, 120 BDP domminator turbo, 4" turbo back, open air intake, WARN hubs, '03 head lights, Recon led tail & third brake lights,. Dads is a '03 regular cab w/flatbed 7.3 w/auto tranny 4X4, Edge evulation open air intake.
--Also drive a '05 378 Peaterbilt w/C15 525hp Twin turbos 13speed 3 drive axels 55'long w/a Haybuster haygrinder mouted on it w/650hp C15 Cat powering the grinder w/flued cuppler clutch and hydra boom True diesel power
Farmer18 is offline
Old 07-27-2009, 10:44 AM   #2 (permalink)
My Photos: (19)
By doing just a spring pack you will end up with a harder right up front. If this is acceptable then you will want to also get an adjustable track bar as your front axle will no longer be centered under your truck. Some will try and sell you a drop track bar bracket but this will just mess up your steering geometry. An adjustable track bar isn't that expensive and will do a better job.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline
