Another Herculine question, but different this time...
I'm working on the inside of my E350 7.3L PSD. I'm building tool box / storage cabinets down the inside of the walls leaving ~ 50" in between for easy plywood hauling. I'm facing the boxes with 24g cold roll steel, with the intent of applying Hurculiner over it to keep the inside (of the van) looking nice even if it is getting roughed up a bit with loading/unloading stuff. After reading some of the posts on DIY bedliners, I'm wondering if folks have an opinion on the suitability to my application, or better recommendation. I wanted to install it, then brush/roll on the liner. Not nearly as rough service as a truck bed, so I figure it might just do.
2003 E350 EXT 7.3L PSD, Bought September 2008 @76,000mi.
Centramatic Wheel Balancers
Autometer Phantom Boost, Transmission Temp, and EGT gauges
Powertrax autolocking rear diff.
Scangauge II xgauge
Dahl 75 Pre-pump fuel filter/water separator
Modified Sinister Diesel fuel bowl delete and regulated return + post pump filtration.
Tow Mirrors
Spahl power remote door locks
Dieselsite Max AC Assist
Added cruise control
Sealed Beam to HID Headlight Conversion
Personal blog http://505live.com
