Anyone using a Lock-Right locker or other upgrade to lousy OE LS? - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 01-28-2008, 12:02 AM Thread Starter
westvandude's Avatar
Question Anyone using a Lock-Right locker or other upgrade to lousy OE LS?
Anybody upgrade their doa 10.5 sterling LS unit? Was looking at this Power Train Truck & Auto Parts, Inc. :: Lock-Right Locker :: Ford :: Lock-Right Locker Ford 10.25" 12 Bolt 35 Spline Open as it says it's an easy replacement, no gear setup req'd. Anybody running one of these Lock-Right lockers? How is it on the street everyday running?
I installed an 08' aluminum diff cover from dieselmanor.com a couple of days ago. Didn't add any friction modifier just to see if it would give the useless OE LS clutches any more grip but it's still completely useless.
What a shocker... the price of 75w140 synthetic diff oil. 4 x 1 quart bottles Pennzoil... $21cdn EACH!! Man.. the damn oil cost more than the freakin diff cover. Wally Mart didn't have that grade oil in synthetic. Royal Purple was another buck a bottle more. Yikes.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, NAPC 450series trans w/billet triple disc TC, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler, 6.0L trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, tint, 08' alum diff cover, clear corners & tails, 20w LED taillight bulbs, cheap OPT7 HID kit, 2000w inverter, Tekonsha Primus brake controller, 220A HD alternator, 120w LED light bar up front, 2x18w led spots backup lights, 145USgal tidy tank, superlift 4" kit full springs & bilstein 5125 shocks, Level8 striker 16x8.5 blk rims, etc.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. REVO tuned. Aftermarket android 4.2 navi 7" touch head unit, Custom fiberglass box MD Sound 12" & Boss NXD5500 amp. GTI grille and projector fogs.
BioPro190 owner. 20,000L produced 2010-2015.
westvandude is offline
post #2 of 6 (permalink) Old 01-28-2008, 10:46 AM
stevedunham's Avatar
My Photos: (6)
I had a factory Trac Lok in the rear axle of my 89 Bronco ( Ford 8.8" axle) and then the axle that repalced it ( currently 96 Ford 10.25" Sterling Full Floater). They were fair under moderate conditions but when the going got tough, well, let's just say I knicknamed them " Un-limited slips"... They work OK with stock tires on the street but with oversize tires and offroad, they aren't too impressive... When I ordered my current '04 SD, I opted out of the factory LS and installed ARB's front and rear... I also have them in my 89 Bronco which runs a Dana 60 up front and Ford 10.25" rear... I wheel alot more than most so need the strongest locker(s) I can get... They might be more $$ than you are wanting to spend though... To each his own... I know several guys who run the Lock Right and they like them alot... They are easier on the street ( predictable ) than say a Detroit Locker ( pushes in corners, eats rear tires ) but a still very positive and strong... The fact that they aren't difficult to install is also a bonus for alot of guys who want a locker but not pay out the nose to have them installed...
Also, with repsect to the $ of Diff Oil, I feel your pain... However, if it makes you feel any better, diff oil doesn't have to be changed as often as engine oil and it takes a beating... Probalby not much comfort huh? If you are running an aluminum diff cover, you might want to look at a Purple Cranium Products Spider Rock Guard, Ford Sterling 10.25/10.50 Half Spider Differential Rock Guard ... I cracked an aluminum diff cover once on Holy Cross and lost all diff oil in about 30 seconds... Not good...! Check my pics to see what they look like installed...
** SMD '04 F250 6.0 CC King Ranch, '14 F350 6.7 Lariat CC **
Original engine grenaded @ 31,000 miles..! Replacement engine DIY bulletproofed, Gen 4 Injectors, 58V FICM, Blue Spring, IPR Remote Oil Cooler/Coolant Filter, ARP studs, DC Power 270 Amp Alt, BD billet H2O pump, CCV catch can, MBRP Duals, 2 blown Turbos currently running a Garrett, DR Edge 8.5" hybrid lift w/ 5" rear leafs, 37x13.5x17 Swamper M16's, Draw-Tite portable winch mount, WARN xD9000i, WARN Pocket Flares w/ Durabak, 4.56's w/ F&R ARB's, Dynatrac Dana 60 35 spline stubs, Powerslot Cryos/Hawk LTS, Yukon Hardcore 35 spline hubs, 2" wheel spacers,
stevedunham is offline
post #3 of 6 (permalink) Old 01-28-2008, 08:05 PM Thread Starter
Thumbs up
Cool, thanks for the info. Ya, thought about ARB's but I want something more automatic. Don't want to have to flip a switch just because I want to have fun sideways in the rain, etc.
So the lock-right is more gentle than a detroit locker on the street... that's all I need to know. I installed an Eaton LS with carbon clutches in my 8.8 that was in my 98' F150. Worked great. Tons of kms on it and it grabbed really good, but I never did serious offroad with it.
post #4 of 6 (permalink) Old 01-29-2008, 09:44 AM
You might also look at the Detroit Truetrac [see Randy's, ringpinion.com, popular source for diff. stuff, in yer general neighborhood] if you are looking primarily to improve on-road LS performance, though the install may be more complicated. Like mine; its a worm gear, no clutches to wear out; note the cautions on Randy's description for the lock-right for big tires and/or high HP.
2002 F350 Supercab Lariat 4x4 7.3L 6 spd. B&W gooseneck, Prodigy brake controller, PAC exhaust brake, WARN manual hubs, Ford AIS, Bilsteins, Michelin LTX, Line-X bedliner, 203F t-stat, Cat ELC coolant, by-pass coolant filter.
Wife's Ride: 2006 Mercedes Benz E320 CDI
Riggodeaux is offline
post #5 of 6 (permalink) Old 01-30-2008, 04:07 AM
IceMan89m's Avatar
My Photos: (12)
Lock-Right, My advice, save your money and put it into a better unit, you will not be happy with a lock-rite..
also see this post
installed a lockright?
03 f-350 FX4 6.0 PS BullyDog Triple with Outlook, AEM Brute Force, Frantz Bypass, 8" Dick Cepek race series lift, 12"x16" Dick Cepek type 1 wheels, 36"x14.50x16 Parnelli Jones Dirt Grip Tires....
International Union of Operating Engineers
local 324....
AMA,District 14 & HOG member
IceMan89m is offline
post #6 of 6 (permalink) Old 01-31-2008, 12:59 AM Thread Starter
Shoot...that aint no good! Cancel that then.
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
Similar Threads
$700 and still a lousy clutch... (Update) jcb1 Power Strokes 1994-1997 General 10 10-12-2006 01:32 PM
Attn: 'high rear gear crazies and those who tow with lockers', to locker or not to locker?? ChrisB General Diesel 2 04-15-2006 01:43 PM
Lousy Continental Tires lvsqcsl 1999-2007 General Questions 22 01-02-2006 01:49 PM
Power Door lock upgrade wjb 1999-2007 General Questions 0 12-09-2005 07:58 PM
Detroit locker or ARB air locker XinAZ 1999-2007 Upgrades and Aftermarket - General 13 11-05-2005 01:59 PM
