Adjusting headlights on 05 f250?? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 06-06-2007, 10:25 PM Thread Starter
Howdy!!
Ive got an 05 f250 powerstroke. The headlights on it seem to be angled downwards too far. Does anybody know how to angle these bad boys up a degree or so?? I hate to pay the dealership the big $$ to do this. Thanks in advance!!
Andy
athollinger is offline
post #2 of 5 (permalink) Old 06-06-2007, 10:43 PM
Parts Jimmy's Avatar
Re: Adjusting headlights on 05 f250??
Most of the time its not to expensive to have the head lamps adjusted. A lot of state inspectors will do it while inspecting your vehicle. Its worth having a aimer attached to get the correct angle.
7.3 Power Stroke Diesel, 4R100, 4" MBRP Exhaust, Ford AIC, Motorcraft Air Induction System,
DP-Tuned, AIH Deleted, EBPV Deleted, Bellowed Up-Pipes, Dieselsite Coolant Filter, Bilstein 5100 Shocks, Timbren Overloads, Husky Mudflaps, Hella 700FF Driving Lights, Autometer Gauges
Parts Jimmy is offline
post #3 of 5 (permalink) Old 06-06-2007, 11:36 PM
Just find a flat level dark road and adjust them like you want them. Your manual should tell you how. I am sure someone will pipe in with locations for adjustment screws.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
post #4 of 5 (permalink) Old 06-07-2007, 02:06 PM
Tallavana's Avatar
My Photos: (14)
05s and up have a external torx screw on the top rear of the light housing. The torx size is E5. You will have to get this size off a tool truck and will have to pay around $10 for the one bit. You can find size E6 at auto parts stores for a couple of bucks. It will work since there isnt much tension on the screw. Ive also used a pair of duck nose pliers on my own, just dont round it off.
Light travels faster than sound. This is why some people appear bright until you hear them speak.
2002 F250 Lariat 4x4 Crewcab PSD Shadow Grey/Black
BD X-Monitor, BD Pressure-Loc, SCMT(80),AFE Magnum, 2.5"leveling and 4" block, Bilsteins, Retrax, LineX, Oilguard, MBRP 4" SS, Moto Metal 950 18x9, Toyo A/T 325/60/18, 05 front end w/Harleys, KC 05 light kit w/3 driving lights.
Tallavana is offline
post #5 of 5 (permalink) Old 06-07-2007, 02:21 PM
DCSpecial's Avatar
My Photos: (21)
A 5/32" socket will work on that adjustment screw as well....
DCSpecial is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
