anyone ever put 3" bodylift on 2000 f350 diesel? - Diesel Forum - TheDieselStop.com
Old 07-05-2007, 05:35 AM   #1 (permalink)
I already have 8" all spring but wanted more lift if I fool with the suspension I loose all the shocks brake lines carrier bearing drop etc. not to mention lengthening the drive shafts I know it will be a pain and experimental but I know it can be done I was just hoping to get the heads up before I start
ANY HELP IS GREATLY APPRECIATTED!!!!!!!!!!!
CrazyCajun is offline
Old 07-05-2007, 10:49 AM   #2 (permalink)
Send a message via ICQ to kcastle
Re: anyone ever put 3" bodylift on 2000 f350 diesel?
There use to be a post and some pictures about a white F250/F350 in Iceland that used a body lift.
My Truck
2000 F250 Crew Cab 7.3L Diesel, BTS Tranny, AFE intake, AIT heater delete, GTP38R turbo, EBV delete, 6 position BTS chip, Adrenaline HPOP, In tank and pre-pump mods, Custom polished skid plates and air tank, 37 BFG AT, 4.10 gears
kcastle is offline
Old 07-05-2007, 03:42 PM   #3 (permalink)
i always heard it was dangerous to do a body lift on superduties due to the weight issues. other than that, i geuss you could do it pretty easily, if you have all the equipment.
2001 black/prairie tan crew cab 4wd lariat
3.5" procomp lift front-factory in the back
35" TOYO open country M/T's on 20" moto metal 951's
PARTS FROM DI 6 posi chip, regulated fuel return, bellowed ceramic coated uppies
Garrett GTP38R
4" turbo back exhaust
Originally Posted by TerminatorEngineering View Post
1/2? That will be an interesting truck to see! :hehe:
dougdoug is offline
Old 07-06-2007, 09:30 PM   #4 (permalink)
JimTJr's Avatar
My Photos: (20)
It has been done, but not nearly as easy as a gasser....
Think about it, you ever done a body lift? The Radiator stays put, so the CAC will stay put, along with the ac condensor. Ect.. You would have to take some action with the intercooler plumbing. So, if you think you can fix all that, then it really is not a big deal.
You also have to cut the bottom out of radiator shroud..
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 07-07-2007, 03:56 AM   #5 (permalink)
Don't do it! Your truck will never be the same. My buddy had a 3" on his '01 (With an 8" suspension and hangers) and later had it removed due to the crappy ride characteristics and just overall saftey concerns. He ran with 44's. Are you looking to run 39's or something?
busterswt is offline
Old 07-07-2007, 11:02 AM   #6 (permalink)
JimTJr's Avatar
My Photos: (20)
I also wouldnt want to do it, but not because of the ride characteristics, If your lifting a truck that high, you KNOW it wont ride great, and could "roll easier" The MAIN reason I wouldnt do it, is because of the CAC, and cutting the radiatior shroud. I had a body lift on my 90 Chevy extra cab, with an 8' bed. 6" Explorer Pro Comp lift along with it. Drove and rode fine,
JimTJr is offline
Old 07-07-2007, 02:36 PM   #7 (permalink)
I had a 3" body lift on my 02 crew cab. I never had a single problem. The only way a body lift will change the "ride" is if you install polyurethane cab bushings when you install the body lift, they are harder than the oe rubber cab bushings. Some people say body lifts are cheap and dumb, thats their opinion. It's your truck, use the kit for a V10, it will be safe, just use your head when putting really heavy things in the bed, a quad, fine, a full bed of gravel or dirt, probably not fine. I agree with you that those last 3" can cost a bundle with x-over steering, driveshafts, etc. Body lift is way cheaper, just make sure you get lift lips to hide the gap. BTW, I put the body lift on my old 02 because I tow a large toyhauler, wanted 40"s, and did not want a super long drop hitch. With a body lift your hitch will not be raised, I had a 6" drop, perfect. When you raise your rear bumper, only go up 1.5", it will fit the body of the truck o.k., and your reciever won't look like it's in no mans land. Hope this helps!
2007 F-350,CC,172",XLT,4x4,6.0,auto,Silver,8"CST suspension,38.5" Pro Comp Xtreme A/T on 20x10 Chrome Weld SandStorms,SCT by Innovative, 5" Magnaflow, AFE stage 2,Kenwood CD w/Sirius, 4.88's w/ Mag Hytec covers,Amp steps, Auto Meter gauges
2003 Excursion,XLT,4x4,6.0,auto,Blue/Dark Shadow Grey,4" Pro Comp suspension, 35" Nitto All Terrains on 16"x10" American Eagle 114's
2006 Weekend Warrior FSC3200 Billet Edition w/Hensley Arrow hitch
Snyder3 is offline
Old 07-07-2007, 03:14 PM   #8 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Just think of the turbo you could put under the cowling with an extra 3".
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
Old 11-05-2009, 12:05 AM   #9 (permalink)
i heard about modifying the intercooler pipes. What has to be done to them?
early 1999, 7/98, F-250 7.3L, 250,000+ miles, 4x4, triple disk torque convertor, AFE dryflo home made cold air intake, straight pipe exhaust, superchips tuner (stuck on high performance tune,because someone stole the tuner out of my truck), 4.7K mod, Glow shift gauges (pyro, boost, egt), CCV mod, 3in of lift in front, 1in in back w/ 2009 SD rims w/ 2in wheel spacers wrapped in 325/65/18 Fierce Attitude MT, aftermarket headlamps w/ LED's, ranchhand grill guard, 03' front bumper w/ fog lights, gooseneck hitch
browningbuck225 is offline
Old 11-06-2009, 02:34 PM   #10 (permalink)
69mach1377's Avatar
Snyder, where were you when asked this question a while back? Everyone said no way. I was thinking of just 1-2 inches. Does anyone make a body lift kit that small? Will it mess up a 5th wheel hitch setup?
2000 F250 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, otherwise mostly stock.
24' 5th wheel camping trailer, no RV parks...just the woods.
2005 VW Passat 2.0 TDI, 40+ mpg hiway
1969 Mustang Mach1 HotWheel, 377 clevor, R&P steering, 3.50 posi, 2003 Mach1 Wheels (17s)
69mach1377 is offline
