Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - General
Upgrades and Aftermarket - General Upgrading and adding aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
Old 10-16-2008, 04:47 PM   #1 (permalink)
Alum diff cover bolts
I just bought an '08 Super Duty aluminum diff cover for my '05 and was wondering if anyone knew the specs on the bolts I should use. The cover is much thicker, so the old steel cover bolts won't work. Metric or SAE? Should I use aluminum bolts or steel? The factory bolts for this cover are over $11 a piece!! so that rules those out....
Greg
PSD #1 SOLD :-(
'96 F350XL 4X4 5-spd 4.10LS SRW reg cab
PSD #2
2005 F250XLT 4X4 supercab short box 6.0 6spd, True Blue, 3.73LS, trailer brake controller, upfitter switches, carpet delete, am/fm/cd/cass, camper pkg, trailer mirrors, skid plates, trailer hitch, fog lamps, priv glass, slider...just what I wanted. AIC via upfitter #4 done, Firestone air bags in back. $120 homemade 4" muffler-less exhaust (ask me how) Edge w/ attitude @13850 mi, power elbow, front receiver hitch. 17" Lariat wheels with 285/70 Toyo OC's
Gregs96 is offline
Old 10-16-2008, 04:52 PM   #2 (permalink)
kaquinn's Avatar
I'm sure there metric! is that a 10.25 i was just on the phone with my parts guy and he has different list for gas /diesel srw /drw w/ different prices also if i find the part # i need ill order it to marrow and ask him for the bolt size!
97'F-250HD 4x4 7.3 cc,sb AFE stage II, MBRP-ss 4", BD-brake, DP-tunner chip, $3,000 in trans, auto meter C2 gauges overhead,....Ride my @$$ you'll see son!
97'F-250HD 4x4 7.3 EC,sb 5 speed
96' F-250 Centurion $dr bronco 4x4 7.3
05'Explorer XLT 4.6 V8/06' Mercury Mountineer
94'Taurus SHO 3.0 5-speed
85' F350 4x4 6.9 w/banks sidewinder under the knife!
94' F350 4x4 7.3 N/A under cont./ referb.
94' F350 4x4 7.3 turbo, dually auto
07' E-250 4.6 i know i know, diesel next time! good price.
i got too much $h!t!!!
kaquinn is offline
Old 10-16-2008, 05:03 PM   #3 (permalink)
RDG
RDG's Avatar
My Photos: (16)
I used 1.25 x 5/16-18 stainless socket cap bolts with washers.
Bob
TheDieselStop.com Moderator
99.5 F-250 CC SRW
TDS Member since 12.18.99
# 4366
NRA Member
RDG is offline
Old 10-16-2008, 10:52 PM   #4 (permalink)
Albin's Avatar
My Photos: (25)
Bob
Same here. It looks very nice on that aluminum cover!
Al
'06 F-350 SRW 6.0 PSD
Albin is offline
Old 10-17-2008, 11:59 AM   #5 (permalink)
x3 here. They are not metric--Much to my surprise! Stainless hex bolts from Fastenal.
2000 F250 PSD XLT CC LB 4x4 Autumn Red, AIS w/DPP Fender Mod, Pro-Comp 2" Leveling Kit, ARE 16x10 058's , 305/70/16 General Ameritrac TR's, Line-X, Delta Tool Box, Chrome GoRhino w2w nerf bar, Firestone Airbags, Stull Billet Grill, Gator Ramp, '01 Cupholder, '02 Headlights, APC Euro corners, Sonnax Valve w/Springs, Optima Batterys, C-BETR Mirrors, ITP Pre-pump/In-Tank, Harpooned, Amsoil Dual By-pass 15W-40, Dieselsite Coolant Filter w/custom bracket, Diesel Manor H/X, Dieselsite Heater By-pass
TomzToyz2 is offline
Old 10-17-2008, 01:06 PM   #6 (permalink)
SmokeyWren's Avatar
My Photos: (42)
It's a Ford-design axle that's been in production since Christ was a corporal, in a Ford axle plant in Sterling MI, with a 10.25" and later with a 10.5" ring gear. Not with a 268mm ring gear, but with a 10.5" ring gear. So it's no surprise here that the bolts that hold on the cover are SAE and not metric.
