Re: Body Lift
that sucks i would rather modify the fire wall.these things have a very heavy body to be suported by a body lift.i wouldent do it if it was mine.but if you have to you have to i geuse.
2000 f250 4x4 lariate woodland green metalic and gold on the bottom.sharp looking super cab.100,000 miles .air heater mod,CCV mod,zoodad,80 econo DP tuner PCM ,cranked doun stock waste gate,cubie hole type gauge pod,k@n replacement filter.sonax/tricumulator, map sensor pop off valve,boost tube,BTM ,code eliminators ,wiked wheel,EBPV deleat ,hp oil cross over feul presure shimed and gauge, Heater core hose bypass valve .Wet Okole seat covers with Powerstroke logo ,.home made donaldson intake in the works parts on order.mounting bracket and 45* silicone elbo.piss on this homemade thing it will never be as good as the AFE stage II.thats what i'll get next.i am curently running my stock air box
