Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - General
Upgrades and Aftermarket - General Upgrading and adding aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
Old 03-23-2006, 09:03 AM   #1 (permalink)
All right. Lets talk about guage brands.
I need advice on what brands are the best and why? Mounts? Prices/sources? Also what type of guages do people consider MANDATORY! Vs. nice to have that type of info? BTW I do not want to get rid of my grab handle, even though I love the look of the guages mounted there. T.I.A. Let the information flow!
If you can read this, thank a teacher, THANK A VET. it's in English: 04/04 F350 6.0 PSD Lariat CC 4X4 LB SRW Auto 3.73 rear end. All options except:moon roof-PTO-roof lights. Mods... MBRP,Line-x, White nite, Windows double tinted, 3 DVD system, Highway products 5er box, Pro-comp leveling kit, Pro-comp wheels/tires, MX-6 shocks,Viper 791XV remote start security system,Line of fire,Fumoto oil drain plug,Alaska tent and tarp bug screen,Rapid hitch drop hitch,Cobra 29 CB, Norcal Powerstrokes Member #5 http://www.norcalpowerstrokes.com/Events.html
SAVAGESAM is offline
Old 03-23-2006, 10:17 AM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Re: All right. Lets talk about guage brands.
Assumming the ordinary, affordable gauges that most of us have, there's no significant difference in the accuracy of name-brand gauges such as ISSPRO, Autometer, DiPrico, Banks, BD, etc. The SPA Technique digital gauges should be a bit more accurate than the analog gauges, but you'll pay extra for that accuracy. So pick the one you like the style or the face or the color or the lighting. I prefer the 270º sweep gauges to the lesser sweep of most analog gauges, so I prefer the ISSPRO EV in an analog gauge. If I had the big bucks, I'd probably go with SPA Technique dual-digital gauges hooked up to alarms and flashing lights, etc. [img]/ubbthreads/images/graemlins/cool.gif[/img] http://www.spatechnique.com/dualgauges/dualgauges.htm
If you want professional-grade very-accurate gauges they are available but very expensive. I don't even know the brand names, but ask anyone who builds experimental aircraft and they can tell you. [img]/ubbthreads/images/graemlins/wink.gif[/img]
Since you want to retain your driver's side grab handle, then your best choice is to mount the gauges above the inside rearview mirror. Or if you like digital gauges, then consider the BD X-Monitor that will mount on the A-pillar below the grab handle. Click here. If you get the BD, then understand that the tranny temp will show about 10 to 15 degrees hotter than other gauges (because of where they put the sensor), so instead of 225 for the red line, use 235 or 240.
For price, you can get what you need in three ISSPRO EV gauges with an A-pillar mount for around $300 from several different sponsors of TheDieselStop. Or for two gauges in an under-cubby mount, as low as about $240 from www.dieselmanor.com . Autometers vary in price based on which style you choose, but their less-expensive styles are around $300 for a full 3-gauge set too. The SPA Technique gauges are a lot higher, but they may be a bit more accurate, too. [img]/ubbthreads/images/graemlins/crazy.gif[/img]
If you don't tow and you don't hot-rod the engine, then you don't need additional gauges.
If you tow more than a rowboat, and you have an automagic tranny, then mandatory is a tranny temp gauge. The stock tranny temp gauge is almost useless, so get one with easy-to-read marking in the critical temp area of around 200 to 230. Anything below 200 is not important. Anything above 230 is too hot - your tranny is probably already turning into toast. So you care about 200 to 225 or a bit above the 225 redline.
If you tow heavy in hills and mountains, then you can get by without a pyrometer if you promise never to take the mountain at pedal to the metal. You can tug that trailer up the mountain at about 9/10ths go pedal with no worry. But if that doesn't sound like fun, then you need a pyrometer. Mount the thermocouple (sender) pre-turbo, then use 1,250º as your red line. When towing up the mountain, modulate the go pedal to keep the pyrometer showing 1,200º to 1,250º EGT - the same technique you use to modulate the go pedal to maintain a constant speed. [img]/ubbthreads/images/graemlins/cool.gif[/img]
If you hot-rod the engine with any sort of chip or programmer, then a pyrometer is mandatory. 1,250 EGT is the red line.
For towing or normal driving with a hot-rodded engine, the boost gauge is "nice to have". The red line is 25 PSI, but it usually goes up with EGT, so when balls out up the mountain, if you properly control EGT then you won't need to also worry about boost.
I don't know about racing or sled pulling or such things. Maybe the boost gauge is necessary for those activities. [img]/ubbthreads/images/graemlins/confused.gif[/img]
SmokeyWren is offline
Old 03-23-2006, 11:10 AM   #3 (permalink)
I like Autometer for the gauges, and as many as ya can get! LOL
Trans, Boost, And Pyro Are pretty standard for the "must have" gauges
http://i36.photobucket.com/albums/e3...Picture033.jpg
Im an info freak.. i have 11 total.
