Big Rig Tires and Wheels - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 08-10-2008, 01:53 AM Thread Starter
Thumbs up Big Rig Tires and Wheels
Hi Guys,
It is me again and need more opinions. I like the look of the big rig wheels, 22.5", but was wondering how much it will effect the towing performance of my truck, 2005 F-350 dually, 4X4, 6.0. I pull a fifth wheel that weighs about 11,500# when loaded. I understand that the gear ratio will be somewhat changed due to the lareger tires. Can anyone offer some direction here?
Thanks!
DUAL350
DUAL350 is offline
post #2 of 8 (permalink) Old 08-12-2008, 10:28 AM
Overkill's Avatar
My Photos: (31)
Originally Posted by DUAL350 View Post
Hi Guys,
Thanks!
DUAL350
We have several customers on 22.5 and 24.5 combos who pull considerable weight without issue. Most of the performance difference is due to the increased tire diameter. You could re-gear if you find that your EGTs are on the high side when towing. Here are a couple of examples:
Overkill is offline
post #3 of 8 (permalink) Old 08-13-2008, 04:16 PM
If you go to the size 255/70R22.5 in the Bridgestone R250F, then the tire diameter is 36.7". For comparison, the LT245/75R17 tires that are stock on your truck have a diameter of 31.5". The ratio of diameters is 1.165. I'm not sure what rear end ratio you have now, but for example, if it is 4.10, then divide that by 1.165 to get 3.52, which is the effective rear end ratio that you would have with the tire swap. Multiply 4.10 by 1.165 to get 4.78. That is the rear end ratio that you would need to change to in order to keep the same effective gearing after the tire swap. Of course, the fact that the bigger tires are heavier is going to slow you down a little also.
Sizes and Specifications
https://www.bfentirenet.com/product_...8&partial=true
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 170,000 miles, repairs so far: starter, batteries, cps, brakes, tires.
DonWarkentin is offline
post #4 of 8 (permalink) Old 08-14-2008, 02:06 PM
Strokin' 6.0's Avatar
What kind of a lift do you need, in order to put 22.5's on?
How noticeable is the ride difference with 22.5's? By that I mean, is the ride a lot harsher than with the stock tires?
How much more wear do you get with the 22.5's?
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
2012 Ford bed w/Factory Reese hitch option
4.10 TracLok
Dieselsite Coolant Filter
IH Fleetrite ELC
Blue Spring Update
43,956 miles - Replaced 6.0L
54,814 miles - Turbo
94,943 miles - Fan clutch
98,755 miles - FICM
127,057 miles - Aftermarket Alternator
154,120 miles - HPOP & Oil Cooler
168,514 miles - Radiator, water pump, t-stat & hoses
178,810 mles - #7 injector
181,807 miles - A/C Compressor
199,458 miles - Motorcraft Alternator
199,506 miles - FICM
199,521 miles - #1, #4, #8 injectors
Strokin' 6.0 is offline
post #5 of 8 (permalink) Old 08-14-2008, 05:03 PM
Overkill's Avatar
My Photos: (31)
Here is an example with a 2.5" lift (you will need approximately 3" minimum on your '04):
IMO, the tires are not very rough with proper inflation. Tread wear will not be an issue. These tires are designed for huge miles on an 80,000 lbs rig. They hardly notice the weight of the SD.
Overkill is offline
post #6 of 8 (permalink) Old 08-14-2008, 10:21 PM
Looks real nice. Aside from size difference, what are the differences between the 19.5 and the 22.5? I've heard that you don't need a lift with the 19.5's.
Fred
King Ranch
4.10 TracLok
IH Fleetrite ELC
Blue Spring Update
98,755 miles - FICM
post #7 of 8 (permalink) Old 08-15-2008, 10:50 AM
Overkill's Avatar
My Photos: (31)
225/70-19.5 32"
245/70-19.5 33"
225/70-22.5 36"
19.5s do not require any lift.
Overkill is offline
post #8 of 8 (permalink) Old 08-15-2008, 02:55 PM
Great, thanks for the info....so how far away are you from San Angelo?
Fred
King Ranch
4.10 TracLok
IH Fleetrite ELC
Blue Spring Update
98,755 miles - FICM
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
