Anyone try the Detriot Soft Locker in their truck? - Diesel Forum - TheDieselStop.com
Old 02-28-2005, 12:56 PM   #1 (permalink)
Basically, the Detroit people tell me that I have two choices for my sterling rear axle.
1.) the "Soft Locker" that remains locked the majority of the time. It is very strong. The downside is that it makes some noise going around turns but apparently it is not very much in a large truck like an F250.
2.) They are about to release a "True Trac" that is a limited slip differential. The big advantage of this system is that you apparently will never know it is in there except when you need it.
What can you guys tell me about these systems and in particular your experiences w/ the noise of the "Soft Locker", snow & ice handling, off road prowess of these products, etc.?
Thanks Guys
Early '99 7.3 Superduty. Built 3-98
Built motor. Homemade "Big Oil", GT42R Big frame turbo. Rods and junk to keep it all together.
http://community.webshots.com/myphot...ecurity=MuSLdj
Suns_PSD is offline
Old 02-28-2005, 02:09 PM   #2 (permalink)
My Photos: (12)
Re: Anyone try the Detriot Soft Locker in their truck?
I've got a Detroit in the rear of my Toyota for off-roading purposes. I barely hear it and after a while you forget its there, until you make a sharp turn and the tire starts chirping [img]/ubbthreads/images/graemlins/grin.gif[/img] Every once in a while it makes a big BANG and you think the rear end just fell out of your truck, but thats normal. On a big truck like these, I doubt you'll even know its there. You'll want to be sure to keep your tires rotated because the inside rear will scrub if you are on the pedal and turning. It doesn't snow or ice down here so I can't tell you from personal experience, but the rear end will try to pass the front end if its slippery and you stand on it.
For off-roading, I wouldn't use anything other than a true locker such as the detroit. It makes a world of difference!
'02 F250 XLT CC Shorty SRW 4X4, Auto, SCMT 80, AIC, WD pyro, boost & tranny, Jack-It with 4" blocks, AFE, Prodigy, 4" Turbo Back Straight Pipe, 285/75/16 Cooper STT's, Sonnax/Tricum, SP Diesel EST
TxToy is offline
Old 02-28-2005, 02:36 PM   #3 (permalink)
smorgan's Avatar
Got em in my Jeep..Ill pretty much second what TexasToy said.. They get interesting in the [img]/ubbthreads/images/graemlins/eek.gif[/img] snow!!! Also Im locked both ends [img]/ubbthreads/images/graemlins/cool.gif[/img]
http://community.webshots.com/user/skidoomxz02 F350 CC shorty 6 speed, DRW conversion (the right way).. 315 GY Duratracs, 5.5" Fabtech (dropped from 8"), Fox 2.0s in front, 5100s rear, Di 4 pos chip, wicked wheel, ATS housing, Luk, 4" turbo back, AFE, Pro Comp traction bars, ORU diff covers, & other mods my wife doesnt know about..Towing our 71 Z28, 40' Cedar Creek 5ver, or who knows what else.
Work truck 00 F350 xcab,9' dumping stake, V10, stainless headers, Xl to full XLT conversion, 255/85 16s
smorgan is offline
Old 02-28-2005, 07:36 PM   #4 (permalink)
MattBMiller's Avatar
I have one in my race truck. Definitely know it's there on a short wheelbase "grippy" tired truck.
Matt
Truck Pics
2000 F-350 PSD Reg Cab, Black, Slicks.... SOLD
2006 F-350 PSD CC/SWB Amarillo
MattBMiller is offline
Old 03-01-2005, 09:05 PM   #5 (permalink)
The ratchet mechanism is a little loud, and it is rough on the tire wear, and it pushes the front end straight foward...
You have to weight your options and decide..
An air locker might be an alternative as you can have the locker-lock/unlock at the touch of a switch. Drive around in 1 wheel drive and then lock to two TRUE wheel drive, with NO slip except in the tires...Radical, but effective...If you are looking for maximum traction..
2000 F250 SC 4A SB OEM TC, OEM Trans, OEM Turbo, OEM Injectors, OEM Airbox, OEM CAC, Quad Pod W/4 Autometers, 3 Guage cubby-hole, Jody-isized, Fuel System Mods, Mag Hy-Tec, Schaefers 9000, Transgo, Interior is soundproofed, 3.5" DP SS XL Magnaflow, LPG, 106k miles, NVK5 to MNMO, 2200 WATT BI-AMP, 18"s, Best MPG-22.80, Best MPT-760 miles.
FORD-DIESEL.COM MODS--Heater Hose Cutoff Valve, T/C lock, EBV brake, MIAH Plug, QD's removed, Wrapped CAC Tubes, Double Clamped Coolant Hoses, Zoodad, Relocated License plate, painless fuse box. Other RSB Mods
388HP 818Ft.Lbs.@ 130MPH. 4th gear dyno run, 2.1 60, Home-Made Traction bars.
This is a Street truck, 18+MPG(No LP), 14.2 at 98mph, 13 sec Motor, 14 sec Truck(NO Traction)
2004/03 CC SB Auto 6L W/OCT flash, 19+MPG, 20%Bio, AFE, Magnaflow XL SS 4" Exhaust, 75K, Heater By-pass mod, 21.1 MPG best.
2006.5 Jetta DSG 14K 41MPG Best
2005.5 VW Jetta 1.9 TDI 49MPG Best 73K
Kubota 7800 30 HP Hydrostatic 4X4
All Diesels
1969 Mach1 351C 4M 9"
Mach1 is offline
Old 03-02-2005, 12:18 PM   #6 (permalink)
I have one in my truck and don't really notice it around town. Once in a while a chirp while going around a sharp corner but that's about it. No noticable tire wear increase - the front still wears faster then the rear. Concrete with epoxy sealer is super slippery even at slow speeds with a locker - exercise caution in the Ikea parking lot.
JP
Commin at you like a WAGON FULLA PANCAKES!
strong_like_tractor is offline