Now if it were a new design axle, it would probably be a "world market" design and have metric measurements as well as metric threads and bolts. I can't wait for my new SuperDuty pickup that will have a 268mm ring gear.
Man, that sounds huge, doesn't it?
My Sierra Blanca is a '99.5 PSD CrewCab hot-rod Towing Machine! BTS tranny; Ford Severe Duty Air Induction System (AIS); 4" stainless turbo-back exhaust; DP-Tuner tunes flashed into an Edge Evolution tuner; ISSPRO EV gauges and Turbo Temp Monitor (TTM); Auxiliary Idle Controller (AIC); SP-Diesel exhaust brake and torque converter controller. Top Job front end replacement. I special-ordered it new and plan to drive it until it quits.
SmokeyWren is offline
Old 10-17-2008, 04:43 PM   #7 (permalink)
I'm surprised the 10.25/10.5 isn't metric. My old man's '83 F250 has lots of metric hardware on it and that was built probably before the 10.25 was even conceived.
So the crowd says stainess? The allen heads must look sharp. Stainless allen screws it is!
Thanks guys
Greg
PSD #1 SOLD :-(
PSD #2
Gregs96 is offline
Old 10-17-2008, 07:11 PM   #8 (permalink)
Keep in mind that strength in not a major factor for these...
2000 F250 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFGs on 8" rims, 08 AlumDiffCvr, otherwise mostly stock.
24' fifth wheel camping trailer, no RV parks...just the woods.
2005 VW Passat 2.0 TDI, 40+ mpg hiway
1969 Mustang Mach1, 377 clevor, R&P steering, 3.50 posi, 2003 Mach1 Wheels (17s)
69mach1377 is offline
Old 10-17-2008, 08:10 PM   #9 (permalink)
Where are we getting said diff cover, and a part# please.
capt205 is offline
Old 10-17-2008, 10:15 PM   #10 (permalink)
My Photos: (14)
Send a message via AIM to edub32
8C3Z-4033-A i forget where the cheapest place is to get them.
2001 F350 7.3 SCLB 4x4 Off-Road SRW
- DP Tuner, Tymar intake, 35" BFG Mudders on 16x10 Mickey T's, Superlift 6" lift, DiPricol 3 gauge Pillar, 4" SS DP to 5" sidepipe to 6" Chrome tip, WW, Panasonic Deck with 4xInfinity References, Overboost Elim., CCV
edub32 is offline
Old 10-18-2008, 09:53 AM   #11 (permalink)
kaquinn's Avatar
Dose this cover have and extra capacity?
kaquinn is offline
Old 10-18-2008, 10:45 AM   #12 (permalink)
Volume no, cooling yes.
Old 10-18-2008, 05:42 PM   #13 (permalink)
This will fit a 2003 F-350 SRW?
2003 F-350 SD, 7.3 PSD, Auto, CC, LB, SRW, FX4, 4.10:1 Genuine Gear Ring and Pinions, Detroit Truetrac Differentials F&R, FabTech Ladder Bars, SuperChips 1705, Magnaflow 4" Exhaust, Ford AIS Air Cleaner, ISSPRO Boost, Trans, and EGT Guages, XM, Ford AIC, Brite Box, 203* T-Stat and Billet Housing, Tru-Cool 4739 MAX, ProComp StageII 4" Lift on Eagle 589's with 35x12.50x16.5 BFG AT KO's, WeatherGuard Toolbox, Rhino Liner, B&W Turnover w/Companion 5th Wheel Hitch & Firestone Ride Rite Airbags, PacBrake PRXB.
2009 Forest River XLR 3712SA ToyHauler
capt205 is offline
Old 10-18-2008, 10:39 PM   #14 (permalink)
SmokeyWren's Avatar
My Photos: (42)
Best price, but without the bolts and washers you have to have is
Ford Diesel Parts at Powerstroke Shop. Be sure you order the one for 10.5" ring gear and not the bigger one. and I'm not positive that's the aluminum jobbie for the 2008, so call them and verify before you spend the money.
Good price with the bolts amd washers is
Diesel Performance at DieselManor, Inc.
Yes, it will fit all '99-up SRW PSDs. But it will not fit on any diesel dually, which have Dana 80 rear ends.
Old 10-18-2008, 11:58 PM   #15 (permalink)
kaquinn's Avatar
will this fit the sterling axle in my 97?
kaquinn is offline
