Re: Advice on 8" lift install for an '06
I installed a 6" skyjacker on my 05 about a year ago, and removed it about 6 months ago and installed a 3" rough country.
Its a really easy install. You could use more then one floor jack. 2 will work great. Tall jack stands are a must especially with an 8" lift. YOu will need to get alot of space between the axle and the upper coil spring mount to get those 8" coils in there.
Be patient on the pitman arm, some of them like to stay on the steering box and others will just pop right off.
This is really all the advice i can give you since i havent install that particular lift or remove the radius arms. Just take your time and make sure you have the truck up high enough.
A buddy will really help you out
Justin
2011 Sterling grey F250 crewcab fx4 lariat plus package 2" up front 2.5 rear lift 37x12.5x20 nitto trail grapple on factory wheels b&w hitch
2006 Red F350 crewcab FX4 4" skyjacker w/4.5" Donahoe springs 37x13.50x20 Kumho Road venture MT on Factory 20", DPPI exhaust,Edge w/ attitude, B&W turnover hitch
pic link http://community.webshots.com/user/justin1978
