Bilstein Shock Help - PLEASE - Diesel Forum - TheDieselStop.com
Old 07-23-2009, 08:57 AM   #1 (permalink)
Good morning all;
The wife and I are leaving for a 6,000+ mile road trip next Friday 31JUL09. I have an '06 F-350 SRW with 65,000 miles(vehicle in signature). I have Toyo 35x12.5x18 M/T on stock rims. I want to change the shocks before leaving (still have the stock "Rancho"). Should I go with the standard bilstien Blue & Yellow or 5100's? Also, can anyone supply part nubmers for the 5100's for a stock suspension? Also, who has the fastest shipping?
Thanks!
Delivered: 29SEP05
2006 Black F-350 Lariat Crew Cab Long Box Single Rear Wheel FX4; 6.0L PSD w/ TorqShift; Tan Leather Captains Chairs (Heated); 6 Disc CD Player; Manual Locking Hubs; Engine Block Heater; Power Moon Roof; Power Rear Slider; FX4 Package
Camper Package; Snow Plow Prep Package; Tow Command System; Power/Heated Telescoping Trailer Tow Mirrors; Upfitter Switches; Roof Clearance Lights; Dual Alternators; Reverse Vehicle Aid Sensors
Add-on's: Line-X Bed Liner; Weather Guard Diamond Plate Cross Over Tool Box; SEIC; Cobra 29 Classic with Wilson Trucker 5000; Rechargeable Mag Light; Key in ignition dinger delete; Toyo Open Country M/T 35x12.5x18; KC Daylighters mounted on Trailer Tow Mirrors; Back Rack w/ 2 KC Flood Lights; Herculiner on rockers; Custom Extang Tonneau Cover; MBRP Turbo Back Exhaust; SCTX3 & IDP Tunes; ZooDad Mod
pkravetz is offline
Old 07-23-2009, 12:26 PM   #2 (permalink)
69mach1377's Avatar
Unless you plan to lift, stick with stock replacements.
2000 F250 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, otherwise mostly stock.
24' 5th wheel camping trailer, no RV parks...just the woods.
2005 VW Passat 2.0 TDI, 40+ mpg hiway
1969 Mustang Mach1 HotWheel, 377 clevor, R&P steering, 3.50 posi, 2003 Mach1 Wheels (17s)
69mach1377 is offline
Old 07-23-2009, 12:28 PM   #3 (permalink)
BadDogPSD's Avatar
Pretty sure the 5100's are for lifted trucks.
1997 F250 4x4 Crew Cab PSD; Modded H2E, FFD Stage 2's, CPR Fuel, SRP1, ARP studs, Comp 910's, DI pushrods, Dana 60; Sky RSK w/SD springs.
BadDogPSD is offline
Old 07-23-2009, 04:13 PM   #4 (permalink)
My Photos: (19)
You should be able to get the 5100's for stock. The biggest thing is they come with different valving for someone that may not have a totally stock truck or doesn't like the valving that comes with everything else. As for shipping... no idea.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline
Old 07-23-2009, 04:27 PM   #5 (permalink)
BadDogPSD's Avatar
Good to know!
To the OP, you may want to contact member Caryt, I know he has done quite a bit of work on fine-tuning suspensions and also sells custom Bilsteins
through his business, CT Performance.
Old 07-25-2009, 11:20 PM   #6 (permalink)
Pearlgc's Avatar
BadDogPSd has it right, contact Caryt (Cary) here on the Diesel Stop and he'll hook you up. You may be looking at 5125's and about $350+ with shipping. They will need to be valved properly.
2004 F-350 Lariat, SD, CC, 4X4, SB,
Volant Intake, SnugTop Canopy,
Spray in liner, custom Billet Tail-gate badge
and still adding on...
SEMPER FI
Pearlgc is offline
