Battery Tender - Diesel Forum - TheDieselStop.com
post #1 of 21 (permalink) Old 11-07-2011, 09:57 PM Thread Starter
bigb's Avatar
Battery Tender
What kind are you guys using for your vehicles that sit a lot. I got a $20 Car Quest one about a year and a half ago and it is dead, don't know how long it has been dead as the indicator light still works but no charge output. So now I am looking at a genuine Battery Tender brand, this one:
Brian, Tucson, Arizona
02 F350 4x4 CREW 7.3 160K, BFG Rugged Terrain 285s, AIS, Isspro pyro, boost & tranny temp pillar pod, Dipricol coolant temp, ELC, Isspro EV-2 Fuel Pressure & HPOP, Dieselsite boots, coolant & tranny filters & 203* Stat, 6.0 Tranny Cooler, ITP pre pump tank mod, Bellowed Up Pipes, Riffraff Frx, netbook mount with AE, GPR LED, Stancor, Red Head steering gear, Battery Tender & 2 Marincos.
bigb is offline
post #2 of 21 (permalink) Old 11-08-2011, 03:00 PM
taztruck's Avatar
That is the same unit I mounted under my hood. It works great.
2003 F-250 (Built 1-03, Engine built at Huntsville plant on Sept. 20, '02), 6.0L, 4x4, CC, Moonroof, Pwr Pedals, FX4, King Ranch, DRL, Leer 100XL cap, Bed Rug, AIC, Prodigy control, Delphi Skyfi XM radio with line input to OEM 6 CD changer using P.I.E. FRDN-AUX Auxiliary Input Converter and Auto-Power On Adapter for SkyFi, Centramatics, Putco Virtual Vertical Grill, Fumoto Drain Valve, B27.9 Flash, BD X-Monitor with Cool Engine Shutdown Module, Dieselsite coolant and transmission filters, Oilguard by-pass filter.
2008 Escape Hybrid
taztruck is offline
post #3 of 21 (permalink) Old 11-08-2011, 05:37 PM
Schumacher XC10 10/6/2-Amp Battery Charger
Walmart.com: Schumacher XC10 10/6/2-Amp Battery Charger: Automotive
I got mine at walmart for $40. It's not a tender though, only a charger.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 170,000 miles, repairs so far: starter, batteries, cps, brakes, tires.
DonWarkentin is offline
post #4 of 21 (permalink) Old 11-08-2011, 06:25 PM
Do you need 2 of these, one for each battery? Mine will be setting more now instead of being used as a daily driver.
2003 CC SRW SB Auto 3.73
Mods:
REAR Air Locker
Kenwood DNX 7140
ISSPRO A Pillar Gauges
Femoto Valve
Edge Insight CTS
dieselhappy is offline
post #5 of 21 (permalink) Old 11-08-2011, 07:19 PM
Mine charges both batteries at once just by connecting it to either one of the batteries, because the two batteries are connected to each other by wires.
post #6 of 21 (permalink) Old 11-08-2011, 09:07 PM Thread Starter
bigb's Avatar
Were you able to get it to fit on the passenger fender next to the battery?
bigb is offline
post #7 of 21 (permalink) Old 11-09-2011, 09:35 AM
Originally Posted by bigb View Post
What kind are you guys using for your vehicles that sit a lot. I got a $20 Car Quest one about a year and a half ago and it is dead, don't know how long it has been dead as the indicator light still works but no charge output. So now I am looking at a genuine Battery Tender brand, this one: Amazon.com: Battery Tender 022-0157-1 Waterproof 12 Volt Power Tender Plus Battery Charger: Automotive
Yea, that is the one you want, but it can be had for less than that, shop around.
Rangertheduck is offline
post #8 of 21 (permalink) Old 11-09-2011, 04:49 PM
I'm drawing a blank. Can you give us a clue where you saw it for less than $77.59 with free shipping?
post #9 of 21 (permalink) Old 11-10-2011, 12:05 AM
Here.......Battery Tender Plus 12 Volt 1.25 Amp Battery Charger: BatteryMart.com
post #10 of 21 (permalink) Old 11-10-2011, 12:15 AM
http://www.batterymart.com/p-del-021...FSYaQgodiDVhEg
Its the same brand but not the same model.
post #11 of 21 (permalink) Old 11-10-2011, 07:34 AM
The one posted for 45.00 looks like a much bigger profile, would be much harder to mount in the truck.
Shortbus
2002 F250 7.3 PSD Crew Cab LWB
4" to 5" Straight Piped
Bilstein 5100's
RiffRaff 6637 Filter Kit
Diablo Programmer
Warn Premium Hubs
BFG 285x75xR16
Viar 450c Compressor and Tank
Heater Plug Mod - Foil Delete Mod
203 Degree Themo, Billet Housing
As of 01/01/14 = 254,000 miles
SOLD
1994 F350 7.3 Turbo Diesel IDI
4x4 Standard Cab LWB Hunter Green XL
171,000 miles going strong
Shortbus is offline
post #12 of 21 (permalink) Old 11-10-2011, 08:14 AM Thread Starter
bigb's Avatar
And it is only 1.25 amps, the one I am looking at is 5 amps. I just ordered it.
bigb is offline
post #13 of 21 (permalink) Old 11-10-2011, 10:19 AM
As a tender, for maintaining a battery. I would never charge more than 2 amps. After all it will be on there for 8-10 hours. Plenty for keeping a float charge.........To each their own.
post #14 of 21 (permalink) Old 11-10-2011, 01:39 PM Thread Starter
bigb's Avatar
The rating of the charger doesn't mean it charges at that rate all the time. If your battery is near fully charged the charging current will drop to a low rate. The Battery Tender specifically cannot overcharge the battery because it switches to a float charge once the battery is fully charged. I chose that model for 2 reasons, I can mount it on the fender and connect it to my bumper power inlet which means I don't have to be raising the hood all the time, and because with two batteries my amp hour rating is up there around 130 and I believe a smaller capacity charger will burn itself out like my original one from Carquest did. I was also looking at this one
but if you notice it is rated 3.3 amps and says for batteries "up to 120 AH" so I chose the Battery Tender brand one instead.
Under maintainence operation it will never charge at the 5 amp rating, but I will have the 5 amps available if I ever need it, plus under normal maintainence charging it will be using only a fraction of it's rating which I believe will lead to a long life.
bigb is offline
post #15 of 21 (permalink) Old 11-13-2011, 10:11 PM
tempsho's Avatar
I have this permanently mounted under my hood. It works really good.
BatteryMINDer® 12 Volt 1.5A OnBoard Battery Charger/Maintainer/Desulfator/Conditioner Model 12151 | Automotive Battery Chargers | Battery Chargers by BatteryMINDers.com
2002 7.3L Excursion Limited 4x4
- Built transmission
- 21"/11"/21" Vision X Xmitter Prime LED light bars up front (47,000 lumens)
- Edge CS Monitor
- Tymar intake
- Door Seal Mod
- Fumoto Quick Drain Valve
- Coolant filter, ELC, 203* T-stat and billet aluminum housing
- Riff Raff boots
- PHP Chip
(Stock, 80DD, 100Race, Whisper Mode, 80Tow, Smoke Show)
- 2" lift (F350 leafs front and back)
- Hellwig rear sway bar, Bilstein 5100's
- LT275/65R20 Durtrac's on 20" King Ranch wheels
- Fred Goeske 2" steel wheel adapters
- Genuine Larry B's Denso starter
tempsho is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