2003 Svt Mustang Cobra
2003 Millenium Yellow Corvette
9.88 @ 141mph
2001 F-350 Supercab short bed, Ford AIC, Buckstop bumper, 2 80 PRO XT Piaa's, 4- 8in Explorer Pro Comp Lights, M12000 winch, K&n Fipk, Garret Gtp38R Turbo, banks power elbow, banks monster exhaust, 6.0 Litre Intercooler, Dp-Tuner 4 poisition chip 60-80 econo-120-140, Banks Six gun,PSC Ram Assist, Autometer Oil temp, Diff temp, Oil Pressure, Water temp, Intake Air temp, Tranney temp, Voltmeter, Pyrometer, Boost Gauges. 12in lift 8in Spring Packs, 3.5in hanger up front and blocked 5in Out back, Goodyear G-124's 265/70/19.5, Spitzlift crane, Snow performance water/meth injection, Suncoast triple disk converter, Tru-cool tranny cooler, Mag hytec tranny pan, 4.30's and Front and Rear Lockers. Towing the vette is FUNNN
CorvetteGuy is offline
Old 03-23-2006, 11:36 AM   #4 (permalink)
[/ QUOTE ]I would get confused trying to find what gauge i want to look at. [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/smirk.gif[/img]
'07 F-350, True Blue, SuperCab, LB, SRW.
Mods: Line-X, Putnam Class V hitch, Power Steps, window tint, chrome package grill and mirror caps, chrome door and tail gate handles, Line of Fire lights with white reverse lights. Marathon Superhides. 55w Reverse lights
Sorno is offline
Old 03-23-2006, 04:27 PM   #5 (permalink)
Thanks alot, I love this website (It's my homepage) I sure do like those dual guages, they are pricey though. Has anyone completely done away with their stock instrument panel and fabbed up a new one? Pics? Special thanks to Smokey.
Old 03-23-2006, 05:08 PM   #6 (permalink)
CONFUSED??? Heck, with 11 guages I'd have a wreck.
I have Isspro's Boost, Pyro, and Trans Temp. If I had it to do over again I would probably get a real water temp guage instead of the boost. My "Check Engine" light tells me when my foot is on the floor and I am overboosting. I had hoped it would tell when my air filter was dirty...but it either does not tell you, or I cant read it right, or my air filter has never gotten dirty enough to tell by the boost guage (likely).
Anyway, I like the Isspro Ev's and it is always fun to have people get mad because their dealer did not tell them they could have guages from the factory. Mine really do look just like FOMOCO put them in. I ordered them from Diesel Injection Service (Lubbock, Tx) and they painted the pillar for me. Looks amazingly factory. DIS used to be a sponsor here but I have not seen them in a while.
I like the A-pillar mount so I cant really comment on mounting anywhere else.
Good luck,
Jay
99 XLT,PSD,CC,SB, 4x4, Manual T-case and hubs, auto trans, 3:73 Limited slip, 235/85/16E Yokahama Geollander AT/S, Straight piped, Amsoil and Dodge LS Additive in the rear, Diamond B Brush Guard, BIG Lightforce lights, AFE MAgnum intake/Pro guard 7 filter, Sony deck, Isspro Gauges on A-piller, Rancho RS 9000's on Back, Monroe reflex on front, SCMT 60 or 80hp, 203 T-Stat, Billit Housing
IF YOU HAVE EATEN TODAY, THANK A FARMER!!
Jay Brunson is offline
Old 03-23-2006, 05:13 PM   #7 (permalink)
Geez, you're an info freak!
Ryan Arthur
2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
Performance Mods: ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator and tee, ATS ported housing, Banks Big Head, CCV Mod, DP-Tuner flip chip, BTS valve body ||| LEDs everywhere: taillights/running boards/mirrors/rear, side lights wired as turn signals, upgraded headlight harness w/ Xtravisions, aux backup lights in bumper ||| Misc. Mods: no more dingers, newer cupholder, fumoto, C-Betrs, locking fuel cap, mud flaps, wannabe air horn, Line-X, behind-seat storage shelf, intercooler foil wrap removed, SS HPX
My Truck Pics
NorCal Powerstrokes
ryaneverk2 is offline
Old 03-23-2006, 08:10 PM   #8 (permalink)
I chose DIPricol Optix. Good factory match and the lighting at night is highly visible and easy on the eyes. Shop around and pick a brand. The choice is yours.
"Real Trucks Don't Have Spark Plugs"
2000 F250 Lariat Crew Cab, Island Blue/ Harvest Gold , 7.3 PSD, LWB, 4x4 ESOF, Auto Trans. 3.73LS, 285/75/16,AT/BFG, Husky Liner Floor Mats, AIS/Foam Fender Sleeve Mod. Line-X, Leer 100XL Cap, MOOG Balljoints, Performance Friction Rotors and Z Rated Carbon Metallic Pads, Fumoto Valve, DIPricol Optix Gauges, Pyro,Trans,Boost, A-pillar Pod, MBRP 4 inch T-304 SS Cool Duals, EBPV delete 6.0L Trans. Cooler,Schaffer's Transmission Fluid, BTS Transmission, DP Tunes, Stock/High Idle/40T/60T/80E/120R/140SMK 309.77 hp/605.12tq
Spooling and Cooling by BWD with a Turbonetics Turbo & Spearco Big 6.0 IC
"The Smoke Don't Mean Its Broke!"
Bushwakd is offline
Old 03-23-2006, 08:26 PM   #9 (permalink)
I purchased the isspro triple gauge overhead kit and love it, easy to install,match great and looks great. People are always saying how good they look and how they look stock. They came from Diesel Manor, thepeople there were very helpful and had great instructions and the kit had everything that I needed to do the job and do it right.Hope this helps
2000 F-250 ext. cab 4x4 lariat auto, <font color="green">F-5 60tow,80eco,120Get'R'Dun</font>,AFE Stage 2 PG7,MBRP 4" turbo back,<font color="blue">BTS-VB</font>,ITP Crossover,203*T-stat,<font color="red">CAT EC-1</font>,Isspro Overhead Pyro,Boost,Trans.Gauges
<font color="blue">Photos</font>[*]The fact is that the average mans love of liberty is nine tenths imaginary, exactly like his love of sense, justice, and truth. He is not actually happy when free.,He is uncomfortable, and a bit alarmed, and intolerably lonely. Liberty is not a thing for the great masses of men, it is the exclusive possession of a small and disreptuable minority, like knowledge, courage, and honor. It takes a special sort of man to understand and enjoy liberty and he is usually an outlaw in democratic societies. H.L. Mencken 1923
Jimmy3336 is offline
Old 03-23-2006, 08:55 PM   #10 (permalink)
I like my Lunars from Autometer, check my pics for mounting position.
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 03-24-2006, 08:36 AM   #11 (permalink)
The pics are worth a thousand words, thanks. Any more pics? Please let me know. So far, I'm thinking three above the mirror and three in a cubby mount. Which ones come closest to matching the color of my AIC? Or should I not even worry about matching them up?
Old 03-24-2006, 10:37 AM   #12 (permalink)
Teebird's Avatar
That's why old analog aircraft have two pilots, a flight engineer and a navigator. It's called "workload" and people to tend to take their eye off the road, or sky, with that much information. That's also why aircraft have a master warning and caution light to let the crew know that, heh, one of your gauges is off you better start looking around and find it. Sometimes too much of a good thing is bad.
2003 F250 XLT 4x4 Sport Crew Cab,
Built May '03, Bright Red, 6.0 Auto, ESOF 4x4, 3.73LS, 4.5" Edge Lift, 315/75-16 BFG KO A/T's, Polished/Clear Powder Coated Diff Covers, Weld Cheyenne 8 Wheels, Line X, Overhead DVD, Torza Tonneau Cover, 30' Fleetwood Gearbox Travel Trailer
Teebird is offline
Old 03-24-2006, 12:45 PM   #13 (permalink)
CSIPSD's Avatar
My Photos: (52)
Overhead...
ALL...
I dont have a shot of just the A-pillar...
05/01 F-250 PSD, 125,000 miles, Zoodad, AFE Stage 2, CCV mod, Turbonetics Ball Bearing, Turbo-Master wastegate, Dieselsite's boots, 6.0 IC,Water Injection, AIH delete,ITP Regulator,DP and Wildman tunes,GTS Hybrid injectors, ITP Fuel system,Studs, 910 valve springs,Suncoast 4r100,MBRP T-409 duals,Aeroturbine, 6" tips, 16 Isspro gauge's, 100g fuel tank, 05 mirrors with recon lens, 4" Revtek lift 37-13.50-17 Toyo MT's
ME!
MY PICTURES
CSIPSD is offline
Old 03-25-2006, 02:49 AM   #14 (permalink)
Autometer Phantom guages in A-pillar.
Same with lights on .
03/03 (Original Factory Flash) F250 SC Lariat FX4 6L, AIC, TS Auto; 6 Bilstein 5125's; Rancho Steering Stabilizer; Toyo AT 305/70/R16E's on 16x8's; Tuff Country 2 1/2" Level kit; 2" rear add-a-leaf; UTE Bumper; Turbo Back Cool Duels; Autometer Phantom Pyro, Boost, Trans, Volt gauges; Hella 4000 Euro's; Hella Micro DE Fog's; SUV headlight harness & Hella 80/100 9007's; Clear Corners; Billet Grille; 2x60 watt battery heaters; 250 watt oil pan heater; Delo 5w40 Synthetic; Compustar Remote Start/Alarm; My Truck
AK6LPSD is offline
Old 03-25-2006, 10:27 AM   #15 (permalink)
I didn't know you could put four above or on the A pillar. I like the look of the auto meters. I got a lot to learn before I part with my hard earned.
